OMRON E5CS heater controller Diode identification help
  • lethbrp
    • Apr 2023
    • 15
    • United Kingdom
    I have a diode that I need help identifying. I've been scouring the web (newbie) can can't seem to find anything. Perhaps I'm looking in the wrong place. Attached is an image of the diode. If you could help me it would be greatly appreciated. Also, an explanation of how to calculate the values would be great.
    Thanks for your help.
    Peter
    Last edited by SMDFlea; 08-12-2023, 04:57 PM. Reason: OMRON E5CS heater controller
  • petehall347
    • Jan 2015
    • 4422
    • United Kingdom
    Re: Diode identification help
    any markings on the other side ?
    • lethbrp
      • Apr 2023
      • 15
      • United Kingdom
      Unfortunately not. Just a violet band.
        • 20300
        What PCB has it come from,any model numbers ,is a schematic available .
        • lethbrp
          • Apr 2023
          • 15
          • United Kingdom
          It's comes from a OMRON E5CS heater controller. I haven't been successful in finding any schematics I'm afraid.
            • 30917
            does the board have markings where it was?
            actually, show us the whole board - it may give a clue
            • lethbrp
              • Apr 2023
              • 15
              • United Kingdom
              Re: OMRON E5CS heater controller Diode identification help
              Attached are some images of the board. This is this is the power board that converts the AC into various DC voltages for the logic board.
              Running a did from a good board through a component analyser, it says it's a Diode Junction with a forward voltage of 0.672v at 5v. So I'm guessing that it's not a schottky diode or Zenner. Therefore, its it safe to assume I could replace this with even a 1n4007?
              • redwire
                • 3900
                It appears to be a 3-transistor SMPS and D4 is part of the drive to TR3. I think 1N4007 is too slow, you would use a high voltage fast switching diode 1N4937, UF4004, FR107. Could even be SMT tacked on to the bottom of the board like ES1J, FR2G, RS2G (400V) etc.
                Check the cap C6 is not shorted which would mislead in-circuit readings.
                D1 has a black stripe and more, so it might be a zener.
                • lethbrp
                  • Apr 2023
                  • 15
                  • United Kingdom
                  Many thanks for your help.
                  I did replace the main capacitor, that had gone.
                  Do you know what purpose the small blue capacitors serve. In my ignorance, I thought it was these two capacitors and resistors that were creating an oscillation which was driving the main transistor to the transformer.
                    • 30917
                    the small ceramics are snubbers to protect the diodes and reduce rf.
                    it does look like a regular diode - cant tell the current.
                    if you want to risk it a 1n4148 can handle 250ma otherwise just use a UF4007
                    • lethbrp
                      • Apr 2023
                      • 15
                      • United Kingdom
                      Could you please explain how this works. If I were to guess, the transistors are used to create an a/c voltage to drive the transformer large enough to satisfy the out dc voltages required by the logic board. What I'm struggling with is how the transistors work to create that specific a/c voltage.
                      • lethbrp
                        • Apr 2023
                        • 15
                        • United Kingdom
                        There are no feedback loops and no op amps. so how is the switching controlled?
                        • redwire
                          • 3900
                          It's not regulated, the sloppy output that moves around say 8-10V, can then feed voltage regulator IC's to look after that. It must have a 5V reg IC too.
                          Some designs try to use reflected primary voltage as a rough idea of secondary voltage, in regulating.
                          The module seems to output 5VDC (used by the relay as well) and another rail
                          output at the 5-pin header.
                          The PC board does need the flux cleaned off with IPA and q-tips or something.
                            Tankless hot water heater controller board not powering up when power is applied
                            by sam_sam_sam
                            I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                            I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                            However I would like to know if I could figure what happened to this controller board if possible
                            Tomorrow I will take some better pictures of both side of both boards
                            The...
                            12-09-2022, 09:14 PM
                          • Techie_hobby1
                            Xbox Series S/X controller Parts identification please
                            by Techie_hobby1
                            Hi, could someone please help me here to identify these blue SMD 0201 components.
                            I also have a spare broken board (same model) and can confirm same components installed.
                            Strangely though they have identified Z1 as the same component even though it differs from Z2 and Z3.
                            It's from an Xbox Series S/X controller that I am attempting to fix for my Son..
                            yes I hear a lot of people saying “Just buy a new one because they are cheap” buy this is the White PCB limited edition.
                            Also identification for the other component EW=9L N13
                            Thanks in advanced
                            02-17-2025, 04:30 AM
                          • Zilicon
                            Y4 diode identification
                            by Zilicon
                            Please help me identify this zener diode.
                            I find it hard to see the datasheet. The diode was found on 14TB 3.5" WD HDD
                            I'm looking into having it replaced.
                            Pictures attached...
                            07-24-2024, 09:34 AM
                          • MrBojangles
                            Diode identification for data rescue
                            by MrBojangles
                            Heyo
                            I'm trying to perform data rescue on this drive and don't want to make a mistake. I've found a burned diode and a shorted capacitor right next to it. I've found a component on eBay that seems to match up. Can someone confirm please? Also I don't mind replacing it with a compatible component if it's easy to get hold of.
                            https://www.ebay.de/itm/235070605065
                            Have a nice day
                            05-29-2025, 03:16 AM
                          • master3112
                            ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
                            by master3112
                            I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
                            When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
                            10-29-2024, 09:32 PM
