Panasonic Plasma 10 Blink
  • kickrz
    • Jan 2012
    Hello im new to the forum and im sure this has been asked before. I have a TH-42PD60U 8th gen panasonic plasma which just quit and is giving me the 10 blinks when i push power button. I have looked at the capacitors on the power board and they all look good. I have also checked the fuses on the board and they are also good. Has anyone else experienced this and knows what board I would have to either fix or replace? I have followed a diagram that made me test a few boards and I came up with the SC Board. Im not sure if i did it all right tho. Any help on this would be great.
    Thanks all.
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Panasonic Plasma 10 Blink
    Caps can be bad with no visible symptoms. The only sure way is to check with capacitance and ESR meter out of circuit.
    • kickrz
      • Jan 2012
      would the fuses on the board not blow before the caps would?
      • KeriJane
        Mac Enthusiast
        • Sep 2008
        • 681
        Hi kickrz
        No, caps fail without blowing fuses most of the time.
        A shorted cap might blow a fuse but that's only one way a cap can fail.
        The More You Learn The Less You Know!
        • kickrz
          • Jan 2012
          Ok Thanks Ill check it out
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            I happened several times, in the search for help from the web, to consult this very interesting forum.
            So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
            Having said that I come to the gist of my post on the forum as the title suggests.
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
          • m1ch43lzm
            by m1ch43lzm
            05-12-2025, 08:37 PM
            After all of...
            07-13-2024, 08:14 PM
          • canadaboy25
            Panasonic TC-P54VT25 No image. A or D board?
            by canadaboy25
            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
            01-17-2021, 01:06 AM
