FP5139D-LF, FP5139DR-LF, FP5139W-LF, FP5139WR-LF, FP5139T-LF, FP5139TR-LF Datasheet
    • 115474
    BOOST CONVERT CONTROL IC
    The FP5139D-LF, FP5139DR-LF, FP5139W-LF, FP5139WR-LF, FP5139T-LF, FP5139TR-LF is a boost topology switching regulator control IC for battery-used applications field. The FP5139 includes a totem-pole single output stage for driving NPN transistor or N-MOS, high precision reference (0.5V) for comparing output voltage with feedback amplifier, an internal dead-time control for controlling the minimum duty cycle, programmable soft start with short circuit protection function and logic level control for operating mode or standby mode.
    FP5139 FEATURES
    ● Wide supply voltage operating range: 1.8 to 15V
    ● Reference voltage precision: 4%
    ● Low current consumption: Operation Mode 5.5mA Standby-by Mode 1µA
    ● High speed oscillator frequency: 1MHz max.
    ● Programmable Soft Start function (SS)
    ● Short Circuit Protection function(SCP)
    ●Totem-pole output with adjustable on/off current (for NPN transistors or n-channel MOSFET)
    ● Logic level control stand-by mode function
    ● Package: SOP8/TSSOP8/MSOP8
    TYPICAL APPLICATION
    ● Digital Camera
    ● PDA
    ● Portable Equipment​
  • subroto
    Programmable and non-programmable SIO list
    by subroto
    ene kb9012 programmable
    ene kb9016 programmable
    ene kb9018 programmable
    ene kb9022 programmable
    ene kb9028qc programmable
    ene kb9010 programmable
    ene kb3930qf/b1 programmable
    ite it8585e programmable
    ite it8586e programmable
    ite it8985e programmable
    ite it8587e programmable
    ite it8522 programmable
    ite it8987e programmable
    ite it8589 programmable
    ite IT8380E programmable 192kb
    ite IT8380VG programmable 192kb
    ite IT8995E-128 programmable
    ite it8886H...
    01-13-2018, 09:15 AM
  • Yanleb
    LG 60PK550 Logic Control Board EBR63450301
    by Yanleb
    Hi all, I just want to share the repair of my 60PK550-UA TV set.
    The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
    But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
    All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
    C57: 3.30V
    C61:...
    07-20-2023, 12:38 AM
    Electronic Goldmine has replacement Irons for the ZD-978 or similar model number this the one that has the sleep function
    This is a new item at Electronic GoldMine that has arrived within the last few weeks
    Here is the link for them I know for sure that it works because ( I tried it on mine soldering station ) I bought two of them and I just bought two more of them so I have some extra replacement ones in my parts bin
    Stahl Tools DDDS Replacement Iron for DSDS Stahl Solder Station
    https://theelectronicgoldmine.com/products/g28392
    One note it will not work for the ZD-917 or similar model number that does not have the sleep function that are the same iron but the plug only...
    11-24-2024, 01:25 AM
    Fintek F71868A Super I/O and Hardware Monitor Datasheet
    The F71868A which is the featured IO chip for PC system is equipped with one IEEE 1284
    Parallel Port, two UART Ports, one 80 port (multi with COM2), Hardware Keyboard Controller, and SIR. The F71868A integrates with hardware monitor, 9 sets of voltage sensor, 3 sets of creative auto-controlling fans and 3 temperature sensor pins for the accurate dual current type temperature measurement for CPU thermal diode or external transistors 2N3906. Others, the F71868A supports newest AMD TSI and Intel PECI 3.0 interfaces and INTEL Ibex...
    10-23-2024, 02:26 AM
  • harp
    triac phase control 0-100%
    by harp
    Trying to understand which properties of circuit affect triac phase range, is it possible to control near whole period, or it have some limitations - on net found a couple circuit, that claims almost full control, but in the past I build some simple circuit and remember that it do only half of control over triac?...
    06-02-2024, 09:00 AM
