Rework Station Pump - Can They Be Repaired ?
  • shahnld
    wds-580 rework station issue
    by shahnld
    Good day.
    i received used bga rework station wds-580 which was not going above 300c despite the parameter was set to 350c, Everytime beeps at 300c so i did a factory reset and by mistake washed data and log etc. now the station boots to a white screen.
    Does anyone has a firmware for this station and want to share with me. i will really appreciate any help possible..
    kind regards...
    03-28-2024, 01:14 PM
  • minimania
    Need Schematic for jbc am6800 rework station
    by minimania
    hi all im looking for a Schematic for jbc am6800 rework station
    mine has stopped working fully
    it started with turning off when switched on then after a few off and ons it worked sort of for awhile
    now it wont turn on at all...
    01-28-2025, 03:44 PM
  • shahnld
    Seamark ZM-R6200 Rework station
    by shahnld
    Good day Experts.
    I have recently aquired a rework station SEAMARK ZM-R6800,. Is there anyone using this or some other similar station and give me some info about profile temp curve etc for removing leadfree soldered gpu chip..? just 1 profile will be enough to get started.
    Kind regards
    01-24-2024, 10:55 AM
  • petemanuk
    Help with IR6500 rework station
    by petemanuk
    I been playing with a recently acquired IR6500 rework station and watching lots of YouTube tutorials to see how to use it with not much success. I’ve only recently joined badcaps but going through the forums there is a lot of knowledge here, so though it best is if I ask my question here.
    1. Firstly is the IR6500 any good for BGA rework or should I be spending my money on a better one.
    2. The instruction manual is pretty useless on explaining how to set the PID loops (no information at all!!) both top and bottom heater for th Kp, Ki and Kd...
    10-14-2022, 12:31 AM
    ZD desoldering station pump rebuild
    by stj
    just did one.
    works great.
    so here's the discoveries.
    the pump "modules" have 4 parts, the main body, the outside bit, the inside bit - screwed to the main body, and the diaphram.
    the failure is the inside bit, it has a rubber coating for some reason that becomes tacky and breaks down - contaminating the diaphram.
    so you need to clean everything to get rid of all the tacky black stuff.
    then reassemble it.
    *BUT*
    you must put the 2 screws into the assembly only finger-tight.
    if you tighten it properly the valves dont work....
    08-21-2024, 05:59 PM
