PCB Layer to layer short on a low voltage power plane - how to find it?
  • Prott
    • May 2022
    • 154
    • Czechia
    Hello!
    Recently I have a problem finding a dead short (as far as my cheap multimeter is concerned) on a multilayered (12 layer) PCB. It is caused due to mechanical stress (warping the board and, I assume, cracking inner layers). Injecting voltage of 0.9 V (operational voltage of that part of the circuit) and drawing 0.5 W doesn't cause any visible hotspot on a thermal camera.
    Does anybody have any tips & tricks in order to locate the short more or less precisely? The area has a lot of powerplanes, so it's both blessing and a curse.
    Silly idea no. 1: Can I increase the voltage above the operational voltage in order to draw more amps and... hope the short won't burn through before I find it?
    Thanks!
  • huaji62
    • Aug 2024
    • China
    A short found after raising the voltage will not burn through the printed circuit board, but it should not exceed the maximum voltage withstand of the chip. Sometimes the short location will be around a via hole and you can drill some through holes to fix the short, but I've only encountered two motherboards like this.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8353
      Look up something like an Leakseeker 89 or similar.
        • Jul 2011
        • 6070
        Thank for sharing this information these testing equipment
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8353
          No problem. All you need is something that can read very small resistance values. That is something a DMM cannot do.
            • Jul 2011
            • 6070
            I am seriously considering buying one because there are times I could have used one I have used my Blue ESR tester to figure out if the device is shorted or not this not the best way to do this but you use what you have on hand
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8353
              I’ve got the Leakseeker 89. I don’t use it a lot, but if I need it it’s another gods send.
              • Prott
                • May 2022
                • 154
                • Czechia
                Thank you CapLeaker! The leakseeker looks like an amazing piece of equipment to have. I think I might buy the bare pcb and put it together as a project. Hopefully it will not have a short circuit in the pcb
                • harp
                  • Jun 2022
                  • 650
                  • Planet Earth
                  Dead short or 0.5W ?
                  How you get 0.5W, it may be visable in specific condition, what is voltage drop and current consumption, have you try evenly cooling pcb in fridge, and monitor in it, just apply power for long time and see what you get? Half of watt have power to maintain different temperature, if not spread on large area.
                    • Jul 2011
                    • 6070
                    Did you buy this as a kit or did you buy as assembled unit
                    I found this as a kit is this price reasonable for it being a full kit including the enclosure and all the parts including the micro controller programmed
                    https://www.ebay.com/itm/283992280583
                      • Jul 2011
                      • 6070
                      Just make sure that you can get the micro controller program so you can program it yourself
                      • CapLeaker
                        Leaking Member
                        • Dec 2014
                        • 8353
                        I bought it assembled 12-14 years ago.
                        • DynaxSC
                          Extreme High Current & Low Voltage Short Killer ??
                          by DynaxSC
                          Hi Folks
                          I'm looking for a extreme high current short killer solution for a reasonable cost.
                          I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                          After taking off the socket, the shorts dissappear again.
                          The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                          10-15-2024, 10:13 AM
                        • Stephen
                          MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                          by Stephen
                          I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                          02-06-2025, 12:03 PM
                        • snow_sg1
                          MSI GS73 (MS-16K61) : help me find short (got thermal cam)
                          by snow_sg1
                          First : I've got a SMD rework station, thermal camera and good soldering station
                          This is my first "short" motherboard repair, this laptop was 25€ so no loss, it just for learning. I want to learn how to fixed board because I want this to become my job.
                          I've been fixing electronics for 15+ years, but mostly VCR and camcorder.
                          So, I checked power adapter pin to ground, no short, then I plugged the charger in, light on charger blink indicating short.
                          PQ19 mosfet got HOT straight away (viewed on thermal cam). Checked,...
                          09-13-2024, 03:30 PM
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • Victor Moreira Silva
                          Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                          by Victor Moreira Silva
                          I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                          Well, my decice specs are the following:
                          Model: Acer Nitro 5 AN517-54-55T5
                          CPU: Intel Core i5-11400H
                          GPU: NVIDIA GeForce GTX 1650
                          Motherboard: GH51G LA-L181P Rev:1c
                          The symptom:
                          When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                          05-26-2025, 10:49 AM
