BGA non direct stencil help
  • rtstorm
    • Feb 2012
    • 971
    • Croatia
    I need some help on reballing. I have 90x90 stencils. The problem is that not all balls wont go through the hole. Current i use 0.5mm stencil on some ATI radeon GPU.
    When i put solder paste on IC and then put upper part od jig sometime the stencil is touching the ic and paste will stick on it
    ...the quieter you become the more you are able to hear...
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Re: BGA non direct stencil help
    If you need to use that much flux paste that it gets in the holes of the stencil, you need to use better flux. What are you currently using?
    A working TV? How boring!
    • rtstorm
      • Feb 2012
      • 971
      • Croatia
      I put a very thin layer or paste. I use amtech.
      I notices that there is a 4 scree for adjusting height of distance upper part.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Genuine Amtech is good. That's what i use as well.
        If you have height adjustment screws on your jig, try adjusting them so that the stencil comes ever so slightly above your chip, like 0.1mm or so. Look at an angle in powerful light and you should barely see a shadow under the stencil. Then try again and see if it's any better.
        You need to get it far enough so that flux doesn't get into the holes of the stencil, but close enough for the balls to remain in place.
        • nojgib
          • Nov 2014
          • 30
          Not sure how much flux you are using but a thin layer is key. If you have thick flux it will touch the stencil even with the jig set correctly.
          Cleaning the flux from the holes can be a bit challenging but what worked best for me was alcohol based because it evaporates slower. Use a pin to gently poke any residue from the holes.
          • rtstorm
            • Feb 2012
            • 971
            • Croatia
            Thank you, i noticed that every time i put balls and when i try to lift stencil many balls stay on the stencils and wont fall through hole, like tha hole is to small but it is not.
            • dellxps15
              • Feb 2014
              • 1585
              • italy
              put flux, then remove extra by passing 4 time (1 for each side) a similar " credit card" .
              then put in place stencil and allign it perfectly. ofcourse before all that clean the stencil with a fresh isopropilic alchool.
              edit: flux quality is very important. i use kingbo with pb or original amtech 559 uv tpf
              • rtstorm
                • Feb 2012
                • 971
                • Croatia
                Here is the picture of it. I dont know how but may ball stay in the stencil.
                • nojgib
                  • Nov 2014
                  • 30
                  It's hard to tell in the pic but I don't see any flux squishing though the holes so that's a good sign. If there is anything preventing the balls from falling onto the chip it would be easily seen by holding the stencil up to the light.
                  The only other thing that comes to mind would be if the balls themselves have flux on them from previous attempts. I never put solder balls back into the container they came from because any slight residue of flux would make them stick together or stick on the stencil.
                    • 30930
                    cheap ultrasonic cleaner is handy for these problems.
                    • rtstorm
                      • Feb 2012
                      • 971
                      • Croatia
                      Can i use the smaller ball? Like i have stencil that is 0.5 and i put ball 0.4?
                      I try again and still some ball left in stencil. I will try with new sets of ball because i put back sole ball after using them on stencil.
                      • dellxps15
                        • Feb 2014
                        • 1585
                        • italy
                        0.5, use 0.5 for ball that remain on stencil, or they were infected by some flux previously, or stencil is dirty of flux.
                        i clean always stencil each time with fresh isopropilic and balls that remain over the stencil i wont put back is solder balls contenitor, but will trow them for garbage.
                        • Beowulf
                          • Dec 2012
                          • 175
                          You can get more help about bga rework on this forum
                          www.advancedreworks.com/forum
                          Yes it's perfectly fine to use smaller balls. But your problem is that your using too much flux. Start from putting almost nothing.
                          • harshad1975
                            • Jan 2015
                            • 7
                            • India
                            You can check my video on youtube .. it will help for direct heat stencil
                            reball process
                            watch this video :
                            http://youtu.be/0C80O7_galU
                            • BGA Rework Store
                              • Mar 2015
                              • 14
                              • united kingdom
                              think of a grain of rice put that amount on flux should be genuine if its amtech and got a holographic sticker (fake ) I dont sell fake amtech full of cheap crap , But if its orginal a grain of rice size and rub that all over the chip is more than enough, remember good flux is very tacky so little is best , also if you have been using alot of flux you may have clogged the holes on the stencil for stencils I sell the 9050 from aoyue drop those in job done , you can drop down .5 on solder balls but its down to flux and stencil use , dont panic when you look at the chip and think have i put enough on remember the job is to attach the solder and a nice shine of flux over the chip is all you need not a big wax look.
                              if you need stuff contact me and i will send you links Im U.K based but ship worldwide.
                              • myth77
                                SR40 90x90 stencil direct heat, where to find?
                                by myth77
                                Mostly i use 90x90 stencils for chip reball, then i remove stencil and apply heat with heatgun...and preheater...and everything is fine. But this SR40 pch chips are very small with lots of balls half milimetar from each other...and i am not happy with results... I get bridges and so on....So i was thinking maybe to reball these SR40 chips with direct heat stencils...but i can not find it in 90x90 size. I tried aliexpress and ebay...but nothing.
                                Maybe someone knows place to buy? Thx
                                11-13-2021, 06:51 AM
                              • myth77
                                direct heat stencil,where do you get it? and how to prevent warping?
                                by myth77
                                So, lately i found that for smaller chips like pch it is very difficult to reball with nondirect heat stencil. So i decided to try direct heat stencils...and while i am waithing some stencils to arrive i have a few questions:
                                1. From who do you buy a quality direct heat stencils? i am reading that they can vary in quality and make a big difference...Any trusted sellers?
                                2. I am reading also the problem of warping (curving) direct heat stencils...Is it because of quality of the stencils? or/and because some preheating is also required? and help and advice here?
                                01-17-2022, 05:06 AM
                              • Veyron7887
                                Laptop overheating after replacement thermal paste
                                by Veyron7887
                                Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
                                11-24-2024, 05:08 AM
                              • BigOof
                                Marantz SR5007 popping on volume change and mute in Direct Mode
                                by BigOof
                                I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
                                12-12-2024, 06:15 AM
                              • caspian
                                Can thermal paste cause corrosion?
                                by caspian
                                Dear members,
                                I have got an ordinary gray thermal paste that has no name/model on the box.
                                I put some of this thermal paste on a 128-pin QFP IC. A bit of this thermal paste was put on pins of the IC.
                                I tried to clean the pins by thinner but the thermal paste cannot be cleaned from the pins properly. because the pins are tiny and the thermal paste is stuck between them.
                                Is it possible that the thermal paste damages pins of the IC in long term by creating corrosion or something?
                                Is it safe to leave the thermal paste on the pins?
                                I guess the thermal paste...
                                06-19-2020, 10:47 AM
