Help sourcing an IC number is MT3058
  • gurj1979
    • 186
    Hi guys.
    I need to source an IC made by M3Tek (I believe its part of MetiaTek), IC number is MT3058.
    It's a step-down converter for a Ubiquiti U6-LR.
    There is literally zero info on the internet about this, nor any datasheets.
    Probably an NDA has been signed.
    Or if any of you know if a pin-to-pin direct compatible IC.
    Thanks.
  • petehall347
    • Jan 2015
    • 4430
    • United Kingdom
    Re: Help sourcing an IC
    3A, 5V, 1MHz Synchronous Step-Down DC/DC Converter;M3Tek;MT3058;;1;
    try here ...
    https://www.m3tekic.com/index_en.php?action=product
    • gurj1979
      • 186
      Yes that's the ONLY info I found online too
      But nothing else online.
      Nobody sells it. And no substitute pin for pin.
      • petehall347
        • Jan 2015
        • 4430
        • United Kingdom
        well its a datasheet so try using filters on your favourite component sellers parts list .
        • gurj1979
          • 186
          Sorry my bad. I didn't even notice the weblink before.
          Thanks for that. I'll see if I can figure something out
          • truclacicr
            • Apr 2019
            • 331
            • australia
            https://web.archive.org/web/20161029...1005143643.pdf
            • R_J
              • 9579
              Thank you truclacicr, I will post it here in case the link dies
              • gurj1979
                • 186
                Re: Help sourcing an IC number is MT3058
                Thanks guys.
                Datasheet has no pinouts.
                I'll see what I can do.
                • petehall347
                  • Jan 2015
                  • 4430
                  • United Kingdom
                  pinouts are there on page 2 of datasheet
                  • gurj1979
                    • 186
                    Unless I'm going blind, there's only 1 page to the PDF.
                    • petehall347
                      • Jan 2015
                      • 4430
                      • United Kingdom
                      page 2
                      • gurj1979
                        • 186
                        That doesn't match the actual item pinout. See picture I have attached.
                        • petehall347
                          • Jan 2015
                          • 4430
                          • United Kingdom
                          shit sorry my eyes saw 3058 but its 3035 i downloaded .
                          • gurj1979
                            • 186
                            haha no worries.
                            I appreciate all the help.
                            • gurj1979
                              • 186
                              Looking at the footprint, voltage, amps, MHz etc, the next best thing I found is this. But I doubt the pin functionality is a match. Make or break LOL.
                              RT8058
                              https://cdn.badcaps-static.com/pdfs/...da256f890a.pdf
                              What you reckon guys ?
                              • R_J
                                • 9579
                                There is a MT3125 which might be similar, it is a qfn 3x3 16 pin the only other similar one they list is a MT3123 but has no pinout.
                                • gurj1979
                                  • 186
                                  Originally posted by R_J
                                  There is a MT3123 which might be similar, it is a qfn 3x3 16 pin
                                  Thanks. It the footprint pins is different than what's on the PCB.
                                  • vinicius.vbf
                                    • Apr 2022
                                    • 3
                                    • Brazil
                                    Hi guys.
                                    Thanks.
                                    Hello! Did you ever find this chip? Thanks!
                                    • vinicius.vbf
                                      • Apr 2022
                                      • 3
                                      • Brazil
                                      RT8058
                                      Looking at the pad connections, this actually looks like a compatible one. Very nice find. I'll try it and let you guys know. Thanks!!
                                      • gurj1979
                                        • 186
                                        Sorry for delayed reply.
                                        I gave up looking. LOL.
                                        • sikocan
                                          Lenovo X1 Carbon 9th Gen Black Screen
                                          by sikocan
                                          I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
                                          SN: PF3G1REP
                                          MODEL: 20KW-00J1AU
                                          PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
                                          Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
                                          06-24-2025, 09:01 PM
                                        • Devonavar
                                          Vizio M43-C1 - How closely do I need to match the mainboard number?
                                          by Devonavar
                                          I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
                                          I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
                                          Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
                                          So, I've ruled out the PSU for now.
                                          The reboot loop...
                                          08-14-2022, 08:46 PM
                                        • matyx
                                          My macbook pro a1708 is under MDM and DEP and i wanted to change the serial number and Main Logic Board number
                                          by matyx
                                          i dont know what im doing I have CH341A programmer and SPI programming cable from chipsetpro.com the curent serial number is FVFWQ1CJHV2F and the MLB number i dont know and the motherboard id is 820-00840-A
                                          Can somebody please help.
                                          I dont know how to uplode the .bin file
                                          02-20-2025, 02:26 PM
                                        • esinior
                                          Smd code to part number
                                          by esinior
                                          Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
                                          I've attached pics of this part
                                          Thanks...
                                          08-20-2024, 02:50 AM
                                        • Friend33
                                          Updating Serial Number on EliteBook x360 1030 G3
                                          by Friend33
                                          I have an EliteBook x360 1030 G3 and after a motherboard replacement, I want to change the serial number and the FeatureByte. None of the known methods work. MPM is locked and cannot be unlocked via EFI.
                                          Therefore, I read out the two chips and adjusted the serial number, FeatureByte, and Born Date using a hex editor. Now the system won't start anymore. I think I did something wrong with the FeatureByte, as there was a message indicating that the file size was changing.
                                          My serial number is: 5CD849BL7Q
                                          FeatureByte:
                                          3X476J6S6b7B7H7M7R7W7maBaEapaqauawbVbhcAd6dUdpdq
                                          06-20-2024, 03:55 PM
