Overengineering
  • Shocker
    Banned
    • Dec 2011
    • 635
    Overengineering
    How much do you overspecify the components when building electronics???
  • japlytic
    • Oct 2005
    • 2086
    Re: Overengineering
    It depends on what it is, but in most cases, I overengineer, but not excessively.
    • Shocker
      Banned
      • Dec 2011
      • 635
      Re: Overengineering
      I understand the concept of "wasted durability". But if it only adds a few % to the overall cost, why not???
      Also, you never know how the equipment is going to get abused. Like dropping hard drives to the floor. No, seriously, I had a Barracuda ATA III fall about 1m and it still worked fine.
      Personally, I would like equipment to be designed with an operational lifespan of at least 20 years at 40°C ambient. I'm only interested in technologies that make a real and significant improvement to usability, reliability, efficiency, robustness, or compactness, without compromising. Or health and safety, but note that lead-free solder does not make the list. In fact, chances are it's causing more harm than good, due to tin whiskers and BGA problems. Not to mention that solder only makes a small percentage of the total lead in electronics anyway. Two things: CRTs, and car batteries.
      • PeteS in CA
        • Aug 2005
        • 3583
        • USA, Unsure of Planet
        Re: Overengineering
        My dream is for the @#$%ing Envirocrats who dreamed up RoHS to find their lives dependent on medical electronics built with lead-free components and solder!
        PeteS in CA
        • dmill89
          • Dec 2011
          • 2534
          Re: Overengineering
          I'll second that, how eco-friendly is something that ends up in a landfill due to early failure anyway?
          • Shocker
            Banned
            • Dec 2011
            • 635
            Re: Overengineering
            I'll third that...
            For the record, I once saw a circuit board labelled "RoHS" that was soldered with ordinary leaded solder. It was in a cheapo PSU with a seized fan though so fake RoHS was the only good thing about it.
            Oh yeah, health and safety. Despite being in Australia, I stumbled across a North American type IEC cable. They really need to get rid of that too since on the plug I'm looking at, there's all of 3.5mm from the outside edge to the pins. Which aren't insulated even today. Nice job, NEMA .
            For the record, my favourite plug design is BS 1363 with massive pins (a prime example of overengineering), mandatory shutters, and built-in fuses. In case you're wondering, I do have (multiple) BS 1363 cords too. Which plug is your favourite???
            • dumpystig
              • Jul 2011
              • 485
              Re: Overengineering
              You have these (British) plugs in Australia?
              System: HP xw6600 Workstation, 650W PSU | 2x Intel Xeon Quad E5440 @2.83GHz | 8x 1GB FB-DDR2 @ 667MHz | Kingston/Intel X25-M 160GB SSD | 2x 1TB Spinpoint F3, RAID0 | 1x 1TB Spinpoint F3, backup | ATI FireGL V7700 512MB | Sony Optiarc DVD +/-RW | Win 7 Ultimate x64 | 2x Dell UltraSharp U2410f | Dell E248WFP
              • Shocker
                Banned
                • Dec 2011
                • 635
                Re: Overengineering
                What I'm talking about that is, but I don't quite get the question.
                • dumpystig
                  • Jul 2011
                  • 485
                  Re: Overengineering
                  Hmmm now I'm puzzled - how can you not get the question?
                  BS1363 is a British Standard. Are you saying that the same plugs/sockets are installed in Australia?
                  • Shocker
                    Banned
                    • Dec 2011
                    • 635
                    Re: Overengineering
                    No, I just happened to get my hands on an entire bag of the cords (as well as CEE 7/7).
                    • dumpystig
                      • Jul 2011
                      • 485
                      Re: Overengineering
                      Ah, right.
                      Yeah, it is a very good standard, the plugs/sockets are polarized and are very safe especially compared to the basic plugs used in most of Europe.
                      The only drawback is the size/shape of the plug - it's very awkward and makes it hard work when packing in a small case for a portable device.
                        Re: Overengineering
                        Since the UK plug has built-in fuse, do they install the Time-delay, or fast-blow type fuse, current rating?
                        Is the Neutral also bonded to Ground at the panel?
                        "North American type IEC cable"
                        By the way, NEMA does not set the standard for the IEC.
                        http://www.iec.ch/
                        • Shocker
                          Banned
                          • Dec 2011
                          • 635
                          Re: Overengineering
                          If you want to be formal, it's a "NEMA 5-15P to IEC C13" cable.
                          But you get the idea.
                          EDIT: Anyone willing to bring this thread back on topic???
