(Short rant) Screws !
  • Nitro468
    • Oct 2013
    • 65
    What the hell is up with screws ! A simple Phillips #0 or #1 screw.. 6 dam screwdrivers later and still nothing that fits well... I could see if I was using crap, but we are talking quality tools, Snap-On, SK and a few other well respected brands....
    EOR (End of rant)...
  • R_J
    • 9592
    Re: (Short rant) Screws !
    JIS - Japanese Industrial Standard not Philips
    http://www.vesseltools.com/hand-tool...-products.html
    • Nitro468
      • Oct 2013
      • 65
      I have a few of those also, sometimes nothing seems to fit well. I was just trying to be general. Its the quality of the screws... Probably from China not Japan... I am used to JIS fasteners in my main industry. (Auto Tech) I have a myriad of tools for fasteners and it keeps growing... Phillips, Prince Reed, Posi-drive, Allen, Torx Torx Plus, some 5 point Torx I don't know the name of, plain and tamper proof. 12 point stuff... And probably 25 different security screw bits. Pentalobe.... Just sometimes it drives me nuts.....
      • R_J
        • 9592
        Sometimes the metal for the screws is crap, almost like aluminum, may times I have had to use my side cutters to grip the screw to break it loose.
          • 31214
          some screws really are aluminium - specially if they are in stuff sensitive to magnetic fields.
          i have lots of them salvaged from harddrives.
          • japlytic
            • Oct 2005
            • 2086
            On a piece of test equipment, I saw a yellow sticker warning that this equipment uses metric screws.
            • TechGeek
              Computer Geek
              • Jan 2015
              • 2254
              Metric screws? Aren't those screws that use metric sizes?
              Sidenote: You just don't see that kind of quality these days. It's getting very bad nowadays.
              Permanently Retired Systems:
              Kooky and Kool Systems
              sigpic
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                When I have a misbehaving Philips or JIS screw, I use a flat head screw driver. Most of the time, that can get out screws even with very stripped heads. If not, I take it to Mr. Drill down in the garage.
                I've also used a flat head many times to remove security torx screws. Works great. Haven't found the need to buy security torx yet.
                Oh, and star drivers can often be used to drive hex heads.
                • Longbow
                  • Jun 2011
                  • 623
                  A painful subject for those of us who have torn rotator cuffs from years of working with phillips screws of all kinds. Notice how these days they sell the bit along with a box of construction screws? Each manufacturer uses his own Phillips profile. Mr. Phillips started it by inventing a fastener that would "self limit" installation torque by kicking the bit out of the screw during automotive production. Note, a Phillips screw by design is meant to kick its bit out at a certain torque. Even tapered square drive will kick out the bit at a certain torque. Star-Torx is the way to go, except for those gorillas that don't know when to stop tightening.
                  It doesn't help if there are a dozen types of phillips sizes and head designs either. And I have yet to find a JIS bit at the local hardware store. Typical types are all sorts of "regular" nameless profile phillips - whatever that means. Then we have Reed-Prince, Posi-Drive and now Phillips-Square as if we need another one.
                  Phillips JIS bits are needed for 95% of consumer electronics since the fasteners are made you know where. I do keep my cordless impact driver handy for stuck fasteners. In my opinion we can now stop making and using Phillips fasteners. Good riddance!
                  Is it plugged in?
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Sorry for necro.
                    Plain security torx? Yes.
                    Why this sucks? because I already have one of those ¼" hex drive interchangeable tip security torx driver from T10 to T40 but the ¼" hex shank does NOT fit down the hole... :-(
                    Note how blurry the foreground is compared to the screw head, hooray for bokeh to tell the story!
                      • 31214
                      that's the "new" security - put the screw down a 2" hole!!
                      you can buy security torx and hex that look like alen keys to get around that.
                      but for tri-wing and the 2 holes(snake tongue??) you have to fab something with a cheap screwdriver and a dremel
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        The device isn't even worth the cost of a new security torx bit set
                        BTW the two holes bit is called "Spanner" not snake eyes...though this sort of conflicts with wrenches...
