MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
  • mitchw
    • 138
    • Slovenia
    Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
    It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
    I quickly took it apart and washed the liquid residue off the mainboard.
    The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
    The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
    Now the laptop boots into OS only if the main LCD is disconnected.
    If I leave it connected, it will power on for about 15 seconds and then reboot. No image on the screen whatsoever.
    Sadly, I don't have another LCD to test, so I am not 100% if it is LCD or the mainboard that is at fault.
    PPVOUT_LUXE_XW is 11.5V which it too low from what I can tell, but it might be just an indication of a bad LCD.
    Any other tests I can do?
    Customer is happy that their data is still intact, but it would be even nicer if the laptop gets repaired.
  • mon2
    • 14377
    Test with external monitor. Do you see all graphics?
    • mitchw
      • 138
      • Slovenia
      Yes, it works with external monitor with no problems. I can log in to system, etc.
      • mon2
        • 14377
        Remove all power. Meter in resistance mode. Measure the resistance to ground of PP3V8_AWAKE_TCON. You should be able to do so at RD892.
        Measure the resistance between PP3V8_AWAKE_TCON_ISNS and PP3V8_AWAKE_TCON_ISNS_R. This measurement should be 0R ohms on your meter.
        • mitchw
          • 138
          • Slovenia
          PP3V8_AWAKE_TCON = 0.570 diode / 2 Megaohms resistance
          Between PP3V8_AWAKE_TCON_ISNS and PP3V8_AWAKE_TCON_ISNS_R I get 0 ohms
          • mon2
            A1466 Macbook Air (Liquid damage repair)
            by mon2
            Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
            Macbook AIR Model A1466 Diagnostic 09-01-2021
            Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
            Problems & Resolutions
            1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
            09-01-2021, 09:31 AM
          • rilley
            MacBook Pro 13inch 2017mid (A1706 820-00923-A) - liquid damage - USBC and Display short circuit
            by rilley
            I am new into this, sorry to post it here. I want to make this as a pet hobby project, as this mac is not urgent.
            I have (Macbook Pro 13inch 2017mid) A1706 820-00923-A
            My mac had liquid damage a long time ago, the connector from J8500 is damaged on pin 46 (PP5V_S0_ALSCAM_F), I guess the LCD/display panel is in short circuit, as I saw the connector from the LCD burned as well.
            And the resistor L4004 is literally burned.
            From what I see from the schematics, it does not affect any other rails, only the connection to the display...
            07-10-2024, 01:57 AM
          • Jenzo
            MacBook A1989 overheating after liquid damage
            by Jenzo
            Hey everyone,
            Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
            I can't figure out how...
            05-13-2023, 07:58 AM
          • MrBojangles
            MacBook Pro A1989 liquid damage
            by MrBojangles
            Hi!
            First post here...
            MacBook Pro A1989 (820-00850-A) with liquid damage showing 5V.
            I clean the board with alcohol and I get 20V. Fans spin but no chime or image.
            I then check the board with a thermal camera and see a component, Q7030, that is hot. I clean extra around this area and now I'm back to 5V.
            So... that means it's time to learn how to use schematics and boardview and what I've learned so far is that PPBUS_G3H is the "always on" power mode.
            I've checked multiple components pertaining to PPBUS_G3H...
            07-31-2024, 02:00 AM
          • martyjelen
            Macbook A1708 - 5V/0A -no power- liquid damage.
            by martyjelen
            Hello, I have macbook a1708 with some liquid damage on PCB.
            I alredy tried to clean PCB with IPA. Stuck at 5V/0A
            PPBUS_G3H is missing > 0V
            I removed fuse F7000 to check voltage, but it's still the same > 0V.
            Diode reading on pad 1 is 576
            Diode reading on pad 1 is 460
            What should I check now? Thanks
            Martin
            06-12-2023, 04:10 AM
