Recommend me a MultiMeter
This topic is closed.
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Recommend me a MultiMeter
    oops, should have edited the the quote, my bad.
    thats not what they asked. answer their question, but don't cut in with crap like that. if they want to know they WILL ask.
    i might ask about a multimeter now and then, but i know lots about soldering irons.
    like if a gamer asks about hardware, that doesnt mean that he's a n00b with software, especially games.
    sigpic
    (Insert witty quote here)
    • Xeoncross
      • May 2010
      • 10
      I also am looking for a cheap multimeter (and esr meter too I guess) to help me test my LCD that died. I don't plan on making a hobby out of this unless my other boards start dieing also.... oh great....
      Originally posted by KeriJane
      Most multimeters that have capacitance ranges do not go above 200μf. Most of the capacitors that give us trouble are rated much higher than that. I use a BK Precision 815 component tester that ranges to 20,000μ for testing capacitors.
      With that in mind does anyone second the mention that the 14213+TE would be a an ok unit for testing the caps on my LCD that range from 100uF to 1000uF? Or would I need to spend more and get something like a $30 B&K to do the job?
      On the subject of Capacitors, multimeters do not generally check ESR (Equivalent Series Resistance). ESR is probably the most important value to check when dealing with electrolytic capacitors. A separate ESR meter is required to check this.
      I can't find any esr meters for less than $50 though. Paying over $100 for the DMM, ESR Meter, and a solder station seems like it kind of defeats the purpose of fixing the screen myself.
      Then again, I'm sure I will use this stuff again.
      • kikkoman
        • Jul 2007
        • 691
        for one fix the ESR meter is defnitely overkill. you might even get away without a multimeter.
        on the other hand, if you do get one, get a proper one. you don't need a Fluke, but as a general rule, mostly anything cheaper than 50$ is just crap. they're okay for *some* things, but if you use them around the house (mains voltage etc.) you don't want to rely on them. seriously not.
        check the previous posts for recommendations, and here's mine:
        the Uni-Trend UT61E. they go for about 40-60$/€ and it's hard to find a meter that can compete at that price. there are cheaper models in the 61 series but the E is capable of True RMS and has better resolution and accuracy.
        build quality is quite nice, too (it's got HRC fuses and proper input and overload protection, HV slots etc.), autorange, all the min/max/hold stuff, RS232, capacity readings up to 220.000µ, frequency up to 220MHz, and comes with GOOD probes.
        best 40 bucks I've ever spent on equipment.
        it can't compete with a Fluke, but hey, I don't care.
        "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
        • Xeoncross
          • May 2010
          • 10
          The Uni-Trend UT61E does look nice - but there is no way I can afford $70 just to test a couple caps. I really need the bare minimum just to get this LCD fixed. The problem is that I don't know what the bare minimum is. I get the feeling that like just about everything else - the cheap stuff works enough to get the/a job done - but no one likes to use it and it doesn't last long - which is fine for me.
          When I build computers I can always choose a cheap $20 ECS mobo that just barely handles the job - or I can spend $70 and get a good Gigabyte/MSI that has better everything.
          Same with cameras, you'd be surprised how good of a shot some of those cheap point-and-shoot things can take. I still rather use a good canon - but it's the photographer that makes the difference. My boss has an awesome canon but can't shoot anything worth saving.
          I'm not trying to sound arrogant or anything since you guys obviously know way more about this than me - I just want to make sure that I'm not getting another bologna reply like "You have to use a Nvidia VCQFX5500-PCIE-PB 1GB Quadro if you game!".
          • retiredcaps
            • Apr 2010
            • 9271
            What a $1 multimeter (DT830B) looks like
            First of all, this is a hobby of mine and I'm not a pro where I depend on my equipment. So I wanted the cheapest possible multimeter to check fuses, shorts (continuity), ohm tests, etc. Nothing fancy. For me, it doesn't make sense to buy a $50+ multimeter to repair a $20 residue value monitor. Even $20 would be hard to justify unless I'm trying to fix a several hundred dollar LCD or plasma TV.
            This DT830B multimeter sells on amazon, but can be found on ebay for $1 + shipping. I didn't expect the greatest or most accurate, but I did it expect it to work.
            After waiting 39 days, it finally arrived today. Well, big disappointment. It doesn't work at all. When I set it to ohms (200) and touch the two probes together I get nothing on the LCD display. Nothing. So I change 9V batteries (both are new and known to work) and same thing.
            I tried measuring simple things like AA batteries and I get nothing at all on the display.
            So naturally, I will be asking for a refund, but in the meantime, I decided to take it apart. See pics.