                          master hoarder
                          • May 2008
                          • 12175
                          • Bulgaria
                          More work for my drill, I guess.
                          But yeah, those security bits can be annoying indeed - especially when burried deep in a hole... and even worse, if the security bit is weak and prone to rounding/striping. On that note, the worst are those one-way flat-head screws (not sure what you call them, but the ones that only let you tighten the screw and not turn it backwards, because of the way the driver slot "ramps" back to kick the driver out.)
                          • eccerr0r
                            Solder Sloth
                            • Nov 2012
                            • 8701
                            Hmm...true, perhaps I should just drill out the whole head.
                            Yeah those tamper proof one way "pre-stripped" flat head screws are the worst (You got the name right I think, "one-way"). They were specifically meant for people to never work on it ever again, unlike all the other security torx, spanner, security hex, tri wing, etc. - at least these were meant for servicing, just not anyone from servicing.
                            I guess I don't have too much issues with screw bits like pozi driv ... while annoying, they do try to prevent stripping, as long as you're not using a philips screwdriver...
                            OH YES!!! Was looking through my junk pile and found... a security torx allen wrench! Finally can open this stupid ancient NiCd battery charger that uses a mechanical timer!
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              But luckily, I haven't seen them used much on electronics, though. (If at all.) Mostly see them in public place bathrooms (malls, gas stations, and etc.), probably so that someone can't take things apart in the bathroom, lol.
                              Nice and nice! (regarding both the security torx and the mechanical timer.)
                              Mechanical timers are pretty dependable... or at least I like them for their simplicity. Probably not the best way to charge a Ni-Cd / Ni-MH battery, though. Then again, at least it's better than those high trickle-charge chargers that ruin the batteries... or worse, cheap (older) RC cars that didn't have any timer or regulator at all - just dump constant high current into the battery until it's dead. That said, though, Ni-Cd and Mi-MH batteries (but especially Ni-Cd) tend to be quite forgiving to overcharging.
                              • eccerr0r
                                Solder Sloth
                                • Nov 2012
                                • 8701
                                Wondering if I should part this thing, or mod it to be more useful. I don't have any 7.2V NiCd cells so I don't have much use for the charger. Could use the parts, though not sure if the mechanical timer is immediately useful in this device (would be nice if it could stop discharging/charging before overdischarge/overcharge).
                                Very simple device it seems, just transformer, bridge rectifier, few power resistors, a meter, a DPDT switch, and the timer.
                                Actually what would be useful is the mechanical timer in the car to power circuitry always hooked up to the battery so you could use without key in the ignition... this way it will at least shut off if you forget and not end up with a dead battery.
                                • howardc64
                                  by howardc64
                                  Problem
                                  08-04-2024, 10:36 PM
                                • DynaxSC
                                  Extreme High Current & Low Voltage Short Killer ??
                                  by DynaxSC
                                  Hi Folks
                                  I'm looking for a extreme high current short killer solution for a reasonable cost.
                                  I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
                                  After taking off the socket, the shorts dissappear again.
                                  The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
                                  10-15-2024, 10:13 AM
                                • Stephen
                                  MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
                                  by Stephen
                                  I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
                                  02-06-2025, 12:03 PM
                                • adelfr2009
                                  HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
                                  by adelfr2009
                                  I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
                                  After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
                                  09-28-2025, 10:21 PM
                                • Victor Moreira Silva
                                  Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                                  by Victor Moreira Silva
                                  I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                                  Well, my decice specs are the following:
                                  Model: Acer Nitro 5 AN517-54-55T5
                                  CPU: Intel Core i5-11400H
                                  GPU: NVIDIA GeForce GTX 1650
                                  Motherboard: GH51G LA-L181P Rev:1c
                                  The symptom:
                                  When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                                  05-26-2025, 10:49 AM
