Conductive Ink Pen - how to apply without bridging when there are multiple traces?
  • Almighty1
    • Apr 2014
    • 222
    I was wondering if anyone here has any experience using conductive ink pens as it seems the motherboard I am recapping has some broken traces. The problem is the traces are next to each other and I am trying to avoid bridging the traces together but what's the best method to do it as I've tried:
    1) using 3M Scotch Magic tape outlining the trace but the ink still seems to bleed to the other trace.
    2) just apply to the entire area and let it dry but after it dries, using the tip of a paring knife to draw the lines between the trace, it will basically take all the conductive ink off.
    Is there another way to apply it so it will just be a hairline instead of spreading and creating a short?
  • Goldieoldie
    • Jul 2014
    • 15
    • England
    Re: Conductive Ink Pen - how to apply without bridging when there are multiple traces
    Rather than using conductive ink,I've repaired traces by using thin copper wire ( single strand from hook up wire ) then a drop of glue to hold the wires in place
    Pete
    • Almighty1
      • Apr 2014
      • 222
      Never thought about that method but wouldn't the glue prevent conductivity as the wire has to be secured tight to the traces and I thought glues were non-conductive.
        • 31197
        yes, wire and if it's long you tack it down with glue afterwards.
        i'v had nothing but trouble with silver paint.
        btw, dont use cyanocrylate (superglue / crazy glue) ever on pcb's
        use UHU all purpose adhesive.
        it sticks real well, dry's clear and can be ripped off later.
        it wont vaporize into your eyes if you go near it later with a soldering iron like cyanocrylate.
          • 31197
          he meant solder the wire & use the glue to hold it down.
          • Almighty1
            • Apr 2014
            • 222
            Only problem is the traces are fairly close as the gap is about 2-3 hairs apart so soldering would basically cause a short.
              • 31197
              no it wouldnt, i'v done it before.
              single-strand copper wire can be placed on tracks like that.
              post a foto of the problem area.
              • Almighty1
                • Apr 2014
                • 222
                Hard to get a picture in focus so I've borrowed one basically showing something in a similar manner, there is like 6-7 traces which all are broken that I'm trying to fix. I can see how single-strand copper wire can be placed but how will you get the solder to be hair thin so it doesn't touch the other traces. I even heard some people use a 0.5mm pencil to fix traces but it just won't be long lasting as that's how some people defeated the AMD CPU frequency lock.
                • chozo4
                  Nothing Special
                  • 134
                  In such cases what I would do is clear off a small section of soldermask further up on each trace so you don't risk bridging it with others adjacent to it. Just alternate the locations on the traces accordingly to avoid any scraped traces right next to each other.
                  Even crap caps can be useful... such as blank rounds for prop gunfights.
                    • 31197
                    yep,
                    strip & tin the tracks,
                    tin the wire,
                    then they will solder together fine.
                    • rievax_60
                      • May 2012
                      • 897
                      • australia
                      That is what I do also, works well.
                      If the tracks are very fine and I need many attempts at getting the wire soldered in the right place, I use candle wax as flux. It doesn't need to be reapplied often like other flux types do.
                      • Almighty1
                        • Apr 2014
                        • 222
                        Good point so basically I can join any two parts of the trace as long as it's the same trace? Also, where would I get the wire for this? What's a good way to clear off a small section of the soldermask without damaging the trace beneath it?
                          I use fiberglass pen, something like this: great for corroded joints and pins.
                          http://www.frys.com/product/2581741?...FcI7Mgod3FgApw
                            • 31197
                            for wire just strip some stranded wire and use a strand.
                            when i want really thin wire i unwind an old transformer or speaker coil.
                            remember that transformer / coil wire is insulated with laquer.
                            • rievax_60
                              • May 2012
                              • 897
                              • australia
                              It is important to not scrape soldermask from adjacent tracks if you want to avoid solder bridges. I use a stainless steel rod sharped like a small flat screwdriver point, but slightly rounded.
                              The fine wire from small mains transformers can usually be tinned easily at normal soldering temperatures.
                              • Almighty1
                                • Apr 2014
                                • 222
                                I have a few of the pens budm mentioned and the problem is it will scrape the soldermask off from more than one track which is what I'm trying to avoid. I don't have any old transformers or speaker coils which is why getting the wire is not exactly that easy. I'm wondering what kind of trouble people actually have with the conductive ink from the conductive ink pens since I know it works except the question is how to draw fine thin lines with it since we're talking about 11 traces within a 5mm width.
                                • mmartell
                                  • Oct 2013
                                  • 3189
                                  You can get fine wire from a piece of solder braid.
                                  • eccerr0r
                                    Solder Sloth
                                    • Nov 2012
                                    • 8701
                                    When I can, I just use 30 ga Kynar wire wrap wire, but it's just because I have plenty of it (have a bit over 1000ft)
                                    But it seems as nobody wire wraps anymore, the price of this stuff has gone up a bit since I last checked, it used to be $4 or so for 100ft...
                                    • Uniballer
                                      • Jul 2013
                                      • 334
                                      +1 on the Kynar insulated wire.
                                        • 31197
                                        i love kynar, but it takes practice to strip it nicely.
                                        • mitsu2k
                                          The Real Dangers of conductive glue.
                                          by mitsu2k
                                          I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
                                          Here is an experience I...
                                          04-16-2023, 06:29 PM
                                        • chth96
                                          Is it possible bridging tiny broken trace
                                          by chth96
                                          When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                                          cutting tiny trace.
                                          This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                                          Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                                          But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                                          12-03-2022, 11:32 PM
                                        • Almighty1
                                          by Almighty1
                                          I was wondering if anyone here has any experience using conductive ink pens as it seems the motherboard I am recapping has some broken traces, these are fine hair thin traces as there as 11 traces within 5mm and 2-3 are broken. The problem is the traces are next to each other and I am trying to avoid bridging the traces together but what's the best method to do it as I've tried:
                                          2) just apply to the entire area and let it dry but after it dries, using the tip of...
                                          10-22-2014, 05:42 AM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
                                        • jeremy96
                                          PS4 Power Button Traces
                                          by jeremy96
                                          I recently bought a used PS4 and discovered that the power button is broken. Upon closer inspection, I found that the traces for the power button on the PCB are damaged and torn.
                                          Does anyone know where these traces lead or have any advice on how to repair them?
                                          Thanks in advance for your help!​...
                                          05-26-2024, 05:01 AM