            PROS
            - lightweight
            - rotary knob feels solid and makes a nice click sound
            CONS
            - very poor soldering job inside (see npn tester)
            - 9V battery prongs need to be pryed out to make contact and hold battery in case
            - user "manual" is your typical poorly written crap
            - no "tone" for continuity
            - plenty of reports on amazon saying it doesn't work or fails very quickly
            PS. I'm going to order a different "cheap" ebay multimeter and borrow a multimeter from a friend! :-)
            --- begin sig file ---
            --- end sig file ---
            • PlainBill
              • Feb 2009
              • 7034
              Re: What a $1 multimeter (DT830B) looks like
              PROS
              - lightweight
              CONS
              One I would recommend is this one on eBay. It's a slightly improved version of the one I use and has been quite reliable for me. I've done business with the seller, and found him to be reliable.
              PlainBill
              • TassieGriz
                • May 2010
                • 7
                #27
                Get a Fluke!
                • Dgtech
                  E. Technician
                  • Apr 2009
                  • 1462
                  • Steeler
                  #28
                  I understand the need to save money on an object but the fact is, you get what you pay for. I, being a technician, can use a cheap meter and know that testing certain circuits the meter will lie to me. A novice user and troubleshooter would beleive the lie! Industries stick to namebrands such as: Fluke, B&K, and Tektronix for a reason (we even use some old Simpson analog meters). All have been proven and stand up to abuse. Not understanding how meters work can be a fatal mistake if improperly used. Some have lost their lives where I work due to this error. Cheap meters are basic ok measuring tools for reading anything with the power OFF. If you have come this far and found these posts, this means that you want to fix a project right and most likely, this wont be the last one you fix. You will get hooked to fixing things like most so why not buy a good long lasting Fluke?
                  Check some flea markets, CL ads, and even pawn shops. With lots of people and businesses losing jobs, they are selling off their tools.
                  • Scenic
                    o.O
                    • Sep 2007
                    • 2642
                    the dinosaur i'm using..
                    Xerox (by Simpson) 600T1616
                    and yes.. that quality control stamp says week 45, 1985
                    still using it because the cheapo ones (like the one retiredcaps posted) don't last more than a couple weeks for me.. (at best)
                    only drawback is that it eats 9V batteries like mad
                    so better not forget to turn it off..
                    bought it for 10EUR on a flea market at least 6 years ago..
                    • PlainBill
                      • Feb 2009
                      • 7034
                      With all due respect, there is a huge difference between someone using a tool as part of his livelihood, and someone repairing a few monitors in the evening. A decent Fluke scope will run a couple of hundred dollars. That is a bargain for someone who uses it in his job. It's a needless expense for someone doing this as a hobby.
                      As far as the bullshit about shock hazard, stop trying to scare people. Short of grabbing the probes at the tips and jamming them into a socket, or probing a 5KV line, I don't see how it would be possible to get a shock. The days when you had exposed live metal on a meter were gone decades ago.
                      PlainBill
                      • PowerAmpFreak
                        • 977
                        • Sweden
                        #31
                        Get a fluke! I've used Fluke the last 15 years. I've still my first Fluke as one of my best friends (A fluke 26 III) and a Fluke 185. I realize the cost of those may be well in excess for hobby use, but I'm a guy who value quality adn realiability, and of course safety during use. I've got some cheaper multimeters aswell but their quality is not in the same world as Fluke. You could go for a cheaper Fluke, I'm sure it will last forever and give you years of troublefree service!
                        • devid21
                          Banned
                          • Sep 2010
                          • 82
                          #32
                          http://www.peaktech.de/produktdetail...kt/p-3360.html
                          • Krankshaft
                            • Jan 2007
                            • 2328
                            I'd have to disagree it has nothing to do with fear or shock hazard I've seen cheap Chinamart meters blow up from simply having the range switch in the wrong position.
                            Their cases don't have proper blast protection and sparks actually flew out of the case on some models. Most of the cheapies also have an unfused 10 amp current measurement that's just downright dangerous. Other meters that have a protection fuse for the mAh measurement don't even use an HRC fuse.
                            I don't want to think about how much heat they'd generate over 10 amps before they'd go up in flames.
                            If you can't spend 50 bucks its better to not have a meter. The one retiredcaps took pics of scares me to death reminds me of a 20 dollar Radioshack pocket model.
                            No fuses no MOVs on the input, an UNFUSED 10 amp current measurement, and the dead giveaway of a cheapie the HFE measurement jack for transistors and a horribly hand soldered one at that!
                            If you're measuring unpowered equipment (resistance and diode checks) or low voltage isolated DC equipment fine but if you're measuring anything connected to the mains then forget about it.
                            I don't need to be a roofer to get a safe ladder even if I'm only going to use it once or twice. I don't need top of the line but I don't want bottom of the barrel either. A multimeter is like any other tool it needs to be safe and reliable.
                            You don't need a Fluke although Flukes are nice and pretty cheap second hand. Don't get a bottom of the barrel sub $50 meter either. Also make sure the meter has a Cat 2 rating or higher. The cat rating refers to testing regarding input protection which none of those sub par meters have.
