Igbt <-> mosfet
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Igbt <-> mosfet
    I've played fast and loose with components for the heck of it (and mainly to use the stock I have) but I have a new substitution to try in order to not have to order components.
    I'm going to try to 1:1 replace IGBTs with MOSFETs...
    The current carrying capacity of the MOSFETs are not going to be as good as the IGBTs, but the IGBTs seem to be quite overspecced to begin with, so maybe it's not so bad. I'm going to derate other components like fuses for the time being to save the MOSFETs.
    Any other things I should look out or is this foolhardy and all I'll get is ?
    Hopefully will get some sign of life from the grid tie inverter until I can order bona fide IGBTs. And theoretically should be able to determine if it has a dead time violation that caused the IGBTs to fail to begin with, though I feel like it was more likely lightning...
  • CapLeaker
    Leaking Member
    • 8286
    Re: Igbt &lt;-&gt; mosfet
    I am running a grid tie inverter for 10 years now and it never missed a day. Lightning is no problem for anyone that has proper grounding installed.
    I’ve seen folks changing out Mosfets for IGBT’s, but you wanna do IGBT’s for Mosfets. Never seen someone do this, but I think while it could be done there are certain things that do come in play. Heat of the Mosfets is one. The other one would be the gate drive resistor. While IGBTs have a higher gate drive resistor the Mosfet have a lower gate drive resistor. However we don’t know what Mosfet you try to sub what IGBT for. I guess there are more details needed to get a better answer.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      I'm pretty sure this GTI was not properly grounded as it's an ad hoc inverter not to mention it's "CCS". The "CCS" aspect may be sufficient cause for failure to begin with. The failed IGBTs still look intact (one with all pins shorted, other with C-E short) so it's possible it's not lightning too... *shrug* no clue other than CCS syndrome.
      What kind of stuff was changed when someone swapped in IGBTs for MOSFETs?
      I was looking at the drive requirements for the two and they were quite similar but the voltage needed for IGBTs were somewhat higher - which makes sense due to needing to also overcome the drop in the BJT. I'm wondering if I stick in a few diode drops but have to do this carefully as it'd affect bother up and down, perhaps inverse parallel diodes.
      I haven't decided on a temporary replacement yet, have to worry about voltage and current, I don't have anything close at all so I will have to put in an order at some point.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        Oh I chickened out sorta. I found some old IGBTs but they're nowhere near the ideal specs... Soldered them in and ..well.. it looks like the GTI is alive! Well, not sure, hard to tell, need to see my grid power consumption and see if it changed any with it turned on, but for once my solar panels may be making their pay...
        It's unfortunate my Kill-A-Watt doesn't deal with back power, but I think I have an idea on how to deal with that...
        YEP IT'S WORKING! Now I need to go order real IGBTs to do a proper fix!
          • Jul 2011
          • 6057
          I am glad that you found a solution to your dilemma with this repair
            • Jul 2011
            • 6057
            Did you find a solution to this dilemma with what you want to do here
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Actually I leave that as an exercise to the reader
              The hint: if you don't like where you're at, define your own zero!
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                oh. I think I figured out how this thing failed while I was perusing the web.
                This GTI is MPPT and doesn't know when to quit. So if MPPT exceeds the design limits, so be it, exceed the design limit.
                MPPT of some batteries will far, far exceed the design limits - so I think someone tried using a battery instead of solar panels.
                This is sort of a let down though not totally unexpected. It was meant to be MPPT and anti-islanding after all. Really need a regular inverter for that though it's a shame this can't be double duty...at least without a hack...
                And may well cut off MPPT at its design limits. (and even less with my ghetto fix, then again it was meant to be a band-aid until I get real componets.)
                • CapLeaker
                  Leaking Member
                  • 8286
                  Or someone put too many panels on a string.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Possible, but unlikely... would need to get a lot of panels whereas a LiFePO4 pack could wreck havoc.
                    • redwire
                      • 3912
                      Mosfets are fast switching compared to IGBT's, which can give new grief if the design has really time deadtimes or compensation added for that. They can turn the IGBT on in advance, while turning another off.
                      Another aspect is HV mosfets have high RDS(on) and at some point IGBT's end up more efficient. They have a huge 1.7V VCE drop but once a mosfet is above this, it's cheaper to use IGBT's. IGBT's are also much tougher when partially on, if your inverter has poor gate drive.
                      Not sure what voltage/current this inverter is or the old part numbers.
                      Mains transients can be huge at Cat. IV that's why many smart meter fires were happening, they couldn't take the 8kV+ spike. It's worse if you are at the end of a long run of distribution power lines and/or near the pole pig.
                      Utilities are putting MOV's on the pole pig input bushing.
                      I think I would use latest generation IGBT's and their voltage ratings are up too. Would have to do an autopsy on the old IGBT's top see why they failed.
                      Apparently it's very common for companies to purchase raw IGBT dies and do your own packaging/bonding wires.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        Indeed I was concerned the IGBT would be slower than the mosfet. At the very least, coupled with the transition time and threshold, the MOSFET will turn on sooner. Nevermind turn off, these IGBTs are dastardly slow compared to even MOSFETs which have ways of mitigating shutoff. Was hoping there was enough dead time designed in for this so that they could sub in whatever part was cheaper at the time of manufacture.
