Recommend me a MultiMeter
This topic is closed.
  • Demix
    • Jul 2009
    • 72
    Hey guys im very new to the whole DIY and replacing bad Caps etc but ive managed so far to repair 2 out of 4 monitors without any problems.
    Although the 3rd one i was repairing had some bad transistors and a pico fuse. I just wanted to know what MultiMeter you guys would recommend for a newbie like me to get in order to be able to see whats good and whats bad (Capacitors, Transistors etc) rather than having to replace everything and hope for the best :P thanks in advance guys
  • KeriJane
    Mac Enthusiast
    • Sep 2008
    • 681
    Re: Recommend me a MultiMeter
    Hi Demix
    Welcome to the Forum!
    Most modern digital multimeters are good enough for resistance, current and voltage checks.
    There are a few things to keep in mind while shopping:
    Most multimeters that have capacitance ranges do not go above 200μf. Most of the capacitors that give us trouble are rated much higher than that. I use a BK Precision 815 component tester that ranges to 20,000μ for testing capacitors.
    On the subject of Capacitors, multimeters do not generally check ESR (Equivalent Series Resistance). ESR is probably the most important value to check when dealing with electrolytic capacitors. A separate ESR meter is required to check this.
    If you intend to be doing much in the way of current measurements (Amps, MilliAmps) find out how much the little fuses inside the meter cost.
    Fluke, which is a very reputable brand uses insanely expensive fuses. Most other meters use much cheaper generic fuses.
    Display update rate. How quickly the meter updates the display is useful for observing rapid fluctuations. Also useful is a bar-graph along the top or bottom of the display. Faster is better. Nowdays, most stuff is decently fast.
    Most digital multimeters are autoranging or use a button-selected range feature They usually integrate the On/Off switch into the main selector as well. Personally, I can't stand this and much prefer manually-selected ranges and a separate on/off switch. The BK Precision 815 has both manual ranges and an on/off switch as do my other meters. This is of course, a personal preference.
    Have Fun,
    Keri
    The More You Learn The Less You Know!
    • PlainBill
      • Feb 2009
      • 7034
      There are a couple of factors that should be considered. The first is 'How are you going to use it?' If you are going to use it 40 hours (or more) a week in your main job, spend the money to buy a good rugged piece of equipment. Fluke has been mentioned prominently.
      On the other hand, if you are using it as a hobbyist for a few hours a week, and perhaps making a few dollars repairing dead monitors, you can get by with a much less expensive DMM.
      As an inexpensive hobbyist level meter I'm content with the Cen-Tech 37772-2VGA from Harbor Freight Tools. It's no Fluke, or even B & K, but at $25 ($20 on one of their frequent sales), it's a bargain. In particular, the temperature probe can come in very handy.
      The capacitance feature on this is rudimentary. In particular, it has no capability of measuring ESR.
      PlainBill
      • Bob Parker
        Technician
        • Feb 2007
        • 182
        Analog multimeters do have some advantages over digital and are better suited to some measurements, believe it or not.
        It is a good shrubbery. I like the laurels particularly...
        • everell
          • Jan 2009
          • 1514
          If you are on a tight budget, as most of us are these days, I use and can recommend a digital multimeter from www.mpja.com, part number 14213TE cost is $14.95. That and the blue esr meter are the two main pieces of test equipment I use.
          I also use and recommend their soldering station part number 15860TL cost $14.95. MUCH better than the old Radio Shack soldering iron I had before.
          And finally, don't use acid core solder. Cheap electronic solder is usually a large diameter that globs. I use and recommend the one pound spool part number 4457TL cost $12.95.
          Welcome to the forum. May you have many enjoyable hours exploring this exciting world of "fix it yourself" electronics.
          Old proverb say.........If you shoot at nothing, you will hit nothing (George Henry 10-14-11)
          • PlainBill
            • Feb 2009
            • 7034
            All types have advantages and disadvantages. An analog meter makes a pulsing voltage obvious. Differences in level are obvious at a glance.
            On the other hand, I've never had a bent needle on a DMM. I've never seen an analog meter that can be read to .1% accuracy (we had a test engineer who insisted the 5 V power supply must be set +- 50 mv). And it is far easier to read a digital display than it is to interpret an analog meter with multiple ranges.
            Still, when the focus block on a Zenith TV was cracked and I found out about it when it arced to the test lead; I was very happy I was using my $10 P.O.S. VOM, not the $100 DMM.
            PlainBill
            • Demix
              • Jul 2009
              • 72
              Thanks a lot for all of your help. From this I will compile a list of the best equipment to get from my money and then let the fun begin =]
              • Demix
                • Jul 2009
                • 72
                Okay I have myself a new Soldering Station, some solder and a DMM =P all I need to find is a ESR Meter now and I really dont know which one i should get, can anyone recomend me on on http://www.mpja.com/ if possible? thanks a lot guys!
                • Demix
                  • Jul 2009
                  • 72
                  Sorry for the triple post guys, it seems that mpja really dont like to send to the UK unless its over $100, soo im going to ask if anyone could recomend any of the multi-meters/ esr meters from this website instead =P http://www.maplin.co.uk - Once again thank you guys and sorry to be a pain
                  • KeriJane
                    Mac Enthusiast
                    • Sep 2008
                    • 681
                    Hi Demix
                    Well, it seem that particular websie only has an ESR/Capacitance meter called the Atlas.
                    http://www.maplin.co.uk/module.aspx?moduleno=43095
                    Personally, I use the Ana Tek Blue ESR meter and a BK Precision 815 component tester to check capacitance.
