Altronics T2380 Soldering station busted
  • pfrcom
    Oldbie
    • Jun 2006
    • 1230
    Re: Altronics T2380 Soldering station busted
    Originally posted by stj
    if it is a xytronics unit then the element is something like 36v
    The element is marked 32V/100W
    better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
    • pfrcom
      Oldbie
      • Jun 2006
      • 1230
      Originally posted by Agent24
      If the T2380 works well for you a new element might be cheaper for now
      Originally posted by pfrcom
      Altronics have advised they're out of stock of heating elements until late October - and replenishment will start from Perth, the other side of Australia
      figure out the control circuit
      Outside my expertise, I'm afraid
      if you can track down the part number for the heater (Farnell probably has it written somewhere)
      I've tracked down 79-210012 for heating element assembly - Xytronic product code E347-599E9_20150211231308
      Farnell only seem to offer Xytronic tips
      Xytronic themselves are no help - got two replies from them:
      First said "You have to get them from where you getting your soldering station ? Due to this model had been specially made for them !
      We do not stock them !"
      Second gave me a URL for Altronics, and Altronic's part number
      For part numbers I tracked down, the only option seems to be Polish sites, and communicating with them would be an issue for me
      Seems to me it's a typical Asian product scenario where focus is on manufacturing, to exclusion of any service, support or compatibility
      There is also heating element 79-210012U around the traps, where I bet the suffix stands for Updated, because it seems to be for soldering handle 210ESD
      I think a 210ESD is compatible with my station, but its tips seem to be different, so thinking about that as option would mean throwing more good money after bad
      • pfrcom
        Oldbie
        • Jun 2006
        • 1230
        I tried an enquiry in English to ndn.com.pl
        Got a prompt reply that they don't ship to Australia
        Nothing ventured nothing gained, I asked if they knew whether xytronic.com.pl would do so
        Another prompt reply that xytronic.com.pl is also theirs
        I also asked www.rapidonline.com if they could supply 79-210012
        They suggested 79-210012U which doesn't look suitable in their picture, and I'm pretty sure is for later model 210ESD soldering handle
        So looks like I'm SOL until November, assuming Altronics can even supply a spare part then
        • Agent24
          I see dead caps
          • Oct 2007
          • 5037
          • New Zealand
          Well, if you posted pictures of the control board we could probably figure it out, though it does seem likely the heater is bad, so probably not needed.
          I guess it's better to wait then, or just get a new station.
          -David VanHorn
            • 31196
            use 32v of lamps to test the base by connecting across the element.
            • pfrcom
              Oldbie
              • Jun 2006
              • 1230
              Thanks STJ
              It's all reassembled and put to the side - too cold here for further diagnosis for the time being
                • 31196
                haha bet you wish global warming wasnt a scam!
                that snow is worth money if you could ship it!
                • pfrcom
                  Oldbie
                  • Jun 2006
                  • 1230
                  What's snow ?
                  Didn't even see the stuff until I was in my late twenties, during a day trip up to an Alpine area
                    • 31196
                    must be the other side of aus
                    • pfrcom
                      Oldbie
                      • Jun 2006
                      • 1230
                      Shot myself in the foot
                      After ruining a motherboard trying to remove caps with my old station, I noticed Altronics offering suspected closing-out price on their T2460 - I think a rebadged Xytronic LF-2000:
                      http://www.altronics.com.au/p/t2460-...ering-station/
                      or first pic
                      Bright idea was to try old handpiece on new station, and vice versa
                      It arrived today, and its handpiece is six-pin connector, not seven
                      Handpiece seems to be a Xytronic 307K - at least it's a much lighter & neater unit
                      So my quest continues for a heater element like second pic, borrowed from:
                      http://ndn.com.pl/akcesoria/3034-grzalka-79-210012.html
                      who won't deliver to Australia
                      FWIW, original station looks like third pic
                        by sam_sam_sam
                        07-01-2024, 06:34 AM
                      • chth96
                        What soldering station should I purchase for 900M-TJ-I tip?
                        by chth96
                        hello.
                        A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
                        https://ko.aliexpress.com/item/4001275635593.html
                        Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
                        Any reply would be appreciated.
                        11-24-2023, 05:08 PM
                      • caprider
                        Recommendations of quality soldering station and (separate) hot air station
                        by caprider
                        Hey,
                        I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
                        I now have a TS100 and some soldering irons and looking for some better tools.
                        1. Soldering station, budget around 200-240€
                        JBC BT-2BWA seems to be a good product in the budget.
                        2. Hot air station, budget around 200€
                        Up to now I've found ATTEN ST-862D to be a good option....
                        01-15-2022, 02:05 AM
                      • mkbehbeh
                        KSGER C245 Soldering station PSU 220V only?
                        by mkbehbeh
                        I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
                        I am...
                        04-17-2023, 03:11 PM
                      • Peter_1402
                        Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                        by Peter_1402
                        Hi Everyone,
                        I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                        1. Soldering iron works great
                        2. There is a burnt mark on the hot air gun handle.
                        I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                        Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                        Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                        Reed switch tested ok with a magnet.
                        From the above test, I can conclude...
                        07-12-2025, 11:50 AM
