[Baku 702B] Soldering iron not heating up and the temperature doesn't go up
  • datsnow
    • Mar 2016
    • 13
    • Portugal
    Hi!
    I'm owner of a Baku 702B. I do some SMD work with it, and since I have a spare soldering iron that works very well for the little soldering that I do, I hardly use the soldering iron that this station comes with.
    (To add some info, this station went to RMA some months ago, the hot air gun resistance was changed to a new one.)
    So, some days I needed to use the soldering iron that comes with the station, but for my surprise, the temperature would not rise. The temperature screen would always show 22/23ºc and no matter what, if I rised or decreased the temperature, it would not change anything.
    Since I really don't enough to troubleshoot the station, I tried to use the very little that I know first before coming here.
    Things that I've done:
    - Measured continuity from the soldering iron tip socket on the machine from each pin on the socket till the end of the cable where it would connect to the PCB - All OK.
    - Measured continuity from the soldering iron itself from the male socket it has in the iron it self, where I saw that 2 "lines" were mixed. The lines that we're mixed where the black and red.
    - Tested the potentiometer that rises/decreases the temp, and it's working fine.
    Here are some more pictures of the station itself if it helps.
    Could it just be a bad cable on the soldering iron?
    Thanks for any help!
  • R_J
    • 9581
    Re: [Baku 702B] Soldering iron not heating up and the temperature doesn't go up
    I believe these are the same as the hakko 93x, I measured mine
    • datsnow
      • Mar 2016
      • 13
      • Portugal
      Thanks for the reply!
      On the place you got 3ohm, I got 13.4ohm on both of them.
      On the palce you got 55ohm, I got flutuations between 1.3 and 0.2 depending on the cables (both lines are conected to red and black wire)
      • R_J
        • 9581
        there could be a short in the cable, those two leads are the sensor. Do you have another soldering iron?
        • datsnow
          • Mar 2016
          • 13
          • Portugal
          Those two leads are supposed to be connected to each other?
          If you're talking about a spare soldering iron to work it, yes, a replacement to this one for the station, no.
          • R_J
            • 9581
            Those two lines go to the sensor, I suspect the wires are shorted, so unsolder either red or black wire at the solder iron end if you still have a short, check the plug end, it could be shorted in the plug
            • datsnow
              • Mar 2016
              • 13
              • Portugal
              Well, I unsoldered the black cable and it's still not heating, but now the temperature keeps around 97/96ºc.
              Does this symptoms indicate the real problem?
              • R_J
                • 9581
                I did'nt say to unsolder the wire and try the iron, Of course it won't work with the wire unsoldered. I said unsolder the wire and check THE CABLE if it is still shorted. If the cable is shorted either find the short and fix it or replace the cable.
                THE CABLE is likely shorted where the strain relief is clamped or at the plug end.
                  • 31157
                  the sensor probably should look shorted - it's usually a thermocouple.
                  set your meter to read mV and probe the sensor, then heat it up while the meter is connected - i bet you see a rising voltage.
                  • bpjl
                    SEF 551.10 - How to raise the temperature of the unleaded soldering furnace?
                    by bpjl
                    We continue to struggle with the SEF 551.10 reflow oven. After we managed to start it in october - the topic here -> https://www.badcaps.net/forum/troubl...he-reflow-oven everything promised to be good. But...
                    While soldering with lead paste somehow goes, but we cannot force the stove to raise the temperature
                    that he would dissolve the unleaded binder. I even doubted what this bastard shows on screen and passed through it a thermocouple...
                    03-16-2025, 09:26 AM
                  • kalemaroni
                    Opinions on particular soldering iron tip maintenance product
                    by kalemaroni
                    Has anybody tested this product? Posting this question on a Facebook tech group I'm in got a few responses like "that kind of thing corrodes the tips" and "just using normal solder paste is much better" so I'm not looking for generic responses like that, but rather, does anybody know for certain whether this exact product is good or bad for soldering iron tips?
                    04-12-2024, 03:52 AM
                  • tony359
                    Kaiweets USB soldering iron
                    by tony359
                    I am testing a USB powered soldering iron. It's made by Kaiweets but I believe it's also sold under other names.
                    As a standard test, I checked whether there was any voltage leak from the tip - that said the thing runs on USB-C power delivery so am I correct that the whole unit is floating and not grounded? If I check, I measure 90V at the tip but I have a feeling that that is not relevant? Maybe caused by that capacitor between primary and secondary inside the PSU? I do not see current flowing at all.
                    In other words, do you think it's expected and...
                    02-06-2024, 12:51 PM
                  • Peter_1402
                    Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                    by Peter_1402
                    Hi Everyone,
                    I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                    1. Soldering iron works great
                    2. There is a burnt mark on the hot air gun handle.
                    I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                    Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                    Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                    Reed switch tested ok with a magnet.
                    From the above test, I can conclude...
                    07-12-2025, 11:50 AM
                  • acedogblast
                    by acedogblast
                    11-02-2024, 05:13 PM
