Where to buy solder?
  • SteveNielsen
    Retired Tech
    • 2327
    Re: Where to buy solder?
    I ordered a small (50g) roll of 0.5mm 63/37 rosin core for a couple of bucks from the same place I ordered the ESR/Tranny tester (AliExpress). I don't need a whole lot of it usually.
    • clearchris
      • Dec 2013
      • 687
      My solder goodies came in!
      100g solder for $4.50.
      https://m.fasttech.com/p/1260006
      I haven't done a whole lot with it yet, but my testing so far is that its pretty good. Bought a cheapie stand to go with it too. Took about a month to get here, thankfully I ordered in advance...
        • 31197
        interesting stand.
        probably smaller than it looks though if that's a 100g reel of lead solder.
        my 250g roll of lead-free would fill it!
        • ahendricks18
          • Oct 2015
          • 16
          Amazon, radioshack, walmart (some of them), Lowes, Home depot. I get some there, usually from radioshack though. I also have a local HW store that has some nice Alpha Fry solder. I use that a lot.
          • clearchris
            • Dec 2013
            • 687
            Originally posted by stj
            interesting stand.
            A 500g would probably fit too. Lots of room as long as the sppol does not exceed the length. I dont think these are actually made for export. I bet these are in use in local factories in china.
            • acedogblast
              by acedogblast
              11-02-2024, 05:13 PM
            • corrize
              Best way to solder LVDS connector for beginner (and qfn) ?
              by corrize
              Hello, I'm a beginner for micro soldering. Right now I have some difficult to solder a qfn 20, I guess I put too much solder on the thermal-ground pad, the result is a corner of chip wich don't touch the board (last try).
              I use a wire solder with hot air, I tin the board and chip before with iron and I use good flux.
              I will have to solder a LVDS connector (40 pins, laptop pc), I saw a solder paste in seringe, good quality (it does not scatter).
              See the test :
              https://youtu.be/bNAzC-EvqHs?t=1767
              With hot air from bellow the board, that's...
              03-09-2023, 02:57 AM
            • petemanuk
              BGA solder balls not connecting - help pls
              by petemanuk
              So I though in my spare time I’d set myself up repairing motherboards mainly pin damaged lga1151 sockets types.
              I’m using an achi ir sc pro rework station (gave up on my Achie ir6500 - don’t recommend)
              I’ve managed to get my rework profile somewhere in the correct region (after a lot of trial and error) to get the old sockets off and reflow new ones back on again, the problems I’m getting is not all of the solder balls are re-attaching when re-flow occurs. I know this because when socket is removed pads still look clean and have no solder...
              11-16-2022, 05:21 AM
            • myth77
              UV solder mask - high temp resistent, recomendation?
              by myth77
              Can someone recommend any good UV solder mask? But i need a solder mask that will stand high temperetures. The thing is...sometimes i have a bigger cooper ripped from the board, lets say mosfet pad... i reconstract it with cooper sheet, then i "glue it" with solder mask...then i use UV light...and let it cool a bit. After, i try to clean the cooper of extra solder mask..and till that part all is ok. But, when i use a soldering iron to solder that pad/cooper...the solder mask gets weaker or destroyed and finally the pad is ripped again from the board .
              Is there any solder mask...
              03-28-2022, 04:04 AM
            • sircastor
              Solder not reflowing - what am I doing wrong?
              by sircastor
              I'm trying to fix a broken MacBook Air, and got a parts board to salvage components from. Following the suggestions of many folks here, I wanted to get in a little practice of using my hot air station (A Quick 957DW+) on the parts board so I know what kind of behavior to expect.
              For the life of me, I can't get anything done with this thing. I have tried multiple temperatures (from 210-425c), different air speeds, preheating the board (with the hot air, just warming it all around). I have applied what feels like excessive amounts of flux (Amtech V2-TF-559) and the solder on these components...
              03-03-2024, 02:44 AM
