Dirt cheap radio hacking!
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    I've been playing with an AM transmitter these days, built with nothing more than a NAND gate, a few resistors, a few caps, one transistor and a tunable coil. The NAND gate is the oscillator, and the transistor with the LC circuit provides modulation, filtering and power gain. The gimmick proved to be quite stable, working for 4+ hours on end without drifting at all as per my Yamaha PLL tuner. Better than a transistor LC oscillator, and certainly WAY better than a 555. I experimented with carrier current transmission (coupling the transmitter output to the neutral of the AC power line) and was able to achieve good coverage around the house. That's quite a feat for the puny 10mW that this thing puts out! Heck, that's even within legal limits for AM.
    I no longer have an oscilloscope and my multimeter only goes up to 50MHz, so it wouldn't be wise to try to hit the FM band (plus i have a car modulator i can use for that anyway), but i could aim for shortwave. Trouble is, i had given away my last "world band" radio 2 years ago! Since i was out shopping anyway, i remembered a store at the bus stop which sold cheap crap like watches, clocks and radios.
    For $7.69, i got myself a pocket radio with LCD display, world band, AND alarm clock! They even had radios with a USB/SD card MP3 player built in for $15 , but they were kinda big.
    The radio is branded "Interational". Knock-off... Surprisingly, i actually found out who makes them, it's a Chinese company called Kaide/Kchibo, and they even have a website, including PDF manuals. This radio has "KK-848" written on it as the model, but the manual that came with it (in Engrish of course) was for "KK-9704" which appears to be an earlier model with 7 SW bands, mine has 8. I even found a review of a "KK-9702" here.
    Surprisingly, it actually sounds decent on headphones, it's got some bass to it. The volume knob goes way up into overdrive, as usual for those Chinese radios. Reception is stable, but the LCD readout is .2MHz off on FM. Just like the last one i had. Looks like there's hacking to do. I also agree with that reviewer, the band indicator and tune LEDs are way too bright and just waste power. I don't want those shining in my face and eating up my battery, so i'll tone them down. But hey look, there's even a button for LCD backlighting! That's a new one... Unfortunately it's a lame little green LED in the top-left corner, which doesn't really do anything. At least they tried.
    I'll be back with pics and hacks.
    A working TV? How boring!
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Dirt cheap radio hacking!
    roflol!
    interational.
    yes pics please.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      Ask and ye shall receive. First 2 pics show its initial state - as you can see, the soldering quality is generally atrocious. Not that it's a surprise...
      The main radio IC is a clone of the TA2003. Also visible is the reason for the powerful sound - a TDA2822 in bridged mode operates as the audio amplifier. The inductor visible just under the radio IC was the one i adjusted to align the displayed frequency with the real one.
      First close-up is of the swaps for the LED series resistors. The originals were 220 ohm each - which means that on a full battery, each LED ate over 10mA! Considering that two of them are on at all times, this is quite a waste of battery. I settled for 2k2 for the red Tune and FM LEDs which resolves to just over 1mA each, and 1k for the green AM led, ~3mA, because it is dimmer than the red ones for the same current. The Tune LED did not have its series resistor close to it and i couldn't be bothered to trace it, so i cut the PCB trace and bridged across with a 2k2. This would be 2k4 series resistance for the Tune LED, but the difference in brightness from the FM one is insignificant.
      Second close-up is the coupling capacitor swap for the TDA2822 and for the speaker output. Upon closer inspection, the 2822 had a 10k resistor to ground just like in the datasheet, but the coupling cap was just 220n! This was a cutoff frequency of 72Hz which had room for improvement. More bass? Yes please. I put a 1u lytic instead, i found one small enough to fit the cramped space (the speaker magnet comes right over that area). Now the cutoff frequency is 16Hz, more than enough for FM, highpass filters in broadcast equipment are usually set to 30Hz. Now this baby packs some serious punch on headphones.
      Of course, the lowering of the cutoff frequency of the amp raised a new issue - the tiny internal speaker would get overdriven from all the bass. 2x 100uF in parallel as the coupling capacitor for the speaker took care of that - the tone remained exactly the same, while the output gets louder AND cleaner than with the speaker wired directly. I also measured about a 1/3 reduction in the current drawn by the speaker. This probably uses less power than even the stock config - the speaker is 4 ohms, so 200uF in series with that gives a cutoff frequency of 200Hz, which is more than one octave higher than the original. The original 72Hz frequency was likely chosen as a compromise between bass response on headphones and battery life on speaker.
