Ungrounded TV set electrucuting me through Composite RCA cable
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Hi, I've got a TV in another room, connected to a satellite receiver, a Dreambox, and the Dreambox via toslink (optical) to a receiver... The Dreambox and the TV is not grounded but the receiver is...
    From this other room I have run a 5m RCA cable from my Dreambox second SCART connector to my computer so I can view the stuff I have on my TV in an easy way, the TV is connected to the Dreambox via SCART too...
    If I hold the RCA cable in my hand and touch my properly grounded PC's chassi I get a very unconfortable chock from it... I measured with a DMM; only 170mV but the shock is real anyway...
    So, I was not overly annoyed by this untill today, I was poking around with the DMM inside my 3com switch and managed to short it's mosfet, nothing bad happened, it's red failure led lit up so I removed power from it and now it works just fine...
    But when I held the switch in my hand, which is connected with a LAN cable to the Dreambox I got a shock when touching the cover of my PC, which at the time was turned off and not grounded... Took me a while to figure out what was happening LOL
    I.e. the floating ground in my TV or Dreambox or both was trying to level out with the ground in my switch that can find a ground through it's lancable that goes down into the basement to a much bigger 24port proplely grounded switch...
    Ack, that got real lengthy
    Anyway, can I get rid of this issue by grounding my TV? And if so where can I connect a ground cable safley inside it?
  • tiresias
    • Feb 2006
    • 489
    Re: Ungrounded TV set electrucuting me through Composite RCA cable
    It's going to be much more than 170mV if you feel a zap, I can assure you of that!
    I have the same problem with the RCA cables on our TV myself - I'll be looking into it and seeing what I can make of it. Many sockets at our place don't have ground wires... so I'll either have to route them through the house, or execute a "ghetto" solution, like I have done with my own 'workstation'.
    • Decade
      • Dec 2005
      • 37
      The tv chassie might be grounded by the coax shield, you could brake up both inner conductor and the shield and put two caps in series with the inner conductor and shield, could be worth to try? Remember some years ago when I was mounting a tv antenna, while sitting on the metal roof I was touching the coax shield that was connected to the tv-set inside the house I got hit by a pain that felt like I was stung by a wasp on my stern :
      Guess that the roof was acting like some kind of virtual ground.
      Well, luckily todays tv-sets got their psu primary side separated from the secondary side.
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        Was your DMM set for DC or AC? I wouldn't be surprised if you were getting bit by 120VAC. I know I've gotten some "tickles" while holding onto a coax connector and accidentally touching my arm to a VCR's chassis.
        PeteS in CA
        • japlytic
          • Oct 2005
          • 2086
          There is leakage (in the range of microamps) from the Y-class capacitors between Live and Neutral and the chassis in ungrounded equipment. But this amount of current is not dangerous, although it can sting.
          You should connect a wire to the chassis of a plugged-in computer to the antenna cable shield before going on the roof.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Petes, 170mV DC and ca 2.9v AC...
            But it feels like the 100VAC range, almost as bad as touching 230VAC netral to live with your fingers...
            • tiresias
              • Feb 2006
              • 489
              It may well be in the range of 70V or so, Per. If I connect certain power supplies to an unearthed socket, for example - I can notice a distinctive 'tingle' if I directly touch the casing and an earth, even with dry fingers. My multimeter in the same situation will measure virtually nothing at all on the Vdc and Vac settings, and a minimal (sub-mA range) current when shorted to earth.
              I recall having spoken last year or so to a colleague of mine in the UK, who mentioned he had once measured the voltage between such a coax cable from a TV and earth with an oscilloscope - and found a square-wave AC-like potential of about 80V.
              The 230Vac gives quite a zot! Not an experience I'd intentionally repeat. AC at such low frequency 50-60Hz is also considerably more lethal than high-frequency AC or full DC, even if the latter two were 'experienced' at a higher (within reason) current. It seems that the low-frequency AC is unusually prone to disturbing the sinoatrial node, and sending the heart into VF or some other lethal rhythm...
              (Nothing to do with your TV, just an offtopic remark)
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                tiresias; yea I know, 230VAC is supposed to be bad... I don't mind the shock it gives so much though... Had a few through my past carelessness...
                Getting zapped by 400VAC in a breaker box when you are standing in a pool of water and it is raining is NOT somthing I'd recommend though, I know that too from personal experience :P
                • tiresias
                  • Feb 2006
                  • 489
                  That's true - it doesn't always feel particularly strong - although according to most sources 50Hz AC is as lethal as a DC shock of over five times the current!
                  400Vac - between two phases I take it? That's quite a trip.
                  • Scruit
                    What is a normal composite signal range for a C64?
                    by Scruit
                    Hello all,
                    Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
                    More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
                    https://imgur.com/gallery/PpqcqPY
                    My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
                    More detail:
                    Symptoms are that that I get...
                    04-28-2022, 05:33 AM
                  • Patch2
                    Cable Repair
                    by Patch2
                    I have a broken connector (believe it's a 6 pin mini-DIN) on a cable. The metal shroud and all but one of the pins are separated from the cable, and just stuck together for the photo. The other end is an unknown rectangular connector. The cable is for the foot pedals on an Italian made electronic piano, and the company is out of business. Looking for ideas on how to fix it. I have a soldering iron, but I'm not very skilled at soldering, so getting a retrofit for the broken end may be beyond my ability. The other end would be easier to replace, if I could get a mini-DIN cable with the same number...
                    01-02-2025, 06:04 PM
                  • Tr0ll
                    by Tr0ll
                    Original T-con:
                    First replacement T-con:
                    10-07-2023, 07:48 PM
                  • conghuyms
                    I need datasheet cable eDP LCD 30 pin slim pls help me!
                    by conghuyms
                    My 30-pin eDP cable from the mainboard to the LCD screen got cut and damaged at the screen connector side. I found another cable and took the screen-side connector from it, but the wire colors are different. So I really need the wiring diagram for both ends of the eDP cable to solder it back properly. If anyone has the diagram, please kindly help me out. Thanks a lot...
                    08-22-2025, 11:16 AM
                  • fweonea
                    HP-Pavilion x360 Laptop Dead After USB-C Cable Connection
                    by fweonea
                    While at university, I connected my HP-Pavilion x360 14-dw0156ng laptop, running Windows 10, to a monitor using a provided USB-C cable. Immediately after this, my laptop's screen turned black and the device stopped working entirely. There are no signs of life such as fan noise or LED indicators, holding the power button does nothing. I've previously used this same monitor model and cable without issues, the cable typically charges the laptop as well.
                    I've attempted holding the power button for over 30 seconds, removing and reinserting the battery, and trying to power it on with only the...
                    01-16-2024, 11:35 AM
