How to avoid Liquid Damage due to Soldering
  • caspian
    • Oct 2015
    • 1589
    • Laptop
    Dear Technicians,
    I have a bad experience in soldering:
    Two months ago, I soldered the point of PJ801 (in the photo) on a laptop mainboard using flux and leaded solder. Then, I cleaned the area using pure paint thinner. I did not used any other substance. but there was still some flux residues which I refused to clean. I did this because I did not want to use too much thinner.
    Today, the customer came back. I opened the laptop and observed one side of the capacitors in the area got a dark color. Even the solder of PJ801 became dark. This is what happens to capacitors when they get liquid damaged. but the other pins of the components look shinny.
    In the photo, I noticed that the flux residues are gray-colored too. Probably, the thinner made brown flux turn gray.
    Now my questions are:
    Why have this liquid-damage happened?
    What did I do wrong in that soldering?
    Was the liquid-damage due to flux residues or something else?
    note: I do not use my isopropyl alcohol because I used it sometimes but it had the following problems:
    1- It could not clean the flux completely.
    2- It could not clean glue from the board.
    3- It leaded to liquid damage too. It may be mixed with water by the maker.
    Then, I decided to use paint thinner which is stronger and can clean flux and glue completely.
    thanks
  • diif
    • Feb 2014
    • 6978
    • England
    Re: How to avoid Liquid Damage due to Soldering
    I always and only use 99% Isopropanol for cleaning boards and flux. It doesn't cause any damage and dries perfectly leaving no residue. IPA is hydroscopic, it absorbs water but stored and dispensed properly and this isn't an issue. I use an antistatic brush for stubborn parts and foam swabs to clean up. I've never had any issue with a board after repair and clean up.
    What's in the paint thinner you used ? there's many types/formulations.
    The customer either spilled liquid in the exact same place, or what was in your paint thinner/flux did the damage, not being cleaned properly.
    What flux do you use ? some are water based.
    • caspian
      • Oct 2015
      • 1589
      • Laptop
      The thinner is colorless and is called "Instant Thinner". Its ingredients were not mentioned by the maker. It was recommended for cleaning nitro cellulose paint, clear lacquer, polyester lacquer, putty, primers, and washing industrial components. It does not seem to contain water, because it completely evaporates when I leave a drop of it on a surface.
      The flux is an ordinary liquid flux made by an unknown maker. It may contain water, but I do not know. It is pretty oily and looks like a solid paste flux that was heated and became liquid. When I leave a drop of it on a surface, it gets dry and solid after a few days.
      The flux is brown. When I pour thinner or isopropyl alcohol on it, it turns dark gray.
      I found a photo that looks like the thinner which I use.
      Any ideas on why the capacitors turned gray in one side?
      In general, what substances can make such a damage on capacitors?
      • diif
        • Feb 2014
        • 6978
        • England
        Only you can tell if the liquid has come from the customer.
        If its not from the customer it's from you. I use genuine Amtech 599 no clean tacky flux, cleans away easily with Isopropanol.
        Perhaps when you didn't clean the board properly, heat made what was left on the board flow towards the caps and that's what damaged them.
        • caspian
          • Oct 2015
          • 1589
          • Laptop
          Probably, there was no liquid by the customer.
          can flux residues damage the capacitors like what happened?
          • diif
            • Feb 2014
            • 6978
            • England
            Decent flux won't, neither will isopropanol.
            • caspian
              • Oct 2015
              • 1589
              • Laptop
              I have to change my cleaning methods.
              If we consider flux residues that were mixed with thinner and turned dark gray, cam them damage the capacitors like what happened?
              Is it possible the instant thinner makes solder joints weak? or no such problem to worry about?
              • caspian
                • Oct 2015
                • 1589
                • Laptop
                Oops, I had typing mistake.
                Edition of the previous post:
                If we consider flux residues that were mixed with thinner and turned dark gray, can they damage the capacitors like what happened in the photo?
                I can think dark gray flux may be not the same substance as brown flux. it may be a harmful substance to solder joints.
