I'm doing a recap job. I measured three Rubycon 50v 33uf electrolytic capacitors and they all showed about 31uf of capacity on the MK-168 transistor tester (ESR meter) but no ESR reading at all. I then measured some brand new caps with ratings around these rubycons and the meter correctly gave both a capacitance AND an ESR readout. Any ideas?
ESR meter (MK-168) not showing ESR readout on certain capacitors?
Re: ESR meter (MK-168) not showing ESR readout on certain capacitors?
Yes they are bad. I will check later to see what you should expect -
Thanks. I rechecked them and it was user error. Haha. They were all measuring 31pf, not 31uf. They are REALLY bad. Because that "number" was so close to their rating, I guess my brain didn't register the pf versus the uf part of the reading. Duh! Lol. So I read that this meter won't display an ESR for capacitors below some range...like 100pf. Thanks again!Comment
by SimplebeansHey guys i just got myself a Macbook Pro A1989 820-00850-a 2018, the seller said they had spilt liquid over it and since then it has never turned on.
I am using a Apple 61W USB-C Power Adapter and USB-C Charge Cable and on my USB tester i can see when i plug into the power i get around 5.21V and stays at 0.24amps. I am currently testing disconnected from the battery and only plugged into the USB-C Charge Cable.
When opening the machine I was greeted with corrosion on, in and around, in particular the U3100 (USB-C PORT CONTROLLER XA) and U3200 (USB-C PORT CONTROLLER XB)... -
by hikomalekHello, I have a SYMSI70 gas heater board, which has issues with its primary side power supply, controlled by TOP247Y chip.
When I replace a TOP247Y it explode in 1 second. I have desoldered transformer and measured a winding ratio, so transformer looks like OK.
Transformer:
|Info| Primary | Aux | AB | CD|
|Ratio|1|25|40|12|
|Voltage AC|230V|9.2V|5.8V|19V|
|Voltage DC (*1.41)|230V|13V|8.1V|27V|
I have disabled a undervoltage protection of TOP247Y, disconnected secondaries and tried to power it up... -
by expertreaderDell 5520 South peak 15 MB 213253-1 2TWTT$LA
Hi all, looking for some help to get started on troubleshooting without schematics
I have used Dell Latitude 5530 SouthPeak15 MLK 203102-1 schematics from forum although this board is a little bit different.
I am a bit lost on USBC PD circuit and what to measure - here is what i have done so far.- no coils are shorted - one is showing about 15ohms but others are in kohms or infinite resistance.
- most of the coils are showing 5V, 1.3V, 3V etc except 2 of them.
- i have measured 16.5V available at the capacitor
1 Photo -
by chth96I read EBOOK of Testing Electronic Component and found that
Is it really possible to test small ceramic disc capacitor with analogue...-
by ttmi100xGreetings everyone,
I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
Upon closer inspection...6 Photos-
- Loading...
