direct heat stencil,where do you get it? and how to prevent warping?
  • myth77
    • Feb 2017
    • 380
    • Croatia
    So, lately i found that for smaller chips like pch it is very difficult to reball with nondirect heat stencil. So i decided to try direct heat stencils...and while i am waithing some stencils to arrive i have a few questions:
    1. From who do you buy a quality direct heat stencils? i am reading that they can vary in quality and make a big difference...Any trusted sellers?
    2. I am reading also the problem of warping (curving) direct heat stencils...Is it because of quality of the stencils? or/and because some preheating is also required? and help and advice here?
    Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
    The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
    Securing a good thermal interface between...
    10-07-2024, 04:35 AM
  • BigOof
    Marantz SR5007 popping on volume change and mute in Direct Mode
    by BigOof
    I bought a used Marantz SR5007 and it's giving me some issues that I can't seem to really place. It functions well in most settings, ARC mostly works, it has no issues driving my speakers in any of the digital input modes, but I'm having issues running analog inputs in direct or pure direct mode. For some reason in this mode there's distortion for every volume increment I give it, but once the volume is stable it has no issues. Muting creates a loud pop, switching to another source also causes a pop and so does turning off the amp in that mode. Again, no issue in the digital modes....
    12-12-2024, 06:15 AM
  • myth77
    SR40 90x90 stencil direct heat, where to find?
    by myth77
    Mostly i use 90x90 stencils for chip reball, then i remove stencil and apply heat with heatgun...and preheater...and everything is fine. But this SR40 pch chips are very small with lots of balls half milimetar from each other...and i am not happy with results... I get bridges and so on....So i was thinking maybe to reball these SR40 chips with direct heat stencils...but i can not find it in 90x90 size. I tried aliexpress and ebay...but nothing.
    Maybe someone knows place to buy? Thx
    11-13-2021, 06:51 AM
  • harp
    detecting heat with IR LED receiver
    by harp
    I have some dark IR led, and want to know if it is be situable to detect pure heat (not visable glow ir radiation) in well lighted desk?
    So, if I put hand over it in near distance like few centimeters, that detect rising heat, not covering it from light.
    Something like termal camera, but in one spot, any simple circuit?...
    09-06-2023, 06:03 PM
  • Joe24
    BGA reballing techniques and equipment
    by Joe24
    I work mainly with larger (2000-3000 ball) BGA chips, typically 0.4-0.55mm solder balls. I've reballed many of these, and it's always a royal PITA. My current system is direct heat stencils and hot air, which works but is very tedious. Typically takes me 3 hours, which is about 2 hours too many. And to make matters worse, today i discovered that one stencil must be warped, because as soon as I apply heat, 1/3 of the stencil lifts away from the chip and all the solder balls run together. Unfortunately that's the only stencil I have in that size, atm. You know... we've all had weeks like that. ...
    10-14-2021, 03:59 AM