                  • 31012
                  does that chemical feel greasy on your fingers?
                  it looks like white spirit.
                  post a foto of the label, there should be an MSDS datasheet for it.
                  • storm12
                    • Feb 2018
                    • 8
                    • United Kingdom
                    As diif said above, best thing is to use quality flux and 99.9% purity IPA. I use amtech 559 no clean flux as well and never had problems. Since you are not sure what that thinner contains I don't think it's a good idea to use it as you don't know how it will affect the components or how the chemicals react to the flux you're using and may cause more damage.
                      • 31012
                      amtech flux may be a problem,
                      the u.s. sellers may refuse to ship because of sanctions and getting it via china is asking for trouble.
                      probably 95% of it would be fake.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        There is no problem with genuine Amtech 559, agreed most on ebay is fake, insatint is a genuine UK seller on ebay though.
                        • storm12
                          • Feb 2018
                          • 8
                          • United Kingdom
                          I think problem might be procuring genuine amtech in Iran.
                          Maybe insat are shipping there? caspian, it might be worth asking http://www.insatinternational.com/
                          • caspian
                            • Oct 2015
                            • 1589
                            • Laptop
                            Thanks for all the replies.
                            Finally I found the problem:
                            I discovered that the board was exposed to a bit of water. most areas of the board are clean now. but the points that contained my flux residues, absorbed the water. So only those points were damaged on the board because those points made the water to stay. This is what happened to the capacitors.
                            The flux residues did not damage the capacitors directly. because I used the same flux and thinner on another board and it is still fine.
                            At least, we learned something.
                            • storm12
                              • Feb 2018
                              • 8
                              • United Kingdom
                              Glad you figured it out!
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                Never trust the customer when they said they haven't spilled anything...
                                A working TV? How boring!
                                  • Jul 2011
                                  • 6039
                                  This is the flux remover that I use it works very good and you only need a little bit dose a lot
                                  • acedogblast
                                    by acedogblast
                                    11-02-2024, 05:13 PM
                                  • rilley
                                    MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
                                    by rilley
                                    I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
                                    I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
                                    My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
                                    And the resistor L4004 is literally burned.
                                    From what I see from the schematics, it does not affect any other rails, only the connection to the display...
                                    07-10-2024, 01:57 AM
                                  • mitchw
                                    MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
                                    by mitchw
                                    Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
                                    It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
                                    I quickly took it apart and washed the liquid residue off the mainboard.
                                    The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
                                    The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
                                    Now the laptop...
                                    07-16-2025, 07:55 AM
                                  • larrysito111
                                    dell alienware m17 r5 LA-L761P liquid damage no image on lcd 2red 7blue runs on external
                                    by larrysito111
                                    got here a liquid damaged alienware
                                    the laptop had damage in the area of the kb9542qf2 all sorted and now laptop working and turns on but i have no display
                                    so if i start and connect usb-c display it works otherwise it is giving me the 2red and 7blue
                                    so with the usb-c external monitor is getting to bios and OS
                                    otherwise not
                                    so if it is in the os and i connect another lcd via onboard hdmi it is working no problem 2 lcds (1 usb-c + 1 hdmi)
                                    but still not the internal monitor
                                    (tested 3V and 5V going to the...
                                    06-12-2025, 04:16 PM
                                  • grimacelord
                                    Lenovo IdeaPad 5 ITL05 | LA-K321P | Liquid Damage & No Charging
                                    by grimacelord
                                    I have an LA-K321P board here that came to me for no power. Upon visual inspection of the board, I found some liquid damage around PQB13 area. Replaced PQB1, PQB2, and PQB13. Laptop will power on if the battery has a charge, but the computer will not charge the battery. USB Type C meter shows 20V being negotiated, but virtually zero amp draw (0.0100 at most that appears for a brief second about once every 5 seconds or so). Looking through thermal camera, UT1 (SN2001024YBGR) is getting hot. I have schematic, but no board view. Was hoping someone could help me get this charging...
                                    01-06-2025, 09:23 AM