                            Re: Overengineering
                            Some of my mentality:
                            - LDOs/Linear regs not allowed to exceed 60C case temp under normal conditions
                            - If an LDO would dissipate more than 1W, consider a switcher.
                            - Axial power diodes: 2A max, derate 50% from datasheet. Otherwise you NEED a heatsink. Vbrr 90% of maximum.
                            - Power MOSFET not to exceed 80C case (110C for 150-175C rated devices), Vdss 90% of maximum (to allow for ringing at drain for inductive loads.)
                            - If a resistor needs to dissipate more than 5W in your design, you are probably doing something wrong.
                            - If you make something idiot proof, the universe will invent a better idiot.
                            - Fuse stuff above 50V or where available power exceeds 50VA. (Except in certain circumstances where short circuits are rare or can be guaranteed to not happen within design parameters.)
                            • Shocker
                              Banned
                              • Dec 2011
                              • 635
                              Re: Overengineering
                              I think 90% of reverse breakdown voltage is too close for comfort. Remember that reaching the breakdown voltage will lead to catastrophic failure. I'd aim for ⅔.
                                Re: Overengineering
                                Not catastrophic, no. It will lead to breakdown of the PN junction which is reversible if pulse energy limits are maintained. Usually it will cause excessive heat in the diode and lousy efficiency in certain types of converters (a flyback, for example, would discharge through the transformer, and back into the primary snubber, I think.)
                                • Shocker
                                  Banned
                                  • Dec 2011
                                  • 635
                                  Re: Overengineering
                                  And if the dissipation is high enough, and you keep it up for long enough...
                                  Always best to play it safe.
                                    Re: Overengineering
                                    There are five current ratings for the fuse: 1A, 3A, 5A, 10A and 13A; but the most common are 3A, 5A and 13A. The fuse is intended to stop a ring circuit overload or a plug overload which would not be stopped by a breaker.
                                    Nope, but it is bonded at the substation or sometimes the electrical pole. In our house earth measures 6VAC relative to neutral, so the bonding is probably very close.
                                    • BOSCHNJAK
                                      by BOSCHNJAK
                                      ABOUT ME INTRODUCTION FILE
                                      2
                                      024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
                                      2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
                                      2022 BEV, PROJECT ?
                                      2021 BEV, PROJECT ?
                                      2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
                                      2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
                                      12-28-2023, 02:09 PM
                                    • RetroComputingGrotto
                                      Opinions/Advice on Do/Should I replace ALL Electrolytic Capacitors on old equipment?
                                      by RetroComputingGrotto
                                      I've just been repairing some (very) old speakers with a loud hum that occurred as soon as you powered them on regardless if any actual audio is played through them. I work in a School so it's 99% likey that the Teachers have hardly ever turned the power off on them for well over 10+ years.
                                      As you can see the top large capacitor on the right has a bulge on the top so defincately needs replacing. As the one next to it is exactly the same capacity and voltage I planned to replace them both.
                                      What is your advice/opinion on whether or not on old(er)...
                                      04-03-2024, 08:30 AM
                                    • tony359
                                      Use of a Variac to slowly power up equipment
                                      by tony359
                                      I have an old Apple II monitor to restore and I do have a big variac. I've always wondered whether a variac is a good idea to power on equipment which has been unpowered for (likely) decades?
                                      When it comes to analogue stuff, I suppose it's ok and I'm probably going to see the device slowly coming back to life with a lower voltage applied.
                                      But I suppose this won't work for devices with digital components in it as they won't work unless the proper voltages are applied?
                                      In case of an old monitor, it is safe/good for the monitor to...
                                      10-13-2023, 02:47 AM
                                    • Fritter
                                      Your most useful test equipment.
                                      by Fritter
                                      Hi All,
                                      For some background, I passed an OND in electronics in the 80's. Life took me elsewhere, and I've finally got around to using it practically. My interest is in vintage electronics.
                                      My question is, other than a multimeter, what is the most used and useful piece of test equipment ?
                                      Thanks !
                                      06-07-2023, 12:23 PM
                                    • eccerr0r
                                      Server equipment... slow boot?
                                      by eccerr0r
                                      Is it normal for servers to take an eon to boot?
                                      I have two "server class" machines/boards now, with ECC RAM. Both take an eon and a half to boot.
                                      The specific one I have is a Supermicro board with an atom c2550 chip in it. It takes forever, almost a minute before it initializes vga if at all (for some reason it doesn't even init the onboard VGA port, I have to stick in a PCIe card). Machine almost seems dead before then.
                                      The other machine is an Itanium machine, likewise does not init VGA until at least a few minutes after power up.
                                      02-19-2023, 06:02 PM
