has anybody used one of these testers???
  • mattstolte
    • Dec 2013
    • 612
    • usa
    http://www.ebay.com/itm/221342035862...%3AMEBIDX%3AIT
    i bought it off ebay its in chinese so i cant seem to figure it out, has anybody ever used one?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5112
    • New Zealand
    Re: has anybody used one of these testers???
    Looks like you just hook up your DUT to any of the terminals and press the test button - the tester will automatically analyse and tell you the device type, pinout, and other information.
    The 4th picture in the listing tells you which buttons are which
    Edit: Looks like these testers may have originally came from this project: http://www.mikrocontroller.net/artic...ansistortester
    Current project files: http://www.mikrocontroller.net/svnbr...nsistortester/
    More information: http://www.avrtester.tode.cz/
    Added current v1.11k user manual I found
    -David VanHorn
    • popeye
      • May 2011
      • 155
      hi
      From what I can see of it you just connect the leads to componant in any order it will automaticaly show what the item is and display the results and pin outs
      • Ltank
        • Jun 2013
        • 776
        All the button labels are Japanese. Is there another version?
        • ecking767
          • Oct 2009
          • 492
          I have one that is similar, the one with the smaller display which work great. This one have a nice case but If I was to buy another one I would buy this one:
          http://www.ebay.com/itm/12864-LCD-Tr...item41807dfdcb
          The zero force insert socket and surface mount pad will help a lot when testing transistors and SMD.
            • 31316
            there will probably be a new china model soon,
            because the open-source design now has a variable voltage source for testing zener diodes!
            • Dans2530
              • Aug 2014
              • 15
              I got the $16 DIY solder it yourself version of this without that fancy case direct from china. I threw it in a cheap $5 jiffy box from jaycar. It only has the two line lcd though.
              It works better than you would think and it has all those functions. It also has an ESR test for electrolytics, but doesn't work in circuit and I'm not really sure of the readings, seems right but I wouldn't trust it as 100% accurate.
              I use it mostly for checking transistors/mosfets for pinouts and caps to see if they are good as those tests are surprisingly accurate. I checked a bulged capacitor once and it read as a diode! So obviously bad.
              • valente222
                help SG2701B01-7 panel chinese, would this integrated circuit be equivalent? Chinese IC CS601C regulator.
                by valente222
                Hi, I'm repairing this Chinese SG2701B01-7 panel. There isn't much information about it. The original part for the panel is a CSOT CS601C regulator. I can't find anything commercial on Aliexpress; there's only the CS601 without the final 'C'. They claim it's a variant. But will it be compatible? Well, my diagnosis on this screen is a video problem; the image is practically black, although there is HDMI communication. The LED light is on (backlight), but there is no VGL, no 3.3V, and no VSS. It seems that this IC is the one controlling these voltages. The monitor worked correctly for a moment and...
                05-12-2025, 03:42 PM
              • itsthatidiotagain
                CDS‑200B ultrasonic cleaner - (other generic Chinese cleaners are somewhat similar)
                by itsthatidiotagain
                CDS‑200B ultrasonic cleaner - AKA James Ultra 7050 etc.
                There are many versions of cheap Chinese ultrasonic cleaners, and a fair few share this design, with a removable tank with handle. There are also fixed tank versions which look to use the same basic layout and presumably the same PCBs.
                I picked one up "spares or repair" on ebay, and the cleaner was dead, but the fuse wasn't blown.
                A quick diode check revealed D7 was shorted. D7 is a 12V 1/2 Watt Zener. I had one in my stash, so this was about as close to a "five minute repair" as...
                06-23-2025, 03:22 AM
              • NanoTesting
                Anyone else been having problems with chinese laptops using ESSX8336 / ES8336 audio?
                by NanoTesting
                This audio chipset has been a pain to deal with, most of the time its impossible to find drivers for chinese laptops that have no name/brand, or generic rebranded laptops.
                Huawei also started to use it BUT they no longer host drivers on their website since they want you to force their PC manager app that often refuses to install after bios flashing and apparently the generic drivers around wont work on some intel systems and others wont work on amd systems, the generic ones have worked only once and i think i have had this problem on 30+ laptops so far in the last year.
                02-21-2025, 12:33 AM
              • Vincent_Leigh
                Chinese Mini PC Schematic
                by Vincent_Leigh
                For anyone in need of a sample schematic for those Mini PC from chinese origin.
                Enjoy.
                NB690
                SY8003
                NB687BGQ-Z
                MP86941C
                MP2961 AKA MPxxx2961
                NB692AGD-Z...
                09-19-2024, 11:55 PM
              • Bloopeta
                Car Headunit (Chinese?) No Sound / Audio
                by Bloopeta
                Just bought a car that has a stereo in, thats bluetooth etc, and powers on fine and all functions seem to work, BUT there is no audio/sound.
                I have tried another unit in the car that works fine, so know it definitely a problem with this unit.
                I know it just cheap rubbish, probably of chinese origin, but its really bugging me just throwing it away and replacing it 🙈🤣
                I know zero about things like this, ans its probably unfixable, or more trouble than its worth, but just wondered if there was anything to check, as what could lead to an easy-ish fix? Havnt opened...
                02-02-2024, 03:36 PM
