Does flux expire ?? Flux discussion.
    • 30979
    Re: Does flux expire ?? Flux discussion.
    you could desolve rosin with some ipa or just heat it in a spoon, then mix it into some grease or fat.
    be interesting to see how well it works.
    specially if you can make the work area smell like bacon - to hell with fume extractors!
    • Agent24
      I see dead caps
      • Oct 2007
      • 4950
      • New Zealand
      #42
      Yeah, it'll smell alright... when the fat starts rotting
      Beeswax might be better, actually!
      -David VanHorn
        • 30979
        but how would you clean it off??
        that's important to keep in mind.
        there is some relativly good flux from poland (thermopasty), but it ignores IPA!!
        luckily i discovered it disolves in white spirit - which is handy ecause that stuff is cheaper than beer - about €2 for 3Liters
        • megaraider
          • Jul 2015
          • 307
          • Portugal
          #44
          Originally posted by mariushm
          And yes, isopropil alcohol is used in liquid fluxes. You can pound those rosin chunks into tiny granules and mix them with isopropyl alcohol (i forget the ratio now, the video below says between 20% and 80% something of weight is rosin, rest is alcohol) and leave the bottle closed for a day or so to have the contents mix well.Optionally shake from time to time.
          Also optionally you can add a tiny amount of glycerin, less than 1% by weight, basically a drop or so in a 100ml bottle.
          See https://youtu.be/iv_2ULCmA28
          I've used this since i can remember, way before flux birth (or globalization anyway).
          [rosin + isopropyl alcohol, aka isopropanol + glycerine]
          Usually around 60% in concentration but it depends on rosin pureness.
          For very high temperatures long exposures, e.g.: hot air soldering, adding glycerine is a must.
          Also it's easily cleaned with white spirit, which is also cheap.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4950
            • New Zealand
            #45
            I think a detergent is used as part of the flux-cleaning process, in industry, too.
            The hobbyist can just leave the board outside an ant's nest for a week.
            But yeah, some flux is a bit of a swine to clean off.
            -David VanHorn
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8696
              I think the translucent (and yellowish/orange) ones should be mostly rosin, the opaque ones have at least some triglycerides in it. If it's both, maybe it's both...
              • Retro-Hipster
                Tinkerer
                • Apr 2019
                • 125
                "diode gone wild" uses the solid rosin by dipping the iron in it and splashing it onto the joint!!!!
                Ahaha! Him doing surface mount stuff with the rusty nail and the rosin was so entertaining. :'D
                "And Rosiiin.. there is never enough of rosiiiin..."
                “Men always seem to think about their
                past before they die, as though they were
                frantically searching for proof that they
                truly lived.”
                – Jet (Cowboy Bebop) -
                  • 30979
                  go watch his video with the electric water heater and pack of salt!!!!
                  https://www.youtube.com/watch?v=SB62AfXLEHY
                  youtube is fucking with this video!
                    • 30979
                    Originally posted by msbettyhunt
                    Which one do you find better?
                    the clear one that looks like beer is the best.
                    • eccerr0r
                      Solder Sloth
                      • Nov 2012
                      • 8696
                      OMG it's age restricted now ... BS.
                      • megaraider
                        • Jul 2015
                        • 307
                        • Portugal
                        #51
                        Hilarious... if it was just on youtube...
                        The very same principle is applied (without salt) on these electric hot water bags and sold in every chinese local shop!!!!
                        The only difference (???) being it's water tight in a rubber enclosure.
                        They even stick the "CE" approval label
                        • Retro-Hipster
                          Tinkerer
                          • Apr 2019
                          • 125
                          Oh yes, i have watched that one more time than I can say. Lol I wish more people knew of the video because "I can't believe I do this!" desparately needs to be a meme. Haha
                          truly lived.”
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4950
                            • New Zealand
                            #53
                            I kinda think it should be though. We might think it's hilarious, and understand the risks, but some 10 year old could blow themselves up trying it. Not that a dumb adult couldn't either, I suppose, but still. Kids are more likely to do dangerous things without thinking enough about it.
