Hisense H60N5705 automatically switches off
  • _max_
    • Dec 2012
    • 46
    • Italy
    Hisense H60N5705 installed in a conference room, turns off automatically a few minutes after being switched on.
    Problem occurred suddenly, during a video conference. Switched on again by the remote control, it continued to work for a while and then switched off again.
    Power cable and HDMI cable checked.
    No changes by connecting the TV to another source but, even if it is left on the OSD menu, it stays on for a few minutes and then switches off.
    So they took the TV (a 60' which is not easy to handle) to the lab and asked me to check it.
    I still have to open it up, but I don't have the schematic diagrams and should proceed by trial and error, although I imagine a problem with the power supply stage.
    How do you suggest I proceed, since I don't do TV but RF ?
    Thank you for any help,
  • Diah
    • Feb 2013
    • 6647
    1- be sure at the menu setting. automatic switch off are disabled.
    2- reduce the LED BL level setting below 30% and check if it remain on longer
    3- if 1 and 2 didn't bring change then check after connection cable reseated, joint solder crack at PSU
    • _max_
      • Dec 2012
      • 46
      • Italy
      Thank you Diah for your reply!
      Yes, this is disabled. As wrote, the issue appeared suddenly during a video conference. Never happened before and nobody changed TV settings.
      Ok, I will try this.
      I guess I have to open it, even if I have no schematic diagrams...
      • _max_
        • Dec 2012
        • 46
        • Italy
        Is there any place where I can find the circuit diagram of such TV ?
        • EazyBone
          • Jun 2023
          • 1364
          • United states
          They aren't really offered to often anymore.
          Did you check the backlight to see if it was good? Led tester?
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Try resoldering the PSU.
            • _max_
              • Dec 2012
              • 46
              • Italy
              Ok, thanks for your hints. I will try soon
              • _max_
                • Dec 2012
                • 46
                • Italy
                I did not found any broker CAP in the power supply stage, nor burnt or open component:
                board
                In the CPU SMD board I did not found signs of hot parts:
                With the TV is switched on, temperature of single components are in the range of 35-40 °C, only the radiator shield is close to 46 °C.
                When the TV switches OFF, there is no noise or sparks visible.
                I would proceed by replacing ALL the electrolitic caps in the PSU unit.
                What do you think?
                • EazyBone
                  • Jun 2023
                  • 1364
                  • United states
                  I think that's a waste of time and money.
                  Recheck the cracked solder joints as diah said. Test the Backlights with led tester if you have. Tvs will shut off when bl's fail. Google especially shuts down, Roku tends to keep going.
                  • lotas
                    • Jan 2016
                    • 4969
                    • Russia
                    If the TV constantly goes into reboot or standby mode:
                    Disconnect the TV power supply and supply +12V from the power supply to the motherboard. Check the power-on.
                    If the motherboard stops rebooting or turning off (you can see it by the LED indication), then you have problems with the backlight.​
                    • Andrew F. Ali
                      • Jan 2014
                      • 2450
                      • Trinidad & Tobago
                      Resolder the PSU especially the bigger joints even if the look OK. Start with the Transformer legs and Main Cap legs.
                      • _max_
                        • Dec 2012
                        • 46
                        • Italy
                        It does not go in STBY "constantly" but "sporadically".
                        Difficult to supply 12V directly to the mobo, but I can try.
                        • _max_
                          • Dec 2012
                          • 46
                          • Italy
                          Yes, good idea.
                          • Storyteller12
                            • Jun 2020
                            • 625
                            Check backlights as everyone stated. If that checks out these Hisense with android are known to have a high rate of emmc failures
                            • nomoresonys
                              • 12335
                              • U.S.
                              Try to do tests and report results. Now what was the result of the tests in post #2??, you gave no result for #2, reducing backlight level. Even if you do the test and there is no difference report it, everything helps to narrow the problem down.
                              • _max_
                                • Dec 2012
                                • 46
                                • Italy
                                In response to POST #2, there is no point in adjusting the brightness levels and there is no point in reloading the factory settings either.
                                I don't have any specific tool to test the panel because, as already explained, I don't do TV repairs for a living.
                                How can I ‘check' the functionality of the panel or emmc failures?
                                • nomoresonys
                                  • 12335
                                  • U.S.
                                  NO that is not correct, what IS correct is there IS NO point in trying to help some people, bye bye and welcome to my ignore list.
                                  • Storyteller12
                                    • Jun 2020
                                    • 625
                                    Exactly, can’t ask for help and then tell us there’s no point in doing things we mentioned. There’s no point in helping if you can’t follow simple directions.
                                    • nomoresonys
                                      • 12335
                                      • U.S.
                                      +1000
                                      • CapLeaker
                                        Leaking Member
                                        • Dec 2014
                                        • 8354
                                        Gets my vote too.
                                        • tomketcz
                                          schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ
                                          by tomketcz
                                          Does anybody have schematic power board RSAG7.820.9713 from HISENSE TV Hisense 55E76GQ ??
                                          10-01-2025, 03:13 AM
                                        • Coolgoodman
                                          Faulty Hisense 85Q6NAU TV
                                          by Coolgoodman
                                          85” Hisense TV
                                          Greetings,
                                          Request for Technical Assessment – Faulty Hisense 85Q6NAU TV
                                          Dear TV technicians of forum, I hope this message finds you well.
                                          I am writing to seek assistance regarding my 85-inch Hisense Smart TV, model 85Q6NAU, which is currently experiencing a fault. The unit is approximately two years old, and I am not sure if it has a warranty.
                                          I have attached a photo showing the issue for your reference. I would appreciate it if your experienced technician could kindly review the image and provide some insight...
                                          07-24-2025, 03:02 AM
                                        • ShahZaib Ghumman
                                          Can I Swap Screens Between Two Hisense 75” QLED TVs?
                                          by ShahZaib Ghumman
                                          Hey folks,
                                          I'm not a professional, but I do have a decent amount of knowledge when it comes to electronic repairs.
                                          A friend of mine recently bought a brand new Hisense 75” 4K QLED Smart TV (75E7NQTUK) but unfortunately, he cracked the screen just a few days later. Luckily, he had insurance and got a replacement right away but weirdly enough, the insurance company never asked for the broken unit back.
                                          So, I took it off his hands and figured I'd try to repair it myself rather than see it go to waste. I've been searching for a replacement screen but can't...
                                          03-25-2025, 10:59 PM
                                        • nono34
                                          Hisense stuck in Colors cycle like test pattern.
                                          by nono34
                                          I accidentally changed the project ID in the service menu of my Vidaa Hisense 100U7KQ TV. When I turn on the TV, the screen displays an RGB color cycle (test mode???). I contacted Hisense, and they sent me a usb_MTK_9618.EU.bin file, but it doesn't work. I can see that the USB drive is being read, and it flashes for about 10 minutes (the screen remains in the color cycle during the firmware reading), then the TV turns off and restarts, but still in the color cycle mode.
                                          I want to mention that the 4GB USB is formatted in FAT32 MBR. I've also renamed the file to...
                                          10-24-2024, 04:31 PM
                                        • frannyjunk
                                          Hisense 40H4F no backlight but turns off after splash screen
                                          by frannyjunk
                                          So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                                          TIA.
                                          09-24-2025, 10:59 AM
