Use a used resistor
  • uligli
    • Aug 2006
    • 139
    Use a used resistor
    Can i use a used resistor?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Use a used resistor
    yes
    Mann-Made Global Warming.
    - Dr Seuss
      • 31094
      yes - *IF*
      it still reads correctly on a meter.
      i'v had resistors change value without looking any different on the outside.
      • uligli
        • Aug 2006
        • 139
        Originally posted by stj
        yes - *IF*
        I'm trying to find out the problem on a Hyundai LCD's invt/psu board, one of the smd resistors reads different values when i switch the - & + probes on it, and i don't think it's normal, should i pull it out of circuit to retest?
        [182] should be 1.8k ohms, i get 1740 omhs(value going up slowly on the DMM) and 192 omhs.
          master hoarder
          • May 2008
          • 12175
          yes - *IF*
          I agree - definitely check the resistor first with a multimeter before using it. Note the tolerance on the 4th band and see if the resistance is within its range. So for example, if your 1800 Ohm resistor has a Gold band (5% tolerance), then its value can be +/-90 Ohms of that (1800 * 0.05 = 90) - i.e., as low as 1710 Ohms or as high as 1890 Ohms.
          If you want accurate measurements, then YES.
          Otherwise if you know how the resistor is connected in the circuit, you may be able to deduce a range of acceptable values for what it will read on the multimeter.
          For example, the resistor you have in your circuit may be connected in series with a diode and then have that connected across the pins of a transformer - in which case the transformer will act as a short between the diode's other end and the resistor and the result will be the same as if you had a diode and a resistor in series in a closed loop. Basically what will happen then is the resistor will read normal value in one direction and much lower in the other due to the lower resistance of the diode (diodes usually have 100-1000 Ohms resistance).
          Resistors also tend to go open circuit rather then short when they go bad. Thus, when measuring a resistor in circuit, *generally* a lower resistance than the stated one is acceptable (since there may be other components in the circuit that could render this situation). A higher resistance that is out of tolerance, however, is not acceptable and the resistor should be pulled out of the circuit and checked.
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            you are forward biasing a semiconductor.
            resistor is ok.
            as for age some age better than others.
            used is fine if in tolerance.i very rarely will find a noisy carbon comp but its not unusual for me to use a 50+ year old resistor in a repair.mostly in vintage gear to preserve the appearance.
            • MXM
              • 430
              • Unknown
              ^ nice inputs.
              i would use a used resistor, tipically if i cant find the same value on a new one, i just make sure matches properties, also giving correct values in the mm and thats it.... (just on praxis i try to avoid it but yeah if theres no other way.... wel... wth )
              jm2c
              peace.
              We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
              • uligli
                • Aug 2006
                • 139
                Very good explanation thank you
                • jinu_j
                  by jinu_j
                  Hi
                  05-03-2025, 10:51 PM
                • mikey5791
                  by mikey5791
                  Hi to all forum members,
                  12-26-2024, 04:55 AM
                • MidnightRoller
                  Can a resistor lose resistance after hot air?
                  by MidnightRoller
                  I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                  I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                  02-02-2022, 11:46 PM
                • artvandalai
                  What resistor ohm will work better to repair this waterpik?
                  by artvandalai
                  The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                  01-05-2025, 04:10 PM
                • chth96
                  Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
                  by chth96
                  I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
                  Since then, This AC/DC adaptor have been out of order.
                  But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
                  After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
                  And Is there any possibility that it will suddenly explode as well as to be out...
                  12-03-2023, 04:40 AM
