ESR meter really showing only esr
  • yoritomo
    • Sep 2012
    • 139
    • Belgium
    Hello
    My question is about efficiency of esr meters, as you know it has 2 types of esr meters, the bad one which is a simple AC ohmmeter simply displaying the total impédance of the capacitor. And most evoluate one able to display ESR only regardless of capacitance.
    Then of course i would like to buy the second type of ESR meter, i would say a real one, i am not which ones are good or not in this way, can you please give me some advises about it ?
    I was thinking to buy Atlas ESR70 which is handy for uncosy work places, testing capacitance and ESR.
    Is it a good choice or not? It is not really cheap, does it exist good equivalents to it for lower price over Europe ?
    Thanks for your help.
    • 30917
    Re: ESR meter really showing only esr
    http://www.ebay.co.uk/itm/400771099161
    • yoritomo
      • Sep 2012
      • 139
      • Belgium
      Thank you for the link, it look as a very smart tool for the price, look like one 0 is missing in the price.
      AS ESR meter is an interesting one ?
        • 30917
        there are many, go to ebay and search "esr meter"
        some are even cheaper but the display is only test.
        there are even kits.
        • yoritomo
          • Sep 2012
          • 139
          • Belgium
          yes i know it has a lot of different ones available, but very few are true ESR meters, most of them mesure capacitive impedance + ESR , and that is not the purpose at all, they are cheap but not useful. I ever made such crappy ESR meter as well, and became almost useless for me, even if it enables me to find really bad caps a lot of them still let me doubts.
          • Uniballer
            • Jul 2013
            • 334
            There is a slight problem. Test voltage makes a big difference for in-circuit performance (you don't want to turn on diodes/transistors when you are just trying to test capacitors).
            If you want an ESR tester to work (at least some of the time) in circuit for the purpose of finding bad capacitors then you want a meter made for that purpose. Like the Anatek Blue ESR meter, maybe. Or the Peak meter the OP mentioned. Or something else that you like.
            If you are willing to give up in-circuit testing and want really good measurements then take a look at something like this handheld LCR meter. Not guaranteed to work in circuit, but awesome if you need to separate ESR from other aspects of impedance.
              • 30917
              you cant trust in-circuit testing, that's just advertising bullshit.
              • yoritomo
                • Sep 2012
                • 139
                • Belgium
                stj, i think so, it is sometime working but most of time tricky near semiconductors and multiple parallel capacitors.
                Uniballer, it looks like a nice tool following the link.
                I took a decision today and finally ordered an ESR70 i will receive it on beginning of the next month, i will post a feedback here when i will have used this tool .
                Thank you all for your advices and tips.
                • jm1234
                  ESR meter not showing anything for 0.1uF
                  by jm1234
                  my ESR meter doesn't show any ESR for this capacitor: https://www.tme.eu/sk/en/details/r46...acitors/kemet/.
                  Is that an issue? My RLC meter shows the capacitance: 85nF.
                  I'm new to ESR, so maybe this is all expected for this type of capacitor?
                  02-02-2024, 10:03 AM
                • chth96
                  by chth96
                  03-09-2024, 10:03 PM
                • JimBanville
                  ESR meter (MK-168) not showing ESR readout on certain capacitors?
                  by JimBanville
                  I'm doing a recap job. I measured three Rubycon 50v 33uf electrolytic capacitors and they all showed about 31uf of capacity on the MK-168 transistor tester (ESR meter) but no ESR reading at all. I then measured some brand new caps with ratings around these rubycons and the meter correctly gave both a capacitance AND an ESR readout. Any ideas?
                  04-14-2021, 06:39 AM
                • eccerr0r
                  lowest current galvanometer/analog meter (passively powered!)
                  by eccerr0r
                  Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                  On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                  04-16-2025, 12:41 AM
                • jorpec
                  by jorpec
                  Hi
                  Thnaks
                  01-23-2023, 10:37 AM
