Help sourcing an IC number is MT3058
  • vinicius.vbf
    • Apr 2022
    • Brazil
    GUYS!! RT8058 really worked!! I brought my device back from the dead!!
    The LEDs aren't working, but that's another component damaged by liquid (I currently belive it's a logical level translator).
    THANK YOU SO MUCH for finding this replacement, gurj1979!! INCREDIBLE find! If you have the time, could you please teach me how did you get to this RT8058?
    The device is working for a few hours now. I'll let you know if anyhting else happens to it.
    I'll try to source the logic level converter now. Thanks!
    • truclacicr
      • Apr 2019
      • 297
      • australia
      That's interesting news! I tried to cross-reference other MT part numbers to RT numbers, but without success.
      • gurj1979
        • Dec 2014
        • 186
        Hi. Good one. Glad it's working for you. Now people don't have to rely on MT3058.
        It's been a while for me, so I don't remember how I managed to find the cross reference RT8058.
        • sikocan
          Lenovo X1 Carbon 9th Gen Black Screen
          by sikocan
          I believe Chip 2 is BIN is the main one as it contained the Windows product key, marked with XXXXX for now.
          SN: PF3G1REP
          MODEL: 20KW-00J1AU
          PROBLEM: Turns on blank screen, charging circuitry motherboard looks good. I have tried another firmware here - but resulted in 5V will not go to 20v due to different PD firmware I believe - using the current firmware it does go to 20V.
          Requesting a firmware clean/BIOS region cleaned. Here is output from ME Analyzer:
          06-24-2025, 09:01 PM
        • Devonavar
          Vizio M43-C1 - How closely do I need to match the mainboard number?
          by Devonavar
          I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
          I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
          Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
          So, I've ruled out the PSU for now.
          The reboot loop...
          08-14-2022, 08:46 PM
        • matyx
          My macbook pro a1708 is under MDM and DEP and i wanted to change the serial number and Main Logic Board number
          by matyx
          i dont know what im doing I have CH341A programmer and SPI programming cable from chipsetpro.com the curent serial number is FVFWQ1CJHV2F and the MLB number i dont know and the motherboard id is 820-00840-A
          Can somebody please help.
          I dont know how to uplode the .bin file
          02-20-2025, 02:26 PM
        • esinior
          Smd code to part number
          by esinior
          Hi i have a smd part with probably mark "QO 11" or "Q0(zero) 11" on it, and its package is SOT89, i doubt its KTB1260 PNP transistor, but in measuring with diode mode of multimeter it shows number 1.4 between emitter and collector pins and its not open circuit, and .59 from collector to base and .8 from emitter to base , and these numbers doesn't match a pnp transistor, i couldn't find any part number and datasheet for it, does anybody have information for that part number?
          I've attached pics of this part
          Thanks...
          08-20-2024, 02:50 AM
        • Friend33
          Updating Serial Number on EliteBook x360 1030 G3
          by Friend33
          I have an EliteBook x360 1030 G3 and after a motherboard replacement, I want to change the serial number and the FeatureByte. None of the known methods work. MPM is locked and cannot be unlocked via EFI.
          Therefore, I read out the two chips and adjusted the serial number, FeatureByte, and Born Date using a hex editor. Now the system won't start anymore. I think I did something wrong with the FeatureByte, as there was a message indicating that the file size was changing.
          My serial number is: 5CD849BL7Q
          FeatureByte:
          3X476J6S6b7B7H7M7R7W7maBaEapaqauawbVbhcAd6dUdpdq
          06-20-2024, 03:55 PM
