noisy power from Viewsonic LCD screen 12V SMPS
  • bestsystem
    • May 2011
    • 59
    is there anyway to condition the output current from a Viewsonic LCD screen 12V SMPS??
    Can i pass the current through an array of (low esr+ polyesters) capacitors to filter some noise away?
    exactly this one
    Re: noisy power from Viewsonic LCD screen 12V SMPS
    Probably a loose coil vibrating due to magnetorestriction. The coil needs to be glued.
    The trouble with these supplies is that they are welded shut. You can break them open but after repairing them you're going to need a lot of glue to stick them shut.
    A new supply can be found for less than $10, though...
    • bestsystem
      • May 2011
      • 59
      not the sonic noise, actually I mean ripple current
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        Why do you think it's noise from the brick?
        You can get junk on the screen by using video cables without a Ferrite.
        See pic.
        Mann-Made Global Warming.
        - Dr Seuss
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          He didn't say if he actually uses the supply for the monitor... maybe he's trying to power something else with it.
          A working TV? How boring!
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            That's right.
            He didn't say - either way.
            - Dr Seuss
            • filesponge
              • Jan 2011
              • 15
              • England
              Hi. I'm not sure of the actual problem you're having on this one on this one, but i'm assuming that by saying you want to remove noise from the display itself? Possibly a very slight blurring or shimmering of the picture ?
              If that's the case, it's possible that the fault is on the actual board at the rear of the screen, and no amount of other changes will affect it
              As a wild stab in the dark, i'd say . . . .
              Check the screens menu, and see if you can alter its phase settings from in there,
              or try a different PSU (i guess thats already been tried?),
              or, have a look at the back of the screen on its board, reseat all the connections.
              I've had a few older screens where they are even adjustable inside by a tiny pot, though i've not seen such a thing for a while on the bigger sizes now like 19 and above.
              With things like this, i usually just throw another screen in and see if it's doing the same. Any screen will do, though the picture may be off to the side, and if you use a widescreen for testing you'l only get a square picture instead, but all normal screens below 22 inch are interchangeable as long as the connections match (from what i've seen in the UK anyway).
              • bestsystem
                • May 2011
                • 59
                I am using it for a 25W speaker amp.
                Read it first: I know all auidio guys will say use a toridal transformer instead. but there are 3 reasons for me to use smps.
                1. very convient, light weight
                2. efficient, low temperature.
                3. The most important point is I have achieved a very good result without a tiny trace of noise and hum before, using another 12 V SMPS. (1'm sure it's a smps)
                (borrowed from a router with longer 12V plug so that I have to put it back after a few weeks.)
                The only changed variable is the SMPS, so it cant be other things but the purity of 12V DC
                • Toasty
                  • Jul 2007
                  • 4171
                  Crack or cut it open along the seam and re-cap it. Probably all it needs.
                  veritas odium parit
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    and some good supply bypass caps at the amp.
                    i see lots of these bricks die of bad caps.esp the ones on sanyo sets.
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • smic717394
                      by smic717394
                      07-25-2024, 10:16 AM
                    • Chrissygizmo
                      by Chrissygizmo
                      02-10-2025, 12:33 AM
                    • spice_disc
                      Vizio TV M50-C1 reboot cycle and static on screen
                      by spice_disc
                      I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                      The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                      09-08-2024, 02:37 PM
                    • ipatch
                      ipad pro 9.7" blew a SMD component while replacing the screen 🤦‍♂️
                      by ipatch
                      i have an ipad pro 9.7" (1st gen) A1674 where i replaced the screen, but never attached the screen to the frame/chassis (glued down) due to the ipad being previously dropped so the new screen would never fit in the frame properly. so i need flex/bend the chassis to eventually fix the new screen in properly. so i temporarily just applied blue tape around the edges of the screen to keep it in place. when watching videos with the ipad the screen started flicker, so i though maybe the new quasi cheap amz screen i purchased was going out. so i disconnected then reconnected with power still on,...
                      08-24-2024, 02:36 PM
