Which of these esr meters do you recommend
  • bp1
    • Jul 2010
    • 46
    Hi everyone
    I have recently registered and very new on these forums.
    First of all what a great forum site.
    So interesting and very informative.
    I am very interested in buying an esr meter. I have read many posts here at badcaps.net and have come to the conclussion that this would prove quite essential in my toolkit.
    i have been currently looking at the esrmicro 4 (http://www.radiodevices.info/zakaz_e.php) and the Atlas esr60 (http://www.peakelec.co.uk/acatalog/jz_esr60.html )
    Both of these are currently out of stock.
    Which of the above would you recommend as best value and ease of use.
    or
    which esr meter manufacturer / model would you recommend.
    My budget would be to spend upto the price bracket of the esr meters above in uk pounds.
    Your advice and reviews would be very much appreciated.
    Many thanks
    bp1
    • 30979
    Re: Which of these esr meters do you recommend
    go for the russian one, it also reads resistance and looks nice.
    • bp1
      • Jul 2010
      • 46
      Would i be right to say the russian guy visits these forums.
      It would be good to hear when he is likely to get these back in stock.
      Kind Regards
      bp1
      • Scenic
        o.O
        • Sep 2007
        • 2642
        he was on here some time ago.. there was a thread where he posted..
        edit:
        https://www.badcaps.net/forum/showthread.php?t=7394
        RusMike is the guy...
        • smason
          • 1652
          What part of the planet are you on? I got the ESR Micro (the Russian one) from a U.S. supplier last month (link is in another thread on this forum)
          • bp1
            • Jul 2010
            • 46
            I have been searching the forum posts and the link given by scenic
            seems where the discussion about the esr meter has been taking place.
            All links within the threads there also seem to point to out of stock.
            I live in the uk.
            Would be most grateful to you if you could say which usa supplier you bought your esr meter from.
            Many thanks
            bp1
              • 30979
              http://www.prc68.com/P/Prod.html#ESR
              us source also out of stock!
              email mike and ask for info about the problem.
              • bp1
                • Jul 2010
                • 46
                Took the advice and emailed Mike.
                He replied back to say he has some in stock.
                I've placed an order.
                Just have to wait for drlivery. Hope its not to long.
                Kind Regards
                bp1
                • bp1
                  • Jul 2010
                  • 46
                  Just a quick update to say i recieved my esrmicro v4 today from mike in Russia.
                  As other posts on these forums mike has always replied to any email queries very fast.
                  The delivery from Russia to the UK took 10 days. The package arrived open but all the contents were present.
                  Had a quick play with the esr meter with some good and bad caps and so far very pleased with the choice.
                  Just like to say thanks to all that have commented on this thread for their advice.
                  Kind Regrads
                  bp1
                  • edspegeddd
                    • Jun 2010
                    +1 for the esr micro Mike is a good man and will come through. I got the older 3.1 which is awesome. Delivery took about 2 weeks batteries included
                    • aaronkatrini
                      by aaronkatrini
                      - Autorange
                      - DC volts up to 30V
                      - Accurate Resistance
                      - Diode test (Beep mode)
                      - Frequency up to 200MHz
                      - Capacitanze up to 5000uF
                      - as cheap as possible
                      05-06-2024, 09:54 AM
                    • petehall347
                      anyone recommend an earth leakage clamp meter ?
                      by petehall347
                      have been looking at earth leakage clamp meters and its like a minefield out there . i wondered if anyone here had bought one that actually works properly ?...
                      04-17-2024, 01:31 PM
                    • ktmmotocross
                      recommend good solder wick on aliexpress
                      by ktmmotocross
                      I get som bad cheap wick that im furious with so i need to order wick that suck solder like it should. best on aliexpress...
                      02-08-2024, 12:48 AM
                    • eccerr0r
                      lowest current galvanometer/analog meter (passively powered!)
                      by eccerr0r
                      Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                      On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                      04-16-2025, 12:41 AM
                    • EasyGoing1
                      Meters and Microamps
                      by EasyGoing1
                      I've been looking off and on for a meter that can read amperage from 1µA and up. And so far, the vast majority of the meters that I can find that state the ability to read at the microamp level list their range starting in the hundreds of microamps.
                      What gives? Why is it so difficult to find a meter that can read 1 or more microamps of current?
                      And does anyone have any suggestions for a meter that can do this? I love my Fluke 115 but it can't read current that small.
                      Thanks,
                      03-22-2021, 04:09 PM
