Soldering Wick Reuse or Replacement
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Dear Technicians,
    Soldering wick is expensive.
    Is there any way to clean and reuse a used soldering wick?
    or
    Is there any thing cheap among home tools which can be used instead of soldering wick?
  • R_J
    • Jun 2012
    • 9588
    Re: Soldering Wick Reuse or Replacement
    In a word, No. for removing large amounts of solder from larger connections, you could use a desoldering pump, but don't use it on small delicate traces as you can lift them.
    • Fast Alpha
      • Feb 2013
      • 245
      A pencil for clearing old the hole, heat the solder first to melt then add a pointy pencil tip to clear it.
      Solder does not stick to stainless steel, maybe some steel to scoop up the solder?
      http://www.hse.gov.uk/pubns/indg305.pdf
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        It would be great if solder could be cleaned from solder pads by some cheap way or if solder could be cleaned from a used soldering wick by some cheap way.
        I think cleaning soldering wick seems more practical. For example, we can put a used soldering wick in a hot substance so that solder gets melted and then gets out of the soldering wick.
        Is there such a method?
          • 31196
          no.
          there are other ways to clean off solder though - but the tools cost more.
          • petehall347
            • Jan 2015
            • 4438
            look for acid that eats solder and not copper .
            or use electrolysis .
            let us know how you get on ..
            this has sparked something off with me .
            clean copper is worth lots more see .
            • eccerr0r
              Solder Sloth
              • Nov 2012
              • 8701
              Copper is more reactive than lead or tin, so likely you can't get an acid that will eat solder (one for lead and one for tin) but leave copper; also you have oxides to deal with. The only thing that separates copper, tin, and lead is heat - copper has the highest melting point of the three, but they will all want to stick together no matter what. After all, wick is made of the same stuff as wire.
                • 31196
                there are chemicals that will eat tin/lead but leave copper,
                there are company's that can strip expensive chips and re-plate them to RoHS standards.
                they can also re-ball using robotic desoldering units that use a laser!!
                however - it's not cheap - so you only do it for rare or expensive stuff.
                  master hoarder
                  • May 2008
                  • 12175
                  Originally posted by caspian
                  Dear Technicians,
                  No.
                  As others said, copper and solder like to stick together. That's why soldering wick works.
                  Depends on what you are trying to do.
                  If you just want to clear holes (vias) from capacitors and other through-hole components, you can use a stainless steel needle to punch through the holes while heating them with your iron.
                  If you want to clean small SMD pads, an iron with a sharp copper tip *could* do that, but it takes some practice. I do it all the time with my 30W Radio Shack iron. Its stock copper pencil tip became a spoon-like shape with sharp edges a long time ago (from normal use). When I swipe the tip on a well-fluxed BGA pad, I can usually scoop most of the solder out of it and barely leave anything behind.
                  Now if you are doing BGA work and need to clean BGA pads.... there's no replacement for wick. However, if you want to use less, then try to pick up as much of the old solder as possible with a hot sharp tip.
                  When I used to do BGA work, I could last 2-3 times longer with my wick compared to other techs with this method. And this method did not do any more damage to the board.
                  • Th3_uN1Qu3
                    Believe in
                    • Jul 2010
                    • 6031
                    There is replacement for wick in BGA rework: A spatula made of high temperature silicone. I never believed it until i tried it myself and it works a treat. You may still have to use wick for the last pass but it sure cuts down on the amount of wick you need, also reduces the risk of pulling pads or scratching the solder mask to basically zero.
                    A working TV? How boring!
                      master hoarder
                      • May 2008
                      • 12175
                      Interesting.
                      I knew high temperature silicone could be used to clean up solder pads, but I never thought about it for BGA. Genius!
                      That said, another way to minimize wick use is to use a fairly large chisel tip to move a solder pool/blob around the BGA area and basically pickup all the solder that you can without wick (the solder will try to stick to your liquid solder pool/blob and very little will remain on the pads). I used to do this all the time and used 3-5 times less wick than most coworkers back when I was ballin' with Xbox 360s.
                      • Th3_uN1Qu3
                        Believe in
                        • Jul 2010
                        • 6031
                        That goes without saying.
                        • Snayperskaya
                          • Nov 2015
                          • 46
                          • Brazil
                          Can you make soldering wick by reusing old coaxial cables' copper mesh? Does it need a reagent/flux to increase the solder absorption?
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            Coax cable copper mesh has some problems:
                            1 - You'll need to get some that have very fine mesh, a lot of it is pretty coarse and doesn't have as much surface area as real wick
                            2 - All of the used cable I've seen, the shield braid mesh tends to be quite oxidized. Some of it doesn't seem to be copper but rather seems to be steel. Of course if you can get copper, that's best.
                            3 - yes, you need lots of flux.
                            • acedogblast
                              by acedogblast
                              11-02-2024, 05:13 PM
                              Multifix 425-01 and 450-01 Rework Flux Datasheet
                              REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                              - No Clean Formulations
                              - Low residue
                              - Range of activity to deal with different component solderability
                              - Halide free
                              - Suitable for dispensing
                              - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                              Both products are supplied in syringes or cartridges for application by dispensing....
                              10-07-2024, 06:02 AM
                            • ktmmotocross
                              recommend good solder wick on aliexpress
                              by ktmmotocross
                              I get som bad cheap wick that im furious with so i need to order wick that suck solder like it should. best on aliexpress...
                              02-08-2024, 12:48 AM
                            • Geeker007
                              Friend messed up my laptop motherboard while working on my bench
                              by Geeker007
                              Hi All,
                              So my friend was visiting and he wanted to use my solder bench to solder on some WLED circuit board. My laptop was open on the side for RAM upgrade. I know my mistake.
                              So while soldering he had too much solder on the soldering iron tip and he just shook off the soldering iron on the table itself to remove extra solder on the soldering tip and it landed on the motherboard of laptop. He then out of fear tried to remove it using solder wick and did more damage by removing some components as well. So here I am with weird situation.
                              I have not tried putting...
                              06-16-2025, 01:40 PM
                            • Geomih
                              CPU socket replacement soldering profile
                              by Geomih
                              Hi All - I am hoping someone can help with some pointers (complete noob here!)
                              I have recently purchased a Scotle HR460 BGA reball machine (it's a bit old and I think the company no longer exists either), but as far as I can tell it is a competent and unmolested machine that should be good enough for my needs.
                              My biggest problem is that it came with no profiles, and I must re-create all of them from scratch, something that is very scary for someone that doesn't really know what they are doing.
                              The simple stuff like a small memory module isn't a big deal because there are
                              12-11-2023, 11:07 AM
