Good day folks. So my Aneng 8008 meter has a capacitance meter built into it, but I reckon it's better to have a proper tool for the job so I was thinking of getting myself one of these...does anyone have any experience with anything of the sorts ? Are they good, are they bad ? Surely it won't be laboratory-grade level, but enough to do my job with. By the looks of it, it's probably one of those kits that we see everywhere, just pre-installed in a case. It looks promising on the outside...
Aliexpress cap meter - any good ?
Re: Aliexpress cap meter - any good ?
Yes it's nice, I've mentioned it here:
https://www.badcaps.net/forum/showth...607#post824607
To be honest I do prefer the first one I bought, a GM328R without case.
But that might be more down to sentimental reasons"The one who says it cannot be done should never interrupt the one who is doing it." -
Yeah, I came across the GM328 one as well but I thought the added case made the BSIDE one worthwhile.
I'm actually achin' to see what's inside one of those BSIDEs I linked to. It would be pretty interesting if it were the same circuit insideWattevah...Comment
Of course it is, I posted some photos of it on eevblog.
http://www.eevblog.com/forum/testgea...82/#msg1371182"The one who says it cannot be done should never interrupt the one who is doing it."Comment
Per Hansson
Your Link
Error 502 Bad Gate WayLast edited by sam_sam_sam; 02-09-2019, 01:59 PM.Comment
Yes eevblog seems to be down for the moment, the link is good..."The one who says it cannot be done should never interrupt the one who is doing it."Comment
Are any of these capacitor ESR tester that this thread has been talked about earlier are really any good and worth the money
Or do you need to spend more money to get a better one
I have a blue ESR capacitor tester and it service well for years
But I have been thinking about buying another ESR capacitor tester
This why I am am asking this question
Can anyone recommend one and the reason for recommending itComment
they work.
depending on the one you get, they do lots of other usefull shit too.
a bit long, but a fun read.
https://www.badcaps.net/forum/showthread.php?t=50720Comment
by ktmmotocrossI get som bad cheap wick that im furious with so i need to order wick that suck solder like it should. best on aliexpress...
by sam_sam_samI have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery... -
by irepair559PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...01-05-2023, 12:32 AM
by klendatu04-07-2022, 06:12 AM
by chth96I read EBOOK of Testing Electronic Component and found that
"In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
Is it really possible to test small ceramic disc capacitor with analogue...-
Channel: General Capacitor Questions & Issues
- Loading...
