PAD repair? What are pads?
  • Forumzboard899
    • Mar 2022
    • 5
    • usa
    This is a Roland MC-505 synthesizer I bought used years ago and 1 of the knobs was bent.
    Eventually it started 'ghost editing' by changing the parameter of this knob on its own.
    I resoldered the 5 pins on this knob (the two larger solder spots above these 3 smaller ones is for the same knob).
    Then it started happening again, or maybe the knob stopped working totally (I set it aside months ago and forgot about it).
    I bought a replacement knob/Potentiometer but when I recently opened it up, it seems the previous repair I did didn't 'stick' and wasn't making good contact. So I'm trying to use the same Potentiometer.
    The previous repair was atrocious. I used a $5.50 harbor freight 30W non-adjustable pen-style iron and it was tricky to get the 3 small prongs soldered, I'm surprised it even worked and didn't short from solder touching eachother.
    I got decent at soldering recently repaired headphones and learned I was doing it wrong before by trying to basically transfer globs of solder from the iron to the work instead of heating the work for a couple seconds and touching solder to it. I also didn't use flux or anything before. I'm using a digital ~$14 80W Chinese eBay pen-style iron with various tips and it seems to be ok.
    I just did the 2 larger solder spots and then noticed the circle pads on 2 of the 3 smaller pins are detached!, and one seems to have vanished but I think it was working like that. I guess I added too much heat previously or that there was some wobble from using the knob on the synthesizer.
    The pic with the screwdriver is spare parts of a stereo I took from the curb to practice on so maybe I can use something from that? The circle pads are really tiny like 2mm diameter.
    What do these pads even do? They transfer electricity to the darker green lines/tracks on the board? The solder is supposed to touch the dark green surrounding tracks, or no? I don't get why these pads are even there, are they supposed to insulate/isolate electricity from the board (light green).
    any help greatly appreciated. thank you
  • R_J
    • 9579
    Re: PAD repair? What are pads?
    The component has been ripped away from the circuit traces (solder pads)
    Carefully scrape the green paint from the places I indicated in blue, then tin the copper with new solder and solder the component leads to the trace (or solder pad)
    You can remove the leftover solder pad from the components lead, then bend the lead so it comes in close contact to the circuit trace, then solder the lead to the trace.
    • Forumzboard899
      • Mar 2022
      • 5
      • usa
      AH ok, I think I get it,
      The dark green lines on a circuit board aren't what carries the electricity like I thought, the entire lighter green part DOES.
      For this 3 pin example the pin to the right I guess is grounded or something because it conducts to the entire board which many other pins also connect to the same copper, but the two on the left are meant to only conduct to whatever is surrounded by darker green isolating lines, in this case they conduct to the light green circle that someone pointed out this is a double sided board and the green circle 'feed throughs' go to components on the other side.
      I still don't understand pads though, why don't they just omit pads and keep that spot bare copper? That'd cause too much risk of something metal like a loose screw shorting it out?
      Pads are paper thin, so the paper thin edge is the only thing transferring electricity to the thin copper layer.
      Also, thanks so much for the replies this should be easier than I thought.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        I've got a nice one I did for you. Xbox one S hdmi pads.
        • Forumzboard899
          • Mar 2022
          • 5
          • usa
          I scraped the areas to clean copper and bent the pins down but I'm hesitant to solder.
          The left pin, right below where the pin comes through the hole, there looks to be some exposed copper.
          When I solder the middle pin I'm afraid the solder might contact the left pin's zone, keep in mind this is a really small repair and the dark green non-copper isolation lines are like only 1mm thick, so everything is super close.
          Is there some sort of non conductive heat resistant epoxy or something I can put over the area right below where the left pin sticks out?
          I have superglue but think that'll melt from soldering. Unsure if I want to buy and wait for a special product but definitely will if bridging these two zones as an error would destroy the whole board or something.
          • R_J
            • 9579
            Just be careful and don't put a big blob of solder. An alternative is to solder one end of a thin wire to the center lead, and the other end to the solder point just below the feedthrough.
            If you get any glue on the copper trace the solder won't stick.
            • macattack600
              • Aug 2011
              • 97
              is the pin in the far right able to use the area scraped above it ? Looks like the far right 3rd is to a ground plane just solder that one up , middle pin down ?
              • Forumzboard899
                • Mar 2022
                • 5
                • usa
                Mission accomplished! Everything fixed now. Thanks again!
                I didn't branch a wire for the center pin, it ended working out and not touching the pin to the left of it.
                • macattack600
                  • Aug 2011
                  • 97
                  I figured it would , just have to have a little guts huh , lol .
