New tool to find short capacitors on motherboards : shorty with display
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    #41
    Re: New tool to find short capacitors on motherboards : shorty with display
    I'm still interested at that price
    Follow me on YouTube
    Learn Electronics Repair
      • 31196
      sounds good - i may need a few.
      • clearchris
        • Dec 2013
        • 687
        Originally posted by kripton2035
        it seems I will be able to ship a letter with a pcb inside for EUR 5 all around the world without tracking, and 8-9 EUR with tracking. more expensive than china of course but still reasonable.
        That's not bad at all. Last I checked it was a lot more.
        BTW, will you (or can you) post a STEP file from that render you made? I could get working on designing a 3d-printed enclosure. In regards to an enclosure, some mounting holes would be nice, looks like the board is already going to be drilled for the DIN, though I don't know if that requires a bit change and will increase the BOM. Might be nice to have the USB port on the nano closer to the edge for easier access, but I don't know if you have traces running on that side of the board. Unbolting the case to upgrade also isn't that terrible of an outcome. + and - would also be nice on the silkscreen for the 9v connector.
        The other thing I'm thinking of is how best to mount the LCD, it sits back a bit on the board in relation to the other components, but it could be attached with ribbon cable and mounted off the board.
        Can't wait for this, it's a tremendous innovation. Interested bare pcb or populated.
        Here's two of my designs
        https://www.thingiverse.com/thing:4126979
        Note on this one how I thinned out the wall to allow USB access.
        https://www.thingiverse.com/thing:4249306
        I don't know if this tool would be best standing up or laying down (like your case) on the bench though. What do you think is an ideal probe cord length, the shorter the better? Is there an advantage to being able to put the device next to the work?
        • kripton2035
          • Mar 2014
          • 31
          • France
          #44
          the pcb is not final in size... I'm thinking of adding one pad with a 1Ω resistor to calibrate easily. but it will be defined soon. yes the oled seems difficult to put nicely into a case. I've never seen a 0.91" oled nicely fitting in a case ! that's why I am now not focusing at all on a 3d printed case. I would leave the pcb alone.
          • clearchris
            • Dec 2013
            • 687
            Challenge accepted.
            But yeah, it's major for you just to put out the hardware, leave the cases to others.
              • 31196
              making a clean hole is always a challenge, but mounting is easy.
              just put a block of packaging foam behind it to gently press it against the front.
              • kripton2035
                • Mar 2014
                • 31
                • France
                #47
                here is the freecad file of the imported pcb.
                please note that this is not the final pcb.
                have fun.
                • clearchris
                  • Dec 2013
                  • 687
                  have fun.
                  Yeah, I understand changes will probably be made, but most of the components will be the same, etc. I can start thinking about it. My best designs take a while to kick around some different ideas...
                  • megaraider
                    • Jul 2015
                    • 307
                    • Portugal
                    #49
                    Originally posted by stj
                    i got 10 last time.
                    they are used on gotek floppy-simulators. ]
                    Being not only a retro gaming fan (Spectrum, Atari, Amiga, ...) and Arcade [MAME] but also in hardware,
                    can't hope wondering where did you use all those gotek floppy emulators
                    [This made me recall the amazing, @ the time, in midle 90's, i think,
                    Iomega Zip drives with much greater capacity and performance :]
                      • 31196
                      i put some in amiga's, one in an arcade system, and i have a few loose ones for testing stuff.
                        • 31196
                        @kripton2035:
                        just to clarify before i order any more,
                        your pcb is for a NANO?
                        • kripton2035
                          • Mar 2014
                          • 31
                          • France
                          #52
                          yes look at the freecad file some posts above
                          https://www.aliexpress.com/wholesale...t=arduino+nano
                            • 31196
                            or with micro-usb
                            though for some reason it has a huge 12MHz crystal in the picture!??
                            https://www.aliexpress.com/item/32292945241.html
                            • clearchris
                              • Dec 2013
                              • 687
                              or with micro-usb
                              Micro USB is and always has been pretty terrible. Granted, the USB port won't be used on this much, but still. The micro-usb nano looks pretty non-standard to me, I'd stick to something more mainstream. I'd get the blue 328 or the 328p. Pretty sure all mine are the 328 version, though IIRC the 328p is a little better in some what that I don't remember.
                                • 31196
                                i always go for the biggest memory.
                                i may try this project on a bluepill - 80MHz 128k flash
                                the advantage of having stuff just sitting here is i can try such stuff
                                waiting for the postman to deliver my Raspberry-Pi PICO btw.
