Hi, I've got a TV in another room, connected to a satellite receiver, a Dreambox, and the Dreambox via toslink (optical) to a receiver... The Dreambox and the TV is not grounded but the receiver is...
From this other room I have run a 5m RCA cable from my Dreambox second SCART connector to my computer so I can view the stuff I have on my TV in an easy way, the TV is connected to the Dreambox via SCART too...
If I hold the RCA cable in my hand and touch my properly grounded PC's chassi I get a very unconfortable chock from it... I measured with a DMM; only 170mV but the shock is real anyway...
So, I was not overly annoyed by this untill today, I was poking around with the DMM inside my 3com switch and managed to short it's mosfet, nothing bad happened, it's red failure led lit up so I removed power from it and now it works just fine...
But when I held the switch in my hand, which is connected with a LAN cable to the Dreambox I got a shock when touching the cover of my PC, which at the time was turned off and not grounded... Took me a while to figure out what was happening LOL
I.e. the floating ground in my TV or Dreambox or both was trying to level out with the ground in my switch that can find a ground through it's lancable that goes down into the basement to a much bigger 24port proplely grounded switch...
Ack, that got real lengthy
Anyway, can I get rid of this issue by grounding my TV? And if so where can I connect a ground cable safley inside it?
