Help me identify this BMS component
  • braxton
    • Nov 2009
    • 146
    Hi
    I have 4 ego 56v power tool batteries where the BMS battery management board is dead. I believe I have narrowed down the problem on all 4 to a transformer coil on the board. There are no markings whatsoever on this coil. How would I go about trying to identify it? Thanks.
    I'm attaching a couple of photos for starters. The first shows the entire board with the component in question (silver square 6pin device next to caps).
    The second photo shows the board with the transformer coil removed.
    Any help is greatly appreciated.
    • Jul 2011
    • 6065
    Re: Help me identify this BMS component
    What do the two connectors connect to I amuse that one hooks to the battery cells but where do the other one hooks up to ( unless the other connector has some battery cells on that one as well and also has temperature sensors on this connector as well )
    Please show us a picture of the battery pack cells as well with the connector
    • braxton
      • Nov 2009
      • 146
      The two top connectors attach to the 14 cell packs (individual cell monitoring) plus wiring for two thermistors.
      The bottom connector attaches to the battery contacts (negative and positive leads plus T terminal plus D terminal.
      The coil in question is involved in the circuitry that drops 56v to lower voltages to drive the BMS (12v, 3.3V etc).
      I can also attach another image of an older version of this BMS, which has more labels on the board.
      • braxton
        • Nov 2009
        • 146
        Here is an image of an older version of the BMS board with more labels:
        • braxton
          • Nov 2009
          • 146
          I took a chance and ordered this coil from digikey:
          https://www.digikey.ca/en/products/d...0926NL/2265652
          It looked similar and dimensions were correct. It had a slightly different pin out, but long story short, it did not work in this application.
          • R_J
            • 9588
            What was wrong with the original transformer? it is unlikely it was bad unless it was physically damaged.
            • braxton
              • Nov 2009
              • 146
              For some reason this coil component is a common failure, especially in the newest ego batteries with the fuel gauge. One of the 3 coils tends to short or open up.
              In my case, the 3 coils do not appear to be shorted or open, but resistance values differ slightly from working coils.
              If I install a coil removed from a working BMS, it restores functionality.
              • R_J
                • 9588
                Ok good to know, If it is a common problem maybe some one has a source for them.
                • petehall347
                  • Jan 2015
                  • 4439
                  • United Kingdom
                  bms transformer by the looks of it .
                  see if you can match it .. https://www.digikey.bg/en/product-hi...t-transformers
                  • braxton
                    • Nov 2009
                    • 146
                    Lots seem to be looking but I can't find any sites that mention that someone has found anything yet. It might be a proprietary part made just for EGO bms??
                    • braxton
                      • Nov 2009
                      • 146
                      Thanks. I'm not enough of an expert to know what to look for.
                      Based on my second photo in the 1st post, I can see that pin 1 (bottom left) has a coil connecting to pin 2 next to it. Pin 3 has a coil connecting to pin 4 across from it. Pin 5 has a coil connecting to pin 6 (top left and middle pins).
                      I'm not sure how to interpret coil schematics in the datasheets to find a similar profile.Closest I could find was the pulse electronics device i linked to above, but it didn't work...
                      • petehall347
                        • Jan 2015
                        • 4439
                        • United Kingdom
                        measure the inductances of a good one . a schematic would help but i know with these things its not going to be available .
                        makes me wonder why they are failing .
                        • R_J
                          • 9588
                          How did you try this replacement transformer? did you add wires to its pins so you could connect it correctly to the board or just soldered it in place.
                          • braxton
                            • Nov 2009
                            • 146
                            I added wires to its pins so that it would connect properly to the pads on the boards, as its pinout was different. Pins 3-4 were correct but the others needed to be criss-crossed.
                            • braxton
                              • Nov 2009
                              • 146
                              I unfortunately don't have any equipment to measure inductance
                              • petehall347
                                • Jan 2015
                                • 4439
                                • United Kingdom
                                my multimeter has it .am sure these days there are affordable things that can do this , on another note all i found with similar bms was bad thermistors . i dont see one on your board . must be connected through the plugs .
                                • braxton
                                  • Nov 2009
                                  • 146
                                  Using my 9V generic electrical component tester, the 3 coils test as resistors (in circuit and bms powered down; in a working bms). Pins 1 and 2 are 8.2 ohms, pins 3 and 4 are 6.8 ohms and pins 5-6 are 5.4 ohms. I did not do any further testing at this time as these batteries are very expensive and i don't want to risk breaking a working BMS.
                                  Do they need to be tested out of circuit?
                                  My tool can measure inductance as I tried other choke coils and the transformer coil part i ordered from digikey and they tested as inductors (with an ohm reading and mH reading; out of circuit).
                                  • braxton
                                    • Nov 2009
                                    • 146
                                    I noticed that, on the BMS board, the 3 coil symbols each has a (-) designation at one end, which would seem to indicate a polarity. How does this factor into identifying a suitable replacement part and installing that part?
                                    • braxton
                                      • Nov 2009
                                      • 146
                                      I guess a more general question is:
                                      What is this transformer exactly doing in this configuration? What is it’s purpose in this BMS?
                                      In a working BMS, the low voltage circuit turns on when the battery gauge button is pressed, or when the battery is used in a tool or charged on the charger. When this circuit is activated, pin 1 of the transformer (bottom left in first photo) reads approx 55v, pin 2 reads approx 54v, pin 5 reads approx 3-5v and pin 6 approximately 3-5v. Pins 3-4 measure in the mVs.
                                      • spidertnt
                                        • Jul 2016
                                        • 34
                                        I have 2 of these gen 3 also dead no power at all....probably transformer .
                                        This is supposed to work with modification. https://www.digikey.ca/en/products/d...0926NL/2265652
                                        https://www.youtube.com/watch?v=Jz0GN0m0zKA
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • thesame
                                          DVR HIKVISION DS-7208HWI-E1/A BOARD DS-80104 REV 2.2 help identify burnt components
                                          by thesame
                                          Hy guys , i have a DVR board DS-80104 REV 2.2 that was powered wrong, i have some smds on the board that are blown and i can't identify them , maybe if someone has this board somehow and we can identify the smds', i have searched online and i can't find a schematic.
                                          The smds are SOT-23-6 , one of them i think it has the marking ADJF since i found another one on the board with this marking , but the other one it seems that it starts with AG or it looks like. I would really apreciate if someone could help me identify those IC's .
                                          02-27-2024, 04:31 AM
                                        • k-krzych
                                          Identify board to board connector
                                          by k-krzych
                                          Hello, can you help me with an id of this board to board connector, or the the tiny silicon flat wires for replacement? It is found on GPS unit and connects main board with pushbotton small board....
                                          07-08-2025, 12:32 PM