                            A primer on cheapies:
                            http://www.youtube.com/watch?v=8cNc5An0DLw
                            Here's a decent video on good $50 dollar meters:
                            http://www.youtube.com/watch?v=ZoeUgMFLyAw
                            • MXM
                              • 430
                              • Unknown
                              #34
                              http://us.fluke.com/Fluke/usen/Digit....htm?PID=56126
                              We don't have a great war in our generation, or a great depression, but we do, we have a great war of the spirit. We have a great revolution against the culture. The great depression is our lives. We have a spiritual depression.
                              • Krankshaft
                                • Jan 2007
                                • 2328
                                I've got to admit I have a Fluke 87-5 that thing is porn for electronics guys . Complete overkill for somebody just fixing a few things.
                                It feels good to finally ditch my 50 dollar Ratshack meter though the autoranging time on that thing was atrocious something like 4 seconds.
                                When measuring resistors during troubleshooting that's a lot of waiting. Never measured currents over 400maH either since the 10 amp range was unfused. But at least it was Cat 2 rated with MOV protection.
                                Extech, Amprobe, and BK Precision are a few brands that come to mind. They have good models in the 50 range.
                                Highly unlikely you'll get a used Fluke in this range unless something is wrong with it.
                                • devid21
                                  Banned
                                  • Sep 2010
                                  • 82
                                  #36
                                  Hello all
                                  Here are some comparative characteristics.
                                  Fluke87v
                                  AccuracyC-0,05%
                                  R-0,2%
                                  C-10mF
                                  F-200kHz
                                  Counts:20000
                                  Price:400$
                                  PeakTech 3360
                                  AccuracyC-0,06%
                                  R-0,3%
                                  C-4mF
                                  F-100MHz
                                  Counts:40000
                                  Price:150$
                                  • Krankshaft
                                    • Jan 2007
                                    • 2328
                                    The accuracy in what mode AC, DC current also plus or minus how many counts?
                                    The other counts you mention 20000 and 40000 that are not tied to the accuracy percentage have nothing to do with accuracy they have to do with resolution or how many digits the LCD can display. The Fluke 87-5 also has a 40000 count mode by holding the back light switch. Also a fair price for a 87-5 Fluke is around $285 shipped nobody pays the MSRP.
                                    It probably won't measure up to a Fluke in every regard but if those numbers are right and the accuracy counts aren't too high it's definitely a good buy. Unfortunately it looks like it's only available in Europe.
                                    • devid21
                                      Banned
                                      • Sep 2010
                                      • 82
                                      #38
                                      Unfortunately could not find a link that has a multimeter FLUKE 87-5 counts 40000.
                                      • devid21
                                        Banned
                                        • Sep 2010
                                        • 82
                                        #39
                                        Hi
                                        Top of the range Professional model
                                        http://www.kew-ltd.co.jp/en/products...1061_1062.html
                                        • devid21
                                          Banned
                                          • Sep 2010
                                          • 82
                                          #40
                                          Originally posted by devid21
                                          hi
                                          top of the range professional model
                                          510€
                                          • aaronkatrini
                                            by aaronkatrini
                                            - Autorange
                                            - DC volts up to 30V
                                            - Accurate Resistance
                                            - Diode test (Beep mode)
                                            - Frequency up to 200MHz
                                            - Capacitanze up to 5000uF
                                            - as cheap as possible
                                            05-06-2024, 09:54 AM
                                          • dj8452000
                                            How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                            by dj8452000
                                            I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                            02-18-2025, 08:28 AM
                                          • trex66
                                            Craftsman 82345 Multimeter broke!
                                            by trex66
                                            My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                                            03-04-2025, 04:26 PM
                                          • Sofian75
                                            Things not to do with a multimeter?
                                            by Sofian75
                                            I started to learn laptop repair a few weeks ago, since then I ve ordered several dead laptops to try to fix them and learn.
                                            I fixed some of them and some I ve made things worse by blowing components.
                                            Every time while taking measurements with my multimeter.
                                            Yesterday I was working on a dell laptop motherboard, I was checking the charge IC for short in diode mode and it killed the chip.
                                            So my question is are there things I should not do with my multimeter?
                                            Or measurements I should do only with the charger and battery unplugged?...
                                            06-27-2024, 05:13 AM
                                          • max_smart
                                            T430 laptop doesn't power on- please help me troubleshoot w/multimeter (fixing for fun)
                                            by max_smart
                                            First off, this forum really helped me out by advising me to cut some ribbon connectors to the LCD panel in order to fix a 70" TV (lots of threads on Sharp TVs with this issue). I didn't believe that it could work, but it did.
                                            Now I've been encouraged to try to diagnose something quite a bit more complicated. That is an old T430 motherboard. I work on a college campus so I have access to pretty decent tools. I found the schematic for the motherboard on the site, and have been following traces and taking DC measurements from things. I also don't mind...
                                            06-01-2024, 03:27 PM
