De Solv it and Flux??
  • stevo1210
    • Oct 2006
    • 4156
    Hello Everyone,
    I was having some issues with remaining solder flux that was stuck to my mainboard while I was soldering and I used a citrus based solution called De Solv It.... It is an American made product and is available at the local supermarket.... normally it is used to remove sticky residues like tape remains etc.
    It is actually water rinseable and doesn't give off any putrid odour part from the smell of orange, since it is citrus based.
    The all the flux came off very well, in fact there isn't ay flux stains left on the board itself but I was wondering if this stuff was corrosive in any way....
    I think this page has the datasheet for it....
    http://www.rcr.com.au/proval/catalogue.php?subid=8
    I first tried this stuff with my Trigem motherboard about a month ago and I haven't seen any corrosion yet even though the cleaner is dry, I haven't cleaned it off with water yet, so it still smells of the nice orange smells.
    Thanks.
  • gonzo0815
    • Feb 2006
    • 1600
    Re: De Solv it and Flux??
    Well, it is probably not corosive, but i would not like to have any chemical on elektronic board for a long time.
    The usuall problem is, that most cleaner will be degraded after some time, and the endproduct will may be become hygroscopic and may be corrosive or conductive.
    So i would prefer to leave the flux prior to remove it with an non water rinsable cleaner.
    The flux is in most cases not corrosive at all, as it was desinged to not harm the traces and solder joints. So either just rinse the solvent with usuall dish detergent and water if you have the time to let is completely dry up (about one or more days depending on temperature dn humidity) or just use some alkohol or acetone for the job, if time is criticvall. A normal paint brush will make it very easy to clean solder joints without too mutch solvent.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16955
      Best way to deflux a board that I've found:
      Scrape the excess away with a hard plastic probe (it flakes off very easily), and then use a fine wire bristle brush and brush away the residual. Then, a blast with the air compressor will blow the dust away. After that, you won't even be able to tell that the board was ever even worked on if your soldering skills are good.
      I've found that chemicals used to deflux a board usually make more of a mess than the flux itself. I stopped using the chemical method years ago.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        flux remover is corrosive to plastic anyway
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          maybe to the fans found in a prudentway psu.
          brand mostly unpronounceable but is "metallic plastic"
          look for some pics soon.
          note that some fluxes must be completely removed as they are hygroscopic and will turn conductive.
          solvents that leave anything behind gather dirt.
            20 year old Kenmore refrigerator ice maker bad water valve coil took a crap
            I got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
            At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
            Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to...
            04-09-2023, 08:04 PM
          • chth96
            Is it good to use chemistronic flux off es835b for flux remover?
            by chth96
            I want to purchase any good flux remover But "chemistronic flux off es835b" is the most common flux remover in my nation..
            Or I have to purchase "3m novec flux remover" which is quite expensive in my nation?
            11-17-2023, 07:25 AM
          • edugimeno
            Stagg sms12p audio amp has water damage
            by edugimeno
            Hi! My friend just brought this audio amplifier/speaker fro his music band saying they realized its got no sound. Led powers up but there no sound at all
            I opened it and found 3 board. 2 of them are for input plugs and potentiometers, and the other larger board has the amplifiers for 2 large speakers that it drives
            There's also a large toroid transformer that feeds a lower voltage to the first 2 boards and a larger voltaje (36x2 rectified close to 100v) to the power board. The power board has the plugs for both speakers
            There is only one signal wire connecting the first boards...
            05-24-2025, 06:00 AM
          • RetroComputingGrotto
            Water Damaged Toshiba 48L1435DB
            by RetroComputingGrotto
            I have a water damaged Toshiba TV that was hanging nicely on the wall then over the summer we had a new multi-million pound boiler system put in and right where this TV was hanging is a nice new pair of water pipes for the radiators...
            The TV hasnt been used for a fair few months but it was needed again the other day and needless to say, it didn't power on or show any signs of life (no standby LED etc). After checking the fuse in the plug (and that the socket it was plugged in to worked) I decided to get up some step ladders to take a closer look and low and behold! It looks like...
            10-07-2024, 08:23 AM
            Multifix 425-01 and 450-01 Rework Flux Datasheet
            REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
            - No Clean Formulations
            - Low residue
            - Range of activity to deal with different component solderability
            - Halide free
            - Suitable for dispensing
            - Compatible with solder coatings and/or No Clean flux cored solder wire product range
            Both products are supplied in syringes or cartridges for application by dispensing....
            10-07-2024, 06:02 AM
