Help on replacing USB port
  • Agent24
    I see dead caps
    • Oct 2007
    • 4950
    • New Zealand
    I just went to plug in a USB cable to the soltek board I successfully recapped, to find that the plug didn't stay in.
    Now I notice that the middle plastic bit is missing and the pins are bent.
    I can easily scavenge a new port off a scrap motherboard, but the question is how to desolder a new one without damaging it, and how to remove the broken one without ruining the board?
    Obviously there's more pins than a capacitor, not going to get away with the same removal method...
    -David VanHorn
  • kikkoman
    • Jul 2007
    • 691
    Re: Help on replacing USB port
    almost impossible.
    if it's a USB+LAN port, it's even more difficult.
    the data pins are doable (using wick or solder sucker) but i've found the biggest problem to be the shielding metal which is REALLY undesolderable. you usually don't have good access to it from above so you can't cut it off.
    you'd need a 100W iron but I doubt the board stands that much heat.
    if it's your own board, you can solder a USB bracket (for the rear slots) to the data/power lines. a bit ugly, but it works.
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • zandrax
      Hit and miss
      • Dec 2007
      • 1157
      • Italy
      Try a workaround: a PCI USB 2 card (better those with Nec chipset) or an external hub.
      Zandrax
      Have an happy life.
      • Agent24
        I see dead caps
        • Oct 2007
        • 4950
        • New Zealand
        Well, I gave it a go anyway..... here's the story:
        Having several completely trashed boards was helpful, first candidate was a socket 7 something which I had already removed a lot of spare things from and decided to test an idea I had
        Took the solder wick to the data pins, they came undone easily, but there was still the shield to contend with... I figured I would do that one like a capacitor, being enough room between each side I heated up 2 of the legs from one side, and pulled to tilt it half out (note: this is where 2 soldering irons and another person come in handy).
        That side came free pretty easily, but when I did the same thing to the other side, I ran into problems. One of the data pins must have still had a bit of solder in the via when I pulled, and it got rather bent before letting go. Upon trying to straighten it, it broke off. Still, I knew the idea worked.
        So I got myself another board (CPU socket was broken) and proceeded to do the same method, this time making sure all pins were clear first! It came out with minimal hassle. (note: having some sort of heat insulation between your finger and the metal shield is a good idea here...)
        So now I had a new USB socket to put in the motherboard. Question was, could I get the old one out of the good board without causing damage?
        Well this is where I decided to get creative - instead of trying to keep the socket intact (as it was already broken anyway) I decided to dismantle it. Using pliers I broke the plastic inside part out and was left with a metal shield and the data pins. I then cut the shield in half along the top and pulled each half and each pin out by heating and removing the usual way. Only one iron was used.
        The leftovers of the broken USB socket. It's still broken
        The holes cleaned out ready for the new socket
        Soldering in the new one was as easy as pie, of course. Then to test if it worked.
        Before thinking you've destroyed your board, please plug this in first. it helps a lot:
        End result: 2 new working USB ports on the board
        -David VanHorn
        • shadow
          • Feb 2007
          • 732
          Wow!! Nice work there.
          Oh and by the way. Congratulations!
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            good work indeed
            • Newbie2
              • Sep 2005
              • 885
              Great job!
              My buddy (electrical enginner) did one of those repairs once with the exact same problem of broken USB ports, but I was surprised as he did it like a standard routine repair with no difficulty.
              My gaming PC:
              AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
              ASUS M4A77TD AMD 770 AM3 Motherboard
              PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
              G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
              TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
              WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
              ASUS Xonar DG 5.1 Channel PCI sound card
              Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
              Antec Three Hundred Mid-Tower Case
              Microsoft Windows 10 Pro 64-bit
              Microsoft Windows 7 Ultimate SP1 64-bit
              • zandrax
                Hit and miss
                • Dec 2007
                • 1157
                • Italy
                Nice work: reading Kikkoman words, I doubted it could be feasible.
                Zandrax
                Have an happy life.
                • gdement
                  • Jan 2007
                  • 690
                  I've done this once, but it took me forever. Eventually got it out and replaced but there was some cosmetic damage from burning the PCB with the solder sucker.
                  I like that idea of cutting up the shielding from above.
                  • gonzo0815
                    • Feb 2006
                    • 1600
                    Well for that kind of task i still have my 80w cheapo iron.
                    • SluggerB
                      Help with trying to fix phone that is not charging (Pics inside)
                      by SluggerB
                      I have two TCL A30 phones.
                      Old Phone: This phone worked fine for years, then stopped charging If you plugged a charger into it, the phone would make the charging sound, the phone would tell you it is charging, but the battery icon would not have the charging symbol in it and the battery would not charge.I tried new battery, same behavior.
                      New Phone: Works fine, bought as a donor board to try and repair Old Phone
                      My interest here is to repair Old Phone, using components parts off New Phone if needed. I am not interested in replacing Old Phone with New Phone....
                      08-12-2024, 08:11 AM
                    • fredyjbi
                      please help, friend, thinkpad L480 NM-B461 rev 1.0 JDOCK1 type C port 5volt only, thank you
                      by fredyjbi
                      I have a thinkpad L480 NM-B461 rev 1.0 laptop functioning normally with Type 1 port (JUSBC1)
                      if you use port type C 2 (JDOCK1) with a usb type meter it only displays 5v, thank you
                      I tried to look at the schematic diagram USBC_VBUS20, which is the port path from JusBC 1 to U4701 then goes to the system2 charging IC, why is there no system2 path leading to the charging IC on the TYPEC_VBUS20 port which is JDOCK1, thank you for your help.
                      if you look at the power sequence there must be 2 types of port type C a (JUSBC1) via U4701 and port type C b (JDOCK1)
                      On the type...
                      07-09-2024, 11:28 PM
                    • JaquesPratt
                      Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                      by JaquesPratt
                      I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                      This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                      07-16-2024, 01:04 AM
                    • theBread
                      5V only on EL580 NM-B461
                      by theBread
                      Hi 😄
                      I have a NM-B461 board that doesn't boot up.
                      Current observations:
                      • The board has no obvious damage, corrosion or previous tempering
                      • I measured the voltage on the TYPEC_VBUS20 and USBC_VBUS20 lines (which are the rails that get powered first according to the schematics) - the dock port measures 5V and the direct port 0V.​
                      • USBC_VBUS20 (the rail from the direct port) measures 0.3V when powered via the dock port?! There is no short between those lines tho and there is no connection in the schematics.
                      • None of the power rails are shorted to ground
                      • Diode measures (red
                      05-11-2025, 10:19 AM
                    • corrize
                      Where to find a very small fpc connector 0.3mm between 2 pins ?
                      by corrize
                      Hello, I search this connector (oxydated).
                      It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
                      I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
                      I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
                      Do you know how to find this connector please ? What is the exact name for find it ?
                      08-06-2024, 05:25 PM
