Help needed getting an ESR meter...
    replied
    Re: Help needed getting an ESR meter...
    https://www.badcaps.net/forum/showpo...1&postcount=14
    See page 13 of the PDF on the rotary encoder.
    replied
    most suppliers sell them, but not with prices that can compete with ebay.
    replied
    Digikey sells them.
    http://www.digikey.com/product-searc...coders/1966131
    http://www.digikey.com/product-searc...=0&pageSize=25
    replied
    btw, it just dawned on me you can find a rotary encoder in a mouse wheel - although not the type for fitting to the board.
    replied
    it's a passive device, but it's not a case of up / down contacts.
    the contacts switch in order based on the direction you spin it.
    as for ebay, search the part "ec11 a617" there are a number of sellers.
    there are cheaper ones sold in 5's but they look like shit.
    here:
    http://www.ebay.com/itm/181361695762
  • vinceroger69
    replied
    once stj has verified its in the firmware etc i bet a few of us will do the mod if stj gets it working and dosntmind posting pics and how to do the mod.I need to learn how to use my old tester first better yes im fine on testing capacitors and resistors but when it comes to testing transitors etc im still learning what a good or bad reading should be.
  • SteveNielsen
    replied
    Ok, so it's not a passive device then. There isn't a lot of explanation that I can find online as to how such a device actually works. I am left to assume it produces some sort of timed logic pulses?
    BTW, the part you linked to does not ship to the US.
    replied
    no.
    i found this:
    http://www.ebay.co.uk/itm/231241921964
    will order one and see how well it fits - and if it's enabled in the firmware!
  • SteveNielsen
    replied
    Thank you. Wouldn't a DPST momentary-on pushbutton switch do the same thing?
    replied
    Rotary Encoder.
  • ivtec
    replied
    I use this one and it's pretty good.
    https://www.youtube.com/watch?v=Rkzj9Z4GQ7c
    replied
    they arent cheap, half the cost of the tester for a cheap one.
    atleast from suppliers - i have not checked ebay. (yet)
  • SteveNielsen
    replied
    Thanks. I guess the question should be can you give me an example of one I can get that would work with the tester when I get it?
    replied
    rotary encoder looks like a pot but goes 360' and often clicks as you turn it.
    it has a pair of switch contacts in it.
    the good ones also have a switch in them that is under the shaft so you push the knob to "select" stuff.
  • SteveNielsen
    replied
    Originally posted by stj
    rotary encoder schem is in the pdf, it also needs 4 resistors.
    the zener circuit is on the forum i think was linked in a previous thread.
    or a seperate one i posted about in a previous thread that works with your multimeter.
    Ok, I see that, thanks. I guess I don't understand what a rotary encoder actually is. Some kind of dual-pole switch with a knob? I'm sure I must have seen one on something or somewhere and didn't pay attention but I'm in dense-mode and drawing a blank here... getting older sucks.
    Ok, let me re-ask, what TYPE of rotary encoder will work?
    replied
    Originally posted by csh
    I bought this one because of ZIF socket.
    If desoldered cap has really short leads you have to hold it on the contacts for SMD elements. Kinda pain in the ass to work with.
    Interesting.
    Was checking some datasheets, is vloss the same as "Dissipation factor"?
    I see some models have leads with hooks. Would that help with measuring desoldered caps with short legs?
    they dont come wih the hooks - only the wires.
    it's more usefull with big transistors & stuff, but you could use it for caps.
    keep in mind the cable length may effect the esr reading.
    replied
  • SteveNielsen
    replied
    @stj: Do you have schematics/info for the rotary selector and/or zener testing?
  • csh
    replied
    Originally posted by Joe Black
    OK, deffo getting some el-cheapo from Ebay.
    If it's good for stj and csh (*waves to neighbour*) it's more than good for me.
    you could still get caught.
    my new tester gives me capacitance, ESR, and Vloss (leakage)
    i'v found a number of used caps in my stash with good capacitance and ESR, but high Vloss.
    Interesting.
    replied
    the cable is included, the test-clips on the end arent.
    test clips
    http://www.ebay.co.uk/itm/371193424125
    hell that seller has everything imaginable!
    http://stores.ebay.co.uk/t-happy?
  • chth96
    Is it possible to test small ceramic disc capacitor with analogue meter?
    by chth96
    I read EBOOK of Testing Electronic Component and found that
    "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
    Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
    It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
    Is it really possible to test small ceramic disc capacitor with analogue...
    03-09-2024, 10:03 PM
  • jorpec
    Changing the scale of an analog meter
    by jorpec
    Hi
    I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
    I wonder how i can accomplish this so the meter would be precise at any temperature ?
    Thnaks
    01-23-2023, 10:37 AM
    How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
    by sam_sam_sam
    About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
    Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
    12-14-2023, 07:45 PM
  • Stephan Mathers
    EDMI ATLAS MK10 Electronic Meter Discussion
    by Stephan Mathers
    Greetings, new guy here but always interested in the crazy universe of modding
    We just finished construction of around 25 vacation houses, all inside the same private area.
    Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
    The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
    Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
    05-20-2025, 09:09 AM
    Bought a volt multi meter that is capable of data logging Hantek 365C USB/Bluetooth Data Logger
    by sam_sam_sam
    I have had this in my wish list for quite a while now and I might need to test BMS protection board with this device because of the limitations of the battery testing machine that I have been using
    https://www.aliexpress.us/item/32568...yAdapt=glo2usa
    What this will allow me to do is use my load testing machine that is having issues with the voltage cutoff set/ current meter monitoring system and I decided not to try to replace it or repair it I just going to use a very primitive load testing...
    03-30-2025, 11:05 AM
