Igbt <-> mosfet
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Re: Igbt &lt;-&gt; mosfet
    Installed new IGBTs, inverter is now full once more with all G60N100s, crossing fingers...
    Problem being tomorrow will be rainy and I won't have enough power to fully test... as if I had full power to begin with. However I need to see if that bigger toroid core would get me more power with that one homemade SMPS...
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8706
      Sun came out today, so have some power to play with. The new IGBTs seem to be fine though will need to run them a few days (with a more optimized/better SMPS that I have) before declaring victory. One thing I noticed as far as I can tell, with IGBTs restored, the output power factor seems to be a bit higher and it seems to be producing less RF noise. Which kind of makes sense since IGBTs are slower, but still kind of surprising... Will need to monitor it more and really see if it really is better.
        • Jul 2011
        • 6070
        If you get this the way you want it to would you consider posting some pictures of your setup I would be interested in seeing what you have
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8706
          is an off the shelf cheap chinese sh*t (CCS) grid tie inverter really that interesting... only when it explodes perhaps, but just the fuse exploded... just the TO247 igbt's just melted internally.
          My custom SMPS for this system is nothing special, just needed something to connect a 1S1P panel parallel to a 2S1P system (because of the CCS grid tie inverter requires 2S and can't deal with 3S1P which would have been ideal, alas it just shuts down when it sees 3S). Of course the 1S1P with the SMPS can generate only half the amperage the 2S1P, but it's still more power to handle...
          Technically I could have bucked the 3S to fake a 2S but then I'd need a toroid that could handle even more watts.
          I suspect that dealing with solar panels, a bit of waste here and there doesn't show up as much as futzing with Li-ion batteries... but still, would be nice to dump everything towards powering the load instead of heating up toroids and transistors...
          • kotel studios
            Intel D865PERL - no Vcore after replacing MOSFETs and MOSFET drivers
            by kotel studios
            Finally got time to fix this board up.
            At first it didn't give any POST codes. Turns out it was an unsupported Celeron D cpu. After dropping in an Celery 2.6gHz the CPU came out of reset with clock signal, but still no post codes. For a while it did work when I applied pressure to the ADP3168 chip, but on next reboot the MOSFETs started to burn. Then I left it as is for months.
            Now I came back prepared. Replaced the bad MOSFETs and the ADPxx18k drivers. Now I don't get any MOSFETs blowing up issues anymore. But sadly, the Vcore is missing. The whole VRM isn't...
            04-22-2025, 05:08 AM
          • Jane
            How do you test MOSFET in laptops ?
            by Jane
            I tried to use this method:
            Testing an N-channel MOSFET:
            Step 1: Discharge the Gate (turn off the MOSFET)
            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
            Step 2: Charge the Gate (turn on the MOSFET)
            Now, place the red probe on the Gate (G) and the black probe on the
            09-27-2024, 03:31 AM
          • redbaron1007
            Help identifying mosfet on Razer Blade RZ09 (CH570_MB_NT)
            by redbaron1007
            I have a Razer laptop (RZ09 MB# CH570_MB_NT) that has a shorted mosfet marked BND M03 E067 that I'm unable to find anywhere online. Does anyone either know what the part number is for this mosfet or have a schematic I can find it in?
            Backstory on the whole thing the laptop was plugged into a lamp at a hotel. The lamp got unplugged while it was charging and now the system won't power on anymore. I found the caps around this mosfet shorted and when I injected voltage into the caps the mosfet got hot and my bench psu was pulling 5A. Pretty sure this is all that's wrong with the laptop...
            09-09-2025, 11:10 AM
          • mikkele86
            Power amplifier SMPS IGBT keeps blowing - Artcoustic PDA1000
            by mikkele86
            hello.
            I have two power amplifiers, both having their IGBT blown on the PSU.
            The original mounted IGBT where marked with IRGB20B60PD1PbF and the gate driver is a IR2156STRPBF.
            I looked at mouser and digikey and could not find any available IRGB20B60PD1PbF and somehow ended up using a Bourns BIDW20N60T.
            I replaced the gate driver, the gate resistor and both IGBT. But as soon power is turned on, both IGBT shorts out completely (gate, emitter, collector) and the fuse on the AC line gets killed.
            So I though i missed a capacitor or diode. I removed...
            01-06-2024, 06:45 AM
          • AppleLover123
            Asus X712EA 3 volts after the first mosfet
            by AppleLover123
            Hey guys,
            i have a asus motherboard here and as the title says after the first mosfet (in the picture) there is nothing more than 3.15v.
            I injected 19v and max. 1 amp at the charging port and there is not voltage drop or smth. It's just taking 19v and 1 milliamp.
            Then i tried to inject 19v and max 1amp after the current sensor and there it first takes 19v and 4 milliamps and after 2 seconds it is taking nothing (no current).
            I measured on the coils on board everything seems fine. Also the main power rail is not shorted (infinite resistance).
            Now i thought something...
            12-15-2024, 07:49 AM
