Car Headunit (Chinese?) No Sound / Audio
  • redwire
    • 3912
    But can you play Luciano Pavarotti full blast? Or maybe it's designed for marching songs lol.
    I wonder what the power amp IC part number is. Is it Class D or AB?
    • Piaskos
      Dell Vostro 5490 - no sound, no audio device
      by Piaskos
      Hi, i've got problem with Dell Vostro 5490.
      Board - Mantis CML 18788-1
      Windows says "no audio device detected". The other functions work properly.
      What i've done:
      1. I checked motherboard
      2. I changed audio codec (ALC3204)
      3. I reflashed bios with clear ME
      4. Audio is enable in bios
      5. Both speakers are good
      6. After installing the drivers from the Dell website, the devices visible in the manager:
      - Audio for intel displays
      - Intel Smart Sound Technology...
      01-30-2023, 02:58 AM
    • ChaosLegionnaire
      by ChaosLegionnaire
      09-13-2022, 09:02 AM
    • JRade
      Audio video receiver KENWood KR-V990D,no sound
      by JRade
      When I select the FM receiver, I find a radio station, the sound is heard on REC OUT(L,R), REC TAPE1(L,R),REC TAPE2(L,R) on high-ohm headphones, the sound regulation does not work.
      The output reacts when I connect the record player to PRE OUT FRONT L, the sound is heard in the speaker but the sound regulation does not work. Then it does not matter what I chose on the front selector.
      I replaced the capacitor C303/0.047F, nothing changes.
      I'm asking for help, what should I do next?
      Thanks in advance!...
      08-05-2025, 10:23 PM
    • MOSSEP
      Monitor Audio RSW12 - Green light, but no sound
      by MOSSEP
      Hi
      Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
      Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
      The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
      I have already tried replacing all of the...
      01-26-2025, 08:33 AM
    • televizora
      HP 8470p - distorted sound and noise when playing audio
      by televizora
      Hello.
      I have an issue with HP 8470p - rather strange one.
      I have a noise and sound distortions on both internal speakers and external speakers, when I plug such into the 3.5mm audio jack.
      Seems like the noise is present especially when I play audio, where there are parts/sections where the volume of the actual recorded sound is low.
      Interestingly, when I play the windows sound test, everything seems to be almost okay. The sound/distortions are similar to when you have interference from some other piece of equipment nearby or when you have an audio receiver with bad amplifier...
      12-31-2021, 10:25 AM
