Short Circuit tester
  • Tarot Superstars
    • Aug 2023
    • 60
    • United Kingdom
    Hello.
    I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
    The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
    Link
    The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
    https://www.youtube.com/watch?v=0eixDdCpiO4
    My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor in series with one of the probes the meter now shows the difference. I think it's about 1/1000 th of an ohm or more.
    I don't have the meter or the circuit for the 1st design so I can't tell you the exact values. So, then I see the very small differences between the resistance to each component on a circuit.
    My question is, is my method good enough?
    Do I need to add the batteries as was in the first design and the voltage regulator component (I think it was a LM317)?
    Any advice is appreciated.
    • 31117
    Re: Short Circuit tester
    if your putting more than 1 or 2 volts into the board your risking damaging some components
    • hcs77
      • Mar 2017
      • 4
      • Hungary
      Many RAM, ROM, SOC, etc ic datasheets contains an absolute maximum ratings for voltage, for 5V SRAM is VCC+0.3V. This is a theoretical upper limit.
      If you want to find internal connection in the pcb (eg. reverse engineering), a simple way to connect 2 schottky diodes antiparallel to the multimeter probe. This will limit the multimeter output voltage to a safe level, 0,2-0,3V. You can use silicon diodes like 1n4001, but it gives a bit higher voltage.
      • Tarot Superstars
        • Aug 2023
        • 60
        • United Kingdom
        Originally posted by Tarot Superstars
        Hello.
        Link
        I quoted the voltage incorrectly. It's 3 x 1.5 V batteries in series.
          • 31117
          that's still too much for modern 3.3 or 1.8v parts
          the multimeter already outputs 2-3v
          • RetroComputingGrotto
            • Aug 2023
            • 92
            • United Kingdom
            3*9V batteries could be 27V which is far too high! In the video you linked to, Learn Electronics Repairs uses 3*1.5V giving a max of 4.5V.
            Don't modern CPUs run at 1V so even 4.5V probed in the wrong place could zap a CPU?
              • 31117
              1.8v is common, but yes - some stuff like cpu/gpu cores are even less
