What kind of desk lamp / magnifier do you use ?
  • aneng
    • 18
    • United Kingdom
    Hi.
    I need to get a bright desk lamp for working on PCBs and I'm wondering what is considered the best type to get for this kind of work ?
    I see there are a lot of magnifier type lamps with ring lighting, but the magnification is usually only 5x, which I don't think is going to be enough for SMD work, though it might be OK for larger components / general use.
    There are also the long LED strip kind.... which seem like they might be good.
    I think that either way, I want to go with a swing-arm type ('anglepoise' type) rather than a gooseneck as I've had lots of gooseneck stuff go floppy on me in the past.
    What do you use ?
    Thanks !
  • clearchris
    • Dec 2013
    • 686
    Re: What kind of desk lamp / magnifier do you use ?
    I'm not well read on optics, but generally speaking, the higher the magnification, the closer you have to get to the work. I have a pair of 2.5 readers, which work ok. I also have an old desktop swing arm luxo magnifier, it's probably around 3.5-4x. It works decent, but it's hard to get my desoldering gun under there, so I usually have to swing it away. It's very heavy, so that works ok, make sure whatever you get can be secured very well, I personally look with skepticism on the clamp type ones, even though the desktop base takes up so much room.
    For SMT work, I'd say it depends. SMT ranges from some decently large components to components that seem scarcely bigger than a spec of dust.
    The advantage of the digital microscopes is that you can get the scope closer to the work without interfering with your working space as much.
    The eevblog guy has some reviews of digital microscopes, they are definitely worth a watch. Unfortunately, it seems that they all come with hokey software to control the scope, which is a major strike in my opinion. I'm not sure there are any open source options that might be a bit more refined, but I haven't looked either.
    If you get a digital scope, I'd probably make sure you have something for fume extraction, the scope gets so close that I'm sure it would be very easy to foul the lens...
    • dicky96
      Sun Seeker
      • Mar 2017
      • 1825
      • Spain
      @aneng
      Are you sure most desk magnifiers (the ones with the flourescent or led ring light) are 5x magnification? In my experience all the anglepoise ones I see are either 5x diopter or 8x diopter
      Diopter is not the same thing as magnification (otherwise it would just be called magnification yeah?). Magnification is diopter divided by 4 + 1 - any one can google that, it's easy to look it up!
      So...
      5x diopter = 5/4 = 1.25+1 = 2.25x magnification
      8x diopter = 8/4 = 2 + 1 = 3x magnification
      So firstly where are you finding these 5x magnification desk magnifiers? That would be 16x diopter ,and I haven't seen any that powerful
      And secondly, to answer your question - my 3.5x - 45x trinocular microscope is normally set to 3.5x while I am soldering because that is usually more than enough (though sometimes I need to zoom in further, 5x - 6x maybe) But generally I would say an 8x Diopter would have roughly the same magnification of my microscope when zoomed out to minimum magnification, which is how I generally use it. The quality of optics and stereo vision is another matter though.
      Rich
      Follow me on YouTube
      Learn Electronics Repair
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8672
        I have a spring-balanced arm lamp with magnifier, it's only like 2+ magnification. Seems if you want a larger work distance and high magnification, it necessarily needs more elements and more elements = more expensive.
        These swing arm lamps that aren't weight balanced also are annoying after a while when the friction stops with the thumb bolt no longer hold. I have one where one of the thumb bolts stripped, and no longer holds. Fortunately the magnifier lamp still mostly holds.
        Sometimes it's cheaper to get a microscope than a swing arm magnifier because at least the microscope lenses are... small!
        • eccerr0r
          desk lamp stopped working... stars?
          by eccerr0r
          How many bcn readers does it take to screw in a light bulb into my LED desk lamp?
          Answer: None. This is a nonreplacable-LED desklamp.
          So this lamp has one of those aluminum stars and an LED on it. It appears to be some sort of BGA or something with pins underneath. Anyway the PSU is 500mA 3.6V-8V meaning this probably was either meant to massively overdrive 1W LEDs or slightly over drive 3W LEDs...
          So it seems that typical 1W LEDs on stars are indeed 3.6V @ 300mA to get 1W which would be overdriven at 500mA, and 3W LEDs appear to be 3.6V@700mA which is a...
          10-01-2020, 12:45 AM
        • vestaviascott
          Epson 5040UB Projector No Lamp Strike Stuck in Startup - Blinking Status/Lamp Lights
          by vestaviascott
          Hoping someone here can put me on the right track. I'm trying to troubleshoot/flowchart the "internal projector error" on my newly acquired Facebook Marketplace bought Epson 5040UB projector (3LED, not DLP). Owner said it needed new lamp, actually error code blink pattern indicates "Internal Projector Error, call Epson support". Unit is out of warranty as of 8/19
          Here's what happens:
          1) Power on
          2) Blue power indicator lights and the lens cover motor opens the lens cover, light fan noise heard
          3) Blue status light flashes for appx 4 minutes...
          07-29-2020, 06:08 AM
        • AJ847.63e
          BenQ TH681 Originally overheating now wont fire the lamp - Colour wheel not starting
          by AJ847.63e
          Hi All.
          Does anyone have any reference materials or something I can use to try troubleshooting a BenQ TH681? Google unfortunately has turned up zip. I did find a service manual for a W series BenQ but that is pretty much useless, it's more a glorified user manual. A list of voltages would be great as I suspect my mainboard is faulty, the colour wheel voltage is not dipping like it should.
          The one I am troubleshooting now was originally overheating after a lamp replacement. It originally would take 2 minutes or so for it to shut off and blink the temp and lamp lights...
          09-18-2023, 06:42 PM
        • khelane
          test active pfc power with lamp test
          by khelane
          Hello
          I have a big problem and that is that in some cases when repairing active pfc power supplies I cannot work with a test lamp. I can only get help with 5 volts standby and for starting and starting I have to work without a lamp and this way there is a possibility of parts exploding and other parts being added.
          Sometimes with a multimeter test the problems can be reduced to some extent, but I had several cases that had to be tested on and online and recently two varistors exploded. They had terrible resistance because the power supplies were over 800 watts.
          Is there a way...
          06-03-2025, 01:00 AM
        • magneh
          Is this some kind of fuse resistor ?
          by magneh
          Hello guys
          Taking a look at some KNX domotic modules that were toasted due to some kind of electrical failure, I found out 2 weird looking resistors.
          Seem to me like some kind of fuse resistor?
          After diggin a bit seems like a fuse wirewound resistor wafer or whatever that is
          They are very toasted but I think the 5 band colours are RED GOLD BLACK ORANGE ORANGE or the opposite, not sure which is the first band.
          The red band is larger than the 4 others, but I dont have much experience with these components.
          Also one of the orange...
          02-10-2025, 07:54 AM