                            -David VanHorn
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8696
                              What would you guys think of the best "test case" for fluxes. A freshly cleaned copper surface will easily take on solder, but what would be a "stress test" hard to wet surface for flux?
                              • Dannyx
                                CertifiedAxhole
                                • Aug 2016
                                • 3912
                                #55
                                Me again THIS is what I have at work on my desk - still unopened, so I have no idea how well it works. I almost thought it had no label....that was until I flipped the tin over and found it on the bloody bottom !
                                Wattevah...
                                • eccerr0r
                                  Solder Sloth
                                  • Nov 2012
                                  • 8696
                                  At least it has rosin in it, but no idea until you open it to tell how much fat is in it.
                                  • Dannyx
                                    CertifiedAxhole
                                    • Aug 2016
                                    • 3912
                                    #57
                                    I DID pop the lid off once just to see what it looks like: looks exactly like honey ! It was actually pretty tempting to take a lick at it That should be a different topic entirely: what does flux TASTE like ?
                                    Wattevah...
                                      • 30979
                                      i have that one too,
                                      it works and is sticky, but as i said - clean it with white spirit.
                                      • Dannyx
                                        CertifiedAxhole
                                        • Aug 2016
                                        • 3912
                                        #59
                                        So Iso alcohol we all know and love doesn't cut it ?
                                        Wattevah...
                                          • 30979
                                          you dont need flux for clean copper.
                                          i compare them by trying to solder to tin/steel tuner cans.
                                          the better the flux, the better it will flow from the iron with clean edges to the puddle.
                                          also a good test to see how much the flux spreads or spits/burns etc.
                                          • chth96
                                            Is it good to use chemistronic flux off es835b for flux remover?
                                            by chth96
                                            I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
                                            Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
                                            11-17-2023, 07:25 AM
                                          • evilkitty
                                            Flux causing high resistance short?
                                            by evilkitty
                                            Now that my de-soldering gun is working i was able to remove this panel i made about a week before i noticed a issue the F segment of digits 2 and 3 would go out, digit 2 would go before digit 3, but would come back after the humidity got down from running the ac (note the weather outside is 30.5 / 74%; panel data is from a BME280)
                                            Temp is on the left humidity is on the right
                                            i noticed when the humidity got up one or 2 of the center digits on the right panel would loose a segment
                                            The pin out looking down from the top is (note this is common cathode)...
                                            07-17-2024, 09:38 AM
                                            Multifix 425-01 and 450-01 Rework Flux Datasheet
                                            REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                                            - No Clean Formulations
                                            - Low residue
                                            - Range of activity to deal with different component solderability
                                            - Halide free
                                            - Suitable for dispensing
                                            - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                                            Both products are supplied in syringes or cartridges for application by dispensing....
                                            10-07-2024, 06:02 AM
                                          • chth96
                                            How can I remove flux with the smallest rubbing?
                                            by chth96
                                            I have tried to bridging tiny broken trace which is shown in the below link,and I found that it is impossible to remove any flux after soldering task.
                                            Is it possible bridging tiny broken trace - Badcaps - Capacitor Search Engine​​
                                            Because the 0.02 mm copper wire is very very fragile,So It broke itself very easily whenever I tried to rub excess flux with cotton bud.
                                            Is there any way to remove flux with the smallest rubbing or without any rubbing?
                                            Any reply would be appreciated.
                                            11-24-2023, 05:22 PM
                                          • tony359
                                            Non darkening Flux?
                                            by tony359
                                            I was watching a video from NorthWest Repair (The guy there is just doing such incredible repairs) and while he was fixing a bunch of pads on a GPU PCB, I saw this
                                            I've been trying to fix some broken traces on a PS3 CPU for a while but one major issue I'm seeing with my AMTECH flux is that it gets tacky and dark very quickly and then it's a pain to remove and replace.
                                            In the video Tony (I think it's his name) seems to suggest that I am just using the wrong flux?
                                            Any thoughts or ideas?
                                            Full video is here: https://w...
                                            02-03-2024, 08:25 AM
