LED lamps a bit lit when switched off
  • Derek23
    • Apr 2008
    • 33
    We replaced the old halogen lamps with LED ones supplied with line voltage (230V), older ones had a 230 to 12V transformer, and when they are switched off they are still lit although very dim, also I have replaced a incandescent bulb with a CFL in my room and when switched off it blinks a bit each second during an hour then stops, this happens in all the rooms they are installed with different switches, anyone knows why? I don't understand how current can flow with the switches off.
    Many thanks
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: LED lamps a bit lit when switched off
    CFLs do the flashing thing due to the capacitor inside.
    As for your led light replacements all I can think of is induced current in the wires.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • ipman
      • Jul 2011
      • 159
      You should check the electrical wiring.
      Your switch is interrupting neutral, not live as it should be.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        photoswitches,x10,other remote switches do this since they draw a bit of power through the load.
        • Derek23
          • Apr 2008
          • 33
          Many thanks , then I'll make sure the switch cuts the live!
          • fabrizziop
            • Jul 2011
            Does your switch has a little pilot light that is on when the lamp is off?. If yes, that's the problem.
            • Gordon01
              • Aug 2011
              • 33
              • Russia
              It doesn't matters.
              Yes! Even small current thru LED is enough to charge CFL's cap.
              Probable the same problem with LED lamps.
              The switch must be real mechanical naked switch: without pilot LEDs or something
              • Derek23
                • Apr 2008
                • 33
                No, it's a normal switch (well those who you can control the lamps with 2 switches I don't remember the name currently).
                Originally posted by Gordon01
                It doesn't matters.
                Then does this have a fix? It's annoying and maybe bad for the lamps
                • delaware74b
                  • Apr 2009
                  • 628
                  Derek - the switches are called 3-way (for having 3 current-carrying terminals). These switches can be a problem due to being able to bleed voltage. I've run into similar situations you're describing caused by the bleed. I use a non-contact voltage tester regularly in my line of work as an electrician. The problem is the tester is sensitive enough to pick up as low as 40 volts. The bleed level normally seen on a 3-way switch setup is around 50 volts.
                  With that said, carefully take a voltage reading with the switches 'off' and I'm willing to bet you're having issues with bleed or induced voltage.
                  Stupidity should be a crime, especially for drivers. I have NO patience for them.
                  • Derek23
                    • Apr 2008
                    • 33
                    Many thanks Delaware
                    You're correct, there is ~35V in my case, and it fluctuates a bit!
                    • ktmmotocross
                      GB RTX2080 Super - crash on load > second switched 12V instability > what is purpose of this circuit?
                      by ktmmotocross
                      Hello.
                      Have this GB 2080 Super that crash on load. When half load i see instability on one of two switched 12V rails. I dont know its purpose and dont have BV or Schema for this board.
                      Can anybody explain me what is purpose of this two switched 12V lines?...
                      10-03-2024, 12:22 AM
                    • DeanWy
                      WD Sentinel DS5100 (NAS) boot issues
                      by DeanWy
                      I have a Western Digital Sentinel DS5100 NAS system which has stopped working. It has dual BIOS. I bought the system second hand with an already broken primary BIOS (it rebooted multiple times until second BIOS was used).
                      It worked until recently. The system was idle in Windows Server 2012 and a BSOD occurred, I think it was 'critical process died'. Thereafter it didn't boot, it just sat there with no video output and fan speed at 100% (there's a proprietary Windows driver by WD which controls the fan, outside of that it always runs at 100%).
                      There...
                      07-30-2024, 04:13 AM
                    • _max_
                      Hisense H60N5705 automatically switches off
                      by _max_
                      Hisense H60N5705 installed in a conference room, turns off automatically a few minutes after being switched on.
                      Problem occurred suddenly, during a video conference. Switched on again by the remote control, it continued to work for a while and then switched off again.
                      Power cable and HDMI cable checked.
                      No changes by connecting the TV to another source but, even if it is left on the OSD menu, it stays on for a few minutes and then switches off.
                      So they took the TV (a 60' which is not easy to handle) to the lab and asked me to check it.
                      03-07-2025, 06:14 AM
                    • MrCreosote
                      2 Belkin KVM switches have dim VGA output
                      by MrCreosote
                      When compared to a direct VGA connection, these 2 switches both output a darker image. The switches are:
                      4-port Omniview Pro2 f1dz104t
                      8-port Omniview either f1da108t OR f1dz108t (look and function same, OSD may be only difference.)
                      The 4 is dimmer, the 8 is massively dimmer - both with same AC adapter and cabling.
                      AD ADAPTER:
                      There were issues with previous AC adapter, it failed during lightning strike that blew up TV and other stuff and tripped a 15 amp breaker in the main panel which also had a whole house Cutler Hammer surge...
                      08-15-2023, 08:26 PM
                    • FALKLAN
                      Running Line Voltage and Integrating LED Pods - Automotive
                      by FALKLAN
                      Howdy everyone! I hope all is well where ever you are!
                      I'm attempting to integrate a couple of LED pods into an automotive reverse lamp circuit. The problem being, while the vehicle is running there is a 8.5v current present on the reverse lamp power wire. Needless to say is that all LED pods and lights dimly illuminate while the 8.5v is present, so the LEDs are always powered on while the vehicle is running. When the vehicle is shifted into reverse, the voltage changes to 12 volts.
                      I am uncertain how to convert this line into a switched 12v output line for the LED pods....
                      02-05-2025, 12:30 AM
