Transistor package colours
  • japlytic
    • Oct 2005
    • 2086
    Some Japanese manufacturers use green coloured encapsulation for PNP transistors, whereas NPN transistors are normally black (some older transistors had grey encapsulation).
    The above mainly affects transistors in a TO-126 or larger package.
    I have seen blue 2SD386A(Y) transistors from 1977 - what does the blue colouring of the encapsulation mean?
  • PeteS in CA
    • Aug 2005
    • 3583
    • USA, Unsure of Planet
    Re: Transistor package colours
    Hmmm ... all the plastic package transistors I've seen were Model T-colored ("Any color you want as long as it's black"). W/O looking for a datasheet ... could it be a darlington or a JFET?
    PeteS in CA
      I have seen and used Japanese transistor with Green, red, blue casing on TO-220. I do not think it means anything since the same one manufaturer will use the color they want to differentiate it from other manufacturer even thoug it has the same P/N as the other manufacturers .
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i remember some nec 2sc1307 in red cases.
        bought the bag of 500 at a surplus dealer.
        i tested them and they had about 3db more gain than others i had seen.
        these average about 12db.some of the red ones were 16.
        special run for an oem?
        this was when cb was hot.these are used in final stage of ssb cb's.
          FP5139D-LF, FP5139DR-LF, FP5139W-LF, FP5139WR-LF, FP5139T-LF, FP5139TR-LF Datasheet
          BOOST CONVERT CONTROL IC
          The FP5139D-LF, FP5139DR-LF, FP5139W-LF, FP5139WR-LF, FP5139T-LF, FP5139TR-LF is a boost topology switching regulator control IC for battery-used applications field. The FP5139 includes a totem-pole single output stage for driving NPN transistor or N-MOS, high precision reference (0.5V) for comparing output voltage with feedback amplifier, an internal dead-time control for controlling the minimum duty cycle, programmable soft start with short circuit protection function and logic level control for operating mode or standby mode.
          FP5139 FEATURES...
          10-07-2024, 05:15 AM
        • delir66
          Transistor from USB HUB
          by delir66
          Hi all!
          Yesterday my usb hub started smoking after I pluged in a pad controller.... It has performed great for a couple of years.
          There is a burnt smd transistor, but the code is unreadable. It's a Sot-23 package. I read somewhere that smd transistors starting with "A" are MOSFET.
          Don't know if P or N.
          5v from usb goes straight to the single pin side, which might be Drain...
          Only data i have is package, usb operation voltage.
          No max current draw on the label.... it has 7 usb ports.
          Don't know about transistor specs....
          10-14-2022, 04:21 PM
        • magneh
          Behringer Eurolive B205D repair - help identifying transistor
          by magneh
          Hello
          Got this speaker from a friend , defective. Power led comes on and off , in a loop.
          Disassembled, got the board out, and after a bit of measuring I found a low resistance on a 5v6 line. With a bit of current I found a transistor heating up on that line (labeled T1 and 113 as on pic).
          After removing this guy, I got a value of 0.7 in diode mode on that 5v6 line, which before had 0.02 or something like that.
          I tested powering it up without the IC, and the speaker turns on and stays on, and works fine
          Still, I need to replace this transistor....
          06-18-2025, 02:34 AM
        • Francesc V.
          Onkyo A8200 - Not the right voltages in some transistors
          by Francesc V.
          Hi:
          I am trying to repair this amplifier that I've bought as faulty. I've found some transistors damaged, the ones where I am drawing a red circle.
          With the final transistors not yet installed (the expensive ones), I've started to measure some voltages:
          Where I am supposed to have 1.12V (base Q524/Q523) I am reading -42V..................both channels don't seem ok.
          Where I am supposed to have -1.12V (base Q526/Q525) I am reading -44V..................both channels don't seem ok.
          I removed and tested Q514,Q516 & Q513,Q515 but the analyzer...
          04-19-2025, 07:17 AM
        • elsomer
          help to identify transistor msi ms-15ck1
          by elsomer
          hi people, i need some help to identify a transistor(q14) that is missing on the board, so the gpu has no voltage i think that q14 activate the phases for gpu, but i dont have schematic or boardview, but i think its the same transistor than q15 and q16, thanks...
          02-17-2025, 05:30 PM