      Then i put the thing back together, and Murphy got me. The LCD display went incomplete on me. I tried everything to no avail, it would go incomplete when the unit was assembled. Since the LCD is connected via one of those carbon/plastic ribbon things, it sure seemed like the end of it, didn't it? Well... a bit of thinking out of the box fixed it. The ribbon HAD to be stuck in place by heat, there was no other way. Here's where a thermally controlled soldering iron comes in handy. I turned the iron to low, so as not to burn thru the ribbon. Then using a wide tip i pressed on the intermittent connection for a few seconds, and hey presto, it's now making solid contact. I sure wish i hadn't thrown out that nice scientific calculator which had the very same issue.
      There are two other mods i did today, that i didn't take pics of. The headphone output was wired in a really weird way - they had a trace running near where the ground pin of the headphone jack was, so they left that unconnected and instead wired the output to the L and R pins. That way the headphones end up in series, but also out of phase, so when listening with both cans it sounded interesting to say the least. I changed the wiring to normal mono config with both channels in parallel. With that, i also get 4x the power output, as if it wasn't loud enough already. Mo' bass fo' yo' face.
      I also added a coupling capacitor from the antenna terminal to the headphone jack, because i carried it with me today and the reception sucked when on the move. We'll see tomorrow if this did any good.
      • Tube_Dude
        • Feb 2011
        • 51
        Hi, Th3_uN1Qu3
        I really appreciate your creativity. Keep up the good work!
        Cheers.
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          This is genius! Well done!
            master hoarder
            • May 2008
            • 12170
            • Bulgaria
            Th3_uN1Qu3, your threads are always full of cool stuff to read . Thanks for posting this.
            • shovenose
              Send Doge Memes
              • Aug 2010
              • 6575
              Creative and Interesting!!
              • shelby5041
                clock radio / radio lifespan?
                by shelby5041
                hi
                ive got a modern digital clock radio approx 15yrs old
                my question is how long can a clock radio or a simple radio last ss farcas operating hours?
                since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
                the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
                it uses very little power just a few watts i would imagine that may have something...
                09-14-2024, 03:30 AM
              • UserXP
                Vintage SONY Digital Clock Radio ICF-C12W no audio
                by UserXP
                Dear all,
                I have this old radio clock by Sony from the early 80s, I guess. The clock display works, but is dim, the function board appears to be OK - but the radio unit shows no signs of life. It doesn't produce a single noise, crack or anything from either FM or AM band. It's like it doesn't even power up.
                i opened the radio and it is full of some TRACON gray capacitors. They only have their negative strip printed, voltage and capacitace markings - no series, no temperature marking, nothing else.
                My question is, do you know of this brand of capacitors and how bad are...
                07-21-2025, 08:35 AM
              • praveenramavath
                Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
                by praveenramavath
                Hello All,
                I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
                https://www.hifivision.com/threads/m...-screen.98243/
                Troubleshooting Summary: Majority Internet Radio - Flash Chip
                04-26-2025, 09:08 AM
                HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point EliteDesk 800 i7-7700T Specification for Upgrade or Repair
                This specification for the HP EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point boardview and EliteDesk 800 G3 + OfficeConnect OC20 2x2 Dual Radio 802.11ac (RW) Access Point schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information....
                09-12-2024, 02:00 PM
              • Omron
                Kenwood KDC 3051G Car Radio permanently stuck in Demo Mode please help
                by Omron
                Hello Guys! I have trouble with my car radio Kenwood KDC 3051G I hope someone more knowledgeable can help me, I tried everything in my power that I stumbled upon online.
                My radio is permanently in demo mode, it says Press Volume Knot Cancel Demo and when I press it nothing happens.
                - Tried to unplug radio and plug it back in into power,
                - Tried to reset radio by holding reset button key for 5,10,30 seconds while in power and without power, plugging it back in, it wouldn't work.
                - Tried to hold 3,6 while turning it back on and then pressing 1,2...
                05-23-2024, 01:27 PM