                    The Atlas is more expensive than either but not both... if all you want to check is capacitance and ESR maybe the Atlas would be OK.
                    Have Fun
                    Keri
                    • Demix
                      • Jul 2009
                      • 72
                      Thanks a lot ^_^ sorry to keep being a bother im just really new to all of this =P thanks again hehe.
                      • caryg
                        • Aug 2009
                        • 36
                        If you've never used a multimeter then I'd recommend getting pretty much the cheapest that you can, either say this one or this one. It'll do 95% of what you want, and after a few months you should be pretty aware of what its limitations are, what extra features you want when you upgrade to a better model, and what is just unwanted eye candy. At that price chances are that it will cost you more in petrol and parking to get to the shop. And even when you do upgrade there are always occasions when you'd rather have something more expendable to hand.
                        • Krankshaft
                          • Jan 2007
                          • 2328
                          I own a Mastech variable 5 amp power supply with digital readouts.
                          I had to junk the bad caps inside (pyramid logo still don't know who makes them and 2 fake Chemicons) but for the 120 bucks shipped I paid for it. It was worth it. Nice torroid transformer in it too.
                          I'd go with that brand rather than the no name.
                          If you save up around 50-70 bucks you can get a Fluke off e-bay if you're so inclined in the future.
                          Don't forget a decent soldering station too. No point in using a DMM if you can't remove the components safely.
                          • dot11
                            • Aug 2009
                            http://www.alfaelectronics.com
                            Model DMM-20.....it is DMM + LCR for 75$....Highly recomended
                            • lucky13
                              • Aug 2007
                              • 412
                              Mmm... interesting and a lot cheaper than Fluke.
                              What does the spec mean under Capacitance?
                              2.000nF, 20nF, 200nF, 2uF, 100uF (5.0%+10digits), >100uF(8.0%+10digits)
                              For over 100uF, 8% accuracy and 10digits? 10 digits? This meter only show 4 digits.
                              • PlainBill
                                • Feb 2009
                                • 7034
                                That probably means 10 counts - a reading of 680.2 uF has a possible error of 54.4 uF (8%) plus 1 uF (10 counts).
                                Also, 'cheaper' is a relative term. If you use it dozens of times a day as part of your job, if it fails it could easily cost you a day's work before it is replaced. That could be expensive If it is used every week or two as part of your hobby, it is unlikely a failure would actually cost much at all.
                                PlainBill
                                • fuse
                                  • Oct 2009
                                  • 5
                                  I have had this meter for almost 2 years. It has been very durable and accurate. It will only take 2 amps of current. I work mostly on tube guitar amps, so the 2 amp limit is 20 times higher than I will ever need for most of my stuff.
                                  Good Luck
                                  http://www.amprobe.com/cgi-bin/pdc/v...id=1&type=elec
                                  26+6=1
                                  • trhisdone
                                    • Aug 2008
                                    • 13
                                    Weller WTCPT soldering station. You can get all kinds of tips and the tips set the temp. Fluke 16 multimeter.
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      wrong thread. we're talkning multimeters not soldering tools.
                                      sigpic
                                      (Insert witty quote here)
                                      • trhisdone
                                        • Aug 2008
                                        • 13
                                        True but if your asking about multimeter's most likely you don't know that much about soldering irons either. Just my 2 cents and I did say Fluke 16 mulitimeter....
                                        • aaronkatrini
                                          by aaronkatrini
                                          - Autorange
                                          - DC volts up to 30V
                                          - Accurate Resistance
                                          - Diode test (Beep mode)
                                          - Frequency up to 200MHz
                                          - Capacitanze up to 5000uF
                                          - as cheap as possible
                                          05-06-2024, 09:54 AM
                                        • dj8452000
                                          How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                          by dj8452000
                                          I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                          02-18-2025, 08:28 AM
                                        • trex66
                                          Craftsman 82345 Multimeter broke!
                                          by trex66
                                          My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                                          03-04-2025, 04:26 PM
                                        • Sofian75
                                          Things not to do with a multimeter?
                                          by Sofian75
                                          I started to learn laptop repair a few weeks ago, since then I ve ordered several dead laptops to try to fix them and learn.
                                          I fixed some of them and some I ve made things worse by blowing components.
                                          Every time while taking measurements with my multimeter.
                                          Yesterday I was working on a dell laptop motherboard, I was checking the charge IC for short in diode mode and it killed the chip.
                                          So my question is are there things I should not do with my multimeter?
                                          Or measurements I should do only with the charger and battery unplugged?...
                                          06-27-2024, 05:13 AM
                                        • max_smart
                                          T430 laptop doesn't power on- please help me troubleshoot w/multimeter (fixing for fun)
                                          by max_smart
                                          First off, this forum really helped me out by advising me to cut some ribbon connectors to the LCD panel in order to fix a 70" TV (lots of threads on Sharp TVs with this issue). I didn't believe that it could work, but it did.
                                          Now I've been encouraged to try to diagnose something quite a bit more complicated. That is an old T430 motherboard. I work on a college campus so I have access to pretty decent tools. I found the schematic for the motherboard on the site, and have been following traces and taking DC measurements from things. I also don't mind...
                                          06-01-2024, 03:27 PM
