ESR Meter
  • willawake
    Super Modulator
    • Nov 2003
    • 8457
    • Greece
    ESR Meter
    Part 1
    http://www.siliconchip.com.au/cms/A_100895/article.html
    Part 2
    http://www.siliconchip.com.au/cms/A_101187/article.html
    http://members.ozemail.com.au/~bobpar/esrmeter.htm
    would be a nice project. i have seen these also for sale from portugal but 68euro is kinda much
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: ESR Meter
    that dick smith kit is the best.
    i have 2 and prefer them over that 179.00 one with the tweezer probe.
    • Neo2_000
      • Apr 2005
      • 180
      Re: ESR Meter
      Good soldering project. Can't rmember how many exactly, but a LOT of soldered joints in construction. But it's not too difficult. After all, I built one!
      Hint: Found out afterwards that it helps if you read the instructions first
      If you look around, you can find a site with some useful mods to the basic design which may care to impliment during construction such as reducing the power to the LCD to acheive consdierably longer battery life.
      However if you live in Australia, a root canal from your local dentist might just be a less painful experience than attempting mail order from Dick Smith. It would be an act of supreme desperation if I ever placed an order again - not really sure that I could bring myself to do it. It takes a lot to reduce me to a raving lunatic on the phone but even I have my limits and Dick Smith Electronics exceeded those by a more than just a considerable margin.
      But full marks to them for consistency. On the three occassions that I have ordered from them in the past, they have always managed to set a new standard for incompetence. If there was an award for such a feat, it would be no contest.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        Re: ESR Meter
        really? i will definitely check it out
        ROFL. thanks for the recommendation.
        • chth96
          by chth96
          03-09-2024, 10:03 PM
          12-31-2023, 06:04 AM
        • BOSCHNJAK
          by BOSCHNJAK
          ABOUT ME INTRODUCTION FILE
          2
          024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
          2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
          2022 BEV, PROJECT ?
          2021 BEV, PROJECT ?
          2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
          2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
          12-28-2023, 02:09 PM
        • jorpec
          by jorpec
          Hi
          Thnaks
          01-23-2023, 10:37 AM
          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the β€œE” stops and one switching power (24 volt) supply and a transformer...
          12-14-2023, 07:45 PM