                        So far the "baby" TO220 IGBT is surviving at 130W or so tie-in. The remaining IGBTs that weren't fried are rated for 2.5x the voltage and 6x the current of the ones I subbed so I'm definitely not going to get anywhere near the original design target. Luckily power is fairly stable around here...
                        New hopefully exact match IGBTs are coming through the mail...and hope I don't get baby IGBTs in TO-247 packages...
                        • eccerr0r
                          Solder Sloth
                          • Nov 2012
                          • 8701
                          Well, on a bright sunny day today, the baby IGBTs blew... LOL
                          I put in MOSFETs this time, still nowhere near the current capacity of the original IGBTs but a bit ... bit closer. Unfortunately I simply do not have high current devices...
                          ... and so far it's holding up at least for now... Let's see how these work.
                          • CapLeaker
                            Leaking Member
                            • 8286
                            What were the IGBT’s that blew and what mosfets are you going to use as a temporary replacement?
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              I did not want to give part numbers as I wanted this to be completely theoretical...
                              but if you insist...
                              G60N100 was the original big honking IGBT
                              RCP10N40 was the baby IGBT that died, well of course it's way too small, albeit I was using 1/6 the rated power of the whole device before it failed which incidentally is 1/6 the current rating of the original...
                              FDFP18N50 is the MOSFET in now since that's what I have on hand. Going to see if the sun kills them tomorrow.
                              I am not going to bother trying: 75N06 ... IRF640 ....
                              I'm thinking I should buy some more FDFP18N50's too....seems like a good MOSFET to have on hand.
                              • CapLeaker
                                Leaking Member
                                • 8286
                                Well… I got curious when the these baby IGBT’s blew again.
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8701
                                  I thought the RCP10N40 was a really obsolete device so no loss... probably could be replaced by a modern mosfet with nothing but upside ...
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    The 18N50s survived one day, peak current was 1.3A ...
                                    still waiting on new G60N1000s...
                                    • CapLeaker
                                      Leaking Member
                                      • 8286
                                      Interesting it survived that long. What’s the grid tie inverter brand? Any pics?
                                      • eccerr0r
                                        Solder Sloth
                                        • Nov 2012
                                        • 8701
                                        Finally got replacements from China.
                                        I was a bit suspicious about the picture of the IGBTs that I bought off of fleabay but now I know why the photos were suspicious. I thought I was buying Fairchild branded units (which were the originals) but I got post merger On Semi units...
                                        I think they look good enough... at least I hope I didn't get fakes.
                                        Going to wait for a rainy day to put them in, the FDPF18N50's are still working however. But I think I'd rather have the G60N100 IGBTs installed instead of the tiny MOSFETs (or the tiny IGBTs), even better when the G60N100s at least have a metal back plate whereas the FDPF18N50s are plastic all around. I hope that the noise emission also goes down with the slower IGBTs, not to mention that they will be balanced with the two remaining working IGBTs.
                                        Just so suspicious the old IGBTs had no failure marks on them, Still look fine, just shorted all the way.
                                        While we're at it, MOSFETs are easy to parallel unlike BJTs. However, how about IGBTs? On the datasheet it says IGBTs are "easy to parallel" but is it?
                                        (as an aside, I happened to have gotten the FDPF18N50s from the same seller as the G60N100s.... probably by coincidence. Hoping that if the 18N50's lasted these few days as temporary fixes, the G60N100s should also last a while...)
                                        • kotel studios
                                          Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
                                          by kotel studios
                                          Finally got time to fix this board up.
                                          At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
                                          Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
                                          04-22-2025, 05:08 AM
                                        • Jane
                                          How do you test MOSFET in laptops ?
                                          by Jane
                                          I tried to use this method:
                                          Testing an N-channel MOSFET:
                                          Step 1: Discharge the Gate (turn off the MOSFET)
                                          Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                          Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                          Step 2: Charge the Gate (turn on the MOSFET)
                                          Now, place the red probe on the Gate (G) and the black probe on the
                                          09-27-2024, 03:31 AM
                                        • mikkele86
                                          Power amplifier SMPS IGBT keeps blowing - Artcoustic PDA1000
                                          by mikkele86
                                          hello.
                                          I have two power amplifiers, both having their IGBT blown on the PSU.
                                          The original mounted IGBT where marked with IRGB20B60PD1PbF and the gate driver is a IR2156STRPBF.
                                          I looked at mouser and digikey and could not find any available IRGB20B60PD1PbF and somehow ended up using a Bourns BIDW20N60T.
                                          I replaced the gate driver, the gate resistor and both IGBT. But as soon power is turned on, both IGBT shorts out completely (gate, emitter, collector) and the fuse on the AC line gets killed.
                                          So I though i missed a capacitor or diode. I removed...
                                          01-06-2024, 06:45 AM
                                        • redbaron1007
                                          Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
                                          by redbaron1007
                                          I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
                                          Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
                                          09-09-2025, 11:10 AM
                                        • AppleLover123
                                          Asus X712EA 3 volts after the first mosfet
                                          by AppleLover123
                                          Hey guys,
                                          i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
                                          I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
                                          Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
                                          I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
                                          Now i thought something...
                                          12-15-2024, 07:49 AM
