ESR meter not showing anything for 0.1uF
  • jm1234
    • Jan 2024
    • 64
    • Slovakia
    my ESR meter doesn't show any ESR for this capacitor: https://www.tme.eu/sk/en/details/r46...acitors/kemet/.
    Is that an issue? My RLC meter shows the capacitance: 85nF.
    I'm new to ESR, so maybe this is all expected for this type of capacitor?
    • 31246
    component testers dont show esr for very low caps - it's a software function.
    here is some text!
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      It depends on the firmware version of the tester too if it is based on the open source transistor tester project.
      For example my with latest k-firmware can test ESR of a film cap down to 47nF but a 10nF shows no ESR.
      Here from the manual that stj linked:
      The tester tries to measure the ESR for capacitors larger than 10nF.
      Alternatively you can also enable the old ESR measurement method starting
      at 180nF. But since the ESR measurement isn't done via an AC signal with a
      specific frequency, please don't expect a solid result. The method used might
      be comparable with a 1kHz test. Anyway, the results are good enough to check
      electrolytic caps. For low value film caps you could get different results
      based on the MCU clock rate. I'd guess Mr. Fourier is able to explain this.​
      That said ESR is generally not of interest for a X or Y class film capacitor, only capacitance so it doesn't really matter anyway...
        12-31-2023, 06:04 AM
      • jorpec
        by jorpec
        Hi
        Thnaks
        01-23-2023, 10:37 AM
        Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
        12-14-2023, 07:45 PM
      • expertreader
        Dell 5520 not booting up - on light comes on momentarily
        by expertreader
        Dell 5520 South peak 15 MB 213253-1 2TWTT$LA
        Hi all, looking for some help to get started on troubleshooting without schematics
        I have used Dell Latitude 5530 SouthPeak15 MLK 203102-1 schematics from forum although this board is a little bit different.
        I am a bit lost on USBC PD circuit and what to measure - here is what i have done so far.
        • no coils are shorted - one is showing about 15ohms but others are in kohms or infinite resistance.
        • most of the coils are showing 5V, 1.3V, 3V etc except 2 of them.
        • i have measured 16.5V available at the capacitor
        10-19-2025, 08:20 PM
      • Track4207
        Hisense H50N5300UK reboots when showing full red images
        by Track4207
        Hi all! A bit of an interesting and unusual problem: as the the title suggests I have a Hisense H50N5300UK that reboots when showing fullscreen solid red images (and some other solid colours, but red generally causes the issue the fastest). I first came across the problem assuming it was an intermittent issue, but later lucked into finding out that a title sequence of a show I watch happened to trigger the reboot.
        What happens:
        • TV appears to operate normally, for an indefinite amount of time until a problem image appears
        • The problem image is displayed very briefly, then the
        08-30-2023, 11:58 AM