                  Good Job , I actually enjoy reworking broken traces
                  • Aliencomputres
                    • Aug 2019
                    • 210
                    • România
                    maybe use Dot-Repairing Soldering Lug
                      • Jul 2011
                      • 6057
                      This was a very nice repair I have had to repair soldering traces an eyelid for components before but not to the extent that you had to do this one WOW
                      How long did it take you to do that repair
                        • Jul 2011
                        • 6057
                        Click image for larger version  Name:	Clip_76.jpg Views:	13 Size:	146.5 KB ID:	3334244
                        How well does this product work and how easy is it to use
                        Where do you buy this product from do they take PayPal as payment
                          • Jul 2011
                          • 6057
                          This is funny I try to avoid having to do this type of repair
                          • petehall347
                            • Jan 2015
                            • 4430
                            • United Kingdom
                            sometimes shit happens . just had to do surgery earlier just for fun as its a pad for a dead brain i removed to see if the short went away which it did , cleaned the area as a matter of course and mangled a pad which i straightened up good enough to instal new donor brain if its best way to proceed . .
                            • Aliencomputres
                              • Aug 2019
                              • 210
                              • România
                              I use this from 4 years.very good.
                              Where do you buy this product-search Googl.
                              • Garret Matt.
                                • Apr 2025
                                • 22
                                Pads are really just landing spots for components. When I compare the size of the actual board trace to the contact point my takeaway is that 'good contact is more important than replacing the pad'. The difficult part, like what your photos describe, is when a pad is also a passthrough point. On certain components, like the corner post of an HDMI, the pass through is a mounting point that secures the part to the board. Depending on how frequently that knob gets used the solder joints will eventually weaken. It's difficult, but not impossible to repair these kinds of pass throughs. More than likely however is that enough force on a component that damages these pass throughs are catastrophic enough to damage the PCB as well, so I generally never see these kinds of repairs unless it's an older board like your synthesizer.
                                Good idea to bend those potentiometer pins over! I would make sure those get soldered well to the board. As long as you don't bridge the pins, a good amount of solder and adequate heat will help that part stay put. The pins being bent as they are will mechanically assist the part against future strain. Don't be surprised if you have to touch up your solder in a few years.
                                Just like your bent pins, crimping parts to make things fit and then running jumpers is always viable. The only guideline is your conscience.
                                Those are some clean jumpers! this series X was a pain, as you can see all the pads were taken off by the hdmi Port. This HDMI repair was unique in the sense that the reason the port failed was because this was a replacement done by another shop wherein the soldering tech did not completely flow the solder on the anchor points causing cold solder joint to form. I have another photo somewhere that shows cavitation and layering of the leaded and unleaded solder.
                                • dbuergi
                                  Restore solder pads for SMC on MacBook A1466
                                  by dbuergi
                                  i got a A1466 logic board for spare parts but it looks like the SMC ist bad. I got several spares but somehow i was too fast while removing it and ripped some pads off. You can see the damage attached.
                                  Just for experience i would like to restore the lost pads but before i start (haven't done this before) do you have some hints or tutorials how to do it?
                                  As written i want to improve skills so it doesnt matter if it takes longer.
                                  12-29-2024, 10:24 AM
                                • ClockChip
                                  Advice sought - Selector switch knob repair
                                  by ClockChip
                                  Hello Everyone,
                                  I am seeking to repair a knob on an old (circa 1971) Panasonic clock radio (a model RC-6900). The good news is that I have the small, easily lost knob. The bad news is that the knob has come off a slotted post and I need to re-attach it in such a way that I won't have to worry about it coming loose again.
                                  Here is a picture of the bare slotted post (if I have the term right) the knob should be attached to:
                                  As you can see, this is an Old School selector switch, which means it's pretty stiff. Put another way: the knob has to fit...
                                  07-20-2024, 04:52 PM
                                • jimjoe123
                                  LCD TV Green/Pink screen problem
                                  by jimjoe123
                                  I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                  Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                  Then each time...
                                  02-23-2020, 01:29 AM
                                  HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green EliteDesk 800 i5-7500 Specification for Upgrade or Repair
                                  This specification for the HP EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green boardview and EliteDesk 800 G3 + ProDisplay P240va + Seagate Game Drive for Xbox 2TB Green schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
                                  09-12-2024, 02:00 PM
                                  Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook Vero Specification for Upgrade or Repair
                                  This specification for the Acer Aspire Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD, Full HD Display, Windows 11, Grey, 30% PCR Chassis) boardview and Acer Aspire Vero Green PC AV15-51 15.6 inch Laptop - (Intel Core i5-1155G7, 8GB, 512GB SSD,...
                                  09-07-2024, 03:10 AM
