New FNIRSI LC1020E LCR Meter
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8353
    Title sez it all... new FNIRSI LC1020E LCR Meter. I wonder if anyone has it already and if it is any good?
    Seen a vid about it: https://www.youtube.com/watch?v=Yj8Sgf_KF74
    • Jul 2011
    • 6070
    I want to being with there products are very good quality I have one of there meters but not this model the accuracy of the seem to be decent it reads very close to my Fluke meter and most times it reads the same when I get home I will post the model number
    I also have two current clamp meters as well
    I would have NOT have any issue buying any of there products because I have several different products from them
    I hope this helps you make your decision about buying any of there products
    I normally am not brand loyalty because I find most times manufacturers are good at one or two things but lack in other products
    I bought there battery operated battery tab welder it works very well but should have one extra battery cell in parallel for better performance but not a deal breaker and by me mentioning this some of there devices might fall short of being perfect but at least they are concerned about quality of their products
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8353
      Not sure if I should buy one or not. I like to have another ESR meter. Not sure if I should buy another Agilent / Keysight one or on of these cheapo jobs.
        • Jul 2011
        • 6070
        This would depend on what your main reason for buying another one for if it just for comparison purposes or are you after accuracy or is price a concern then this is another or at these are determining factor for me
        • CapLeaker
          Leaking Member
          • Dec 2014
          • 8353
          Good question. It’s rather maximizing the bang for my buck. Things are rediculously expensive thanks to some government decisions and being taxed to the hills.
            • Jul 2011
            • 6070
            As you are aware of I have issues with the tariffs and all of these games that they want to play
            And It makes making decisions very difficult to make now because I do not want the extra cost
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8353
              Same here. Those tariffs suck.
                • 31314
                they arent "tariff's" ,they are a sales tax.
                and a criminal one, stealing from the people to hold up the fake economy!
                • CapLeaker
                  Leaking Member
                  • Dec 2014
                  • 8353
                  All I say is this: a tax, plus another tax, and then another tax plus sales tax. It’s ridiculous.
                  Here in Canada we got told from a certain female politician (ex finance minister) that we should cancel our Disney Plus subscription, so the government can invent more taxes, Oyyy… that’s gotta go into the political section soon, before the lid blows off.
                  • chth96
                    by chth96
                    03-09-2024, 10:03 PM
                    AE20218 Milliohm Meter Kit, 0.1 Milliohm Resolution, Four Wire Measurements bought one
                    I have been in need of a mega ohm meter for a while but just could not make up my mind to which one I want to buy and this one has a couple of things going for it can also be used on a computer to display a resistance graph plus it is a kit that you put together supposedly the only parts installed are the surface mount components
                    I will probably make a rechargeable battery pack for so it can be used as a portable device and anywhere
                    I kind a wish that it had a higher resistance value higher than 240 ohms at 10 milliamperes on high range but it is what it it
                    On the...
                    03-15-2025, 05:10 PM
                  • Ryan Wurtz
                    Lenovo Yoga C740-15IML 5V on usb meter.
                    by Ryan Wurtz
                    Hello. So I searched and didn't find any posts on this specific problem.
                    When plugged in USB power meter reads 5v
                    Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                    Original mobo had a shorted cpu it seems.
                    So I decided I need a new motherboard.
                    Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                    5v on the meter. Still won't charge. Can still charge the battery...
                    11-24-2025, 01:08 AM
                  • eccerr0r
                    lowest current galvanometer/analog meter (passively powered!)
                    by eccerr0r
                    Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                    On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                    04-16-2025, 12:41 AM
                    Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                    12-14-2023, 07:45 PM