                                no idea what i want it for, but for under €4 i had to have one!
                                • kripton2035
                                  • Mar 2014
                                  • 31
                                  • France
                                  #56
                                  the total compiled project size is actually around 20k, so a 128k will be more than too much.
                                  • megaraider
                                    • Jul 2015
                                    • 307
                                    • Portugal
                                    #57
                                    Me neither, but for that price (assuming shipment to Europe included), i must have one too
                                    Would u mind share the link?
                                      • 31196
                                      RS, free shipping when you spend 30 or more.
                                      so i just added it to a big cap order.
                                      4us$ is the official price, so you should find it for about €4 anywhere that actually has stock.
                                      and that's the tricky thing - every time a new pi gets released they never have enough!!
                                      https://uk.rs-online.com/web/p/raspberry-pi/2122162/
                                      https://www.reichelt.com/gb/en/raspb...o-p295706.html
                                      • megaraider
                                        • Jul 2015
                                        • 307
                                        • Portugal
                                        #59
                                        Thanks for the share @stj.
                                        • clearchris
                                          • Dec 2013
                                          • 687
                                          I'd think the speed might help, but maybe not, I haven't read the code, but I rarely run out of ram or flash on these small devices.
                                          Raspberry-Pi PICO
                                          https://www.raspberrypi.org/products...pecifications/
                                          >Dual-core Arm Cortex-M0+ processor, flexible clock running up to 133 MHz
                                          Ugh. Now I have to deal with threads on a tiny mcu. I think I'll pass on this one for a while, I'm pretty bought into the stm32 ecosystem. Speaking of which, I think this was recently released, it's a version of the blue pill with stm32f4 processor, usb c, and space for a flash chip on the underside. I might grab a few.
                                          https://docs.zephyrproject.org/lates...doc/index.html
                                          • aaronkatrini
                                            Help me find the short circuit on this WORKING Nvidia GTX1650
                                            by aaronkatrini
                                            Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
                                            Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
                                            04-18-2024, 03:15 PM
                                          • snow_sg1
                                            MSI GS73 (MS-16K61) : help me find short (got thermal cam)
                                            by snow_sg1
                                            First : I've got a SMD rework station, thermal camera and good soldering station
                                            This is my first "short" motherboard repair, this laptop was 25€ so no loss, it just for learning. I want to learn how to fixed board because I want this to become my job.
                                            I've been fixing electronics for 15+ years, but mostly VCR and camcorder.
                                            So, I checked power adapter pin to ground, no short, then I plugged the charger in, light on charger blink indicating short.
                                            PQ19 mosfet got HOT straight away (viewed on thermal cam). Checked,...
                                            09-13-2024, 03:30 PM
                                          • Prott
                                            PCB Layer to layer short on a low voltage power plane - how to find it?
                                            by Prott
                                            Hello!
                                            Recently I have a problem finding a dead short (as far as my cheap multimeter is concerned) on a multilayered (12 layer) PCB. It is caused due to mechanical stress (warping the board and, I assume, cracking inner layers). Injecting voltage of 0.9 V (operational voltage of that part of the circuit) and drawing 0.5 W doesn't cause any visible hotspot on a thermal camera.
                                            Does anybody have any tips & tricks in order to locate the short more or less precisely? The area has a lot of powerplanes, so it's both blessing and a curse.
                                            Silly idea no. 1: Can I...
                                            08-01-2024, 12:09 PM
                                          • rex98
                                            HP DMI Tool
                                            by rex98
                                            HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
                                            DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
                                            The DMI Tool given here are for personal use only.
                                            DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
                                            You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
                                            from it, and that you please credit the author...
                                            07-02-2025, 05:51 AM
                                          • Mess
                                            Beginner question. Did I find a short?? HP dax31mb1aa0 REV A motherboard
                                            by Mess
                                            Hi beginner here, so I'm not sure of I've done this right 😅 trying to diagnose my laptop's motherboard (dax31mb1aa0 rev a). I don't quite know how to read the schematic, so I'm attaching the pictures of the motherboard and the measurements.
                                            I was attempting to measure resistance to GND on inductors. I disconnected motherboard and used "continuity testing" setting on my multimeter. I put black probe to Ground & red probe on an inductor. Did I measure this right? Am I correct to think that 0.3 ohm measurement indicates a short circuit? Thank you for your help!...
                                            09-15-2024, 09:56 AM
