Hakko vacuum desoldering - Stations vs. Self Contained 808
  • y_not
    Same 'ol Song
    • Aug 2009
    • 147
    I have read piles of reviews and praises for the Hakko 808, it rocks!
    This we know.
    Now here's what I'm wondering and can find NO INFO on the matter.
    What sort of difference is there compared to the station based units, where in the vacuum pump is separate from the hand held iron.
    Ex. Hakko 470/472 series.
    I'm not talking about the new yellow+blue models, those are way out of my league in price.
    Performance and maintenance wise, do they require less maintenance in regards to taking apart the pump when the filter lets something through, better filtering, better suction, more power, better solder disposal & cleaning, more heat, faster tip recovery time, etc...
    I see that the vacuum pressure is the same, the only difference is the liters/min are a little higher on the stations.
    That tells me it's a more powerful pump, but at the same pressure? *confused*
    Any who have had a chance to use both, or can at least comment on the stations alone, please let me know your thoughts on the matter.
    Thx.
    How to properly apply thermal grease - Y_not's way.
  • y_not
    Same 'ol Song
    • Aug 2009
    • 147
    Re: Hakko vacuum desoldering - Stations vs. Self Contained 808
    Not many, or any users of stations, huh?
    I dug this up yesterday.
    http://www.howardelectronics.com/den-on/sc7000.html
    It's a bit outside of my price range, but they do have an inhouse refurbished $250 unit.
    It's said this far outshines the stations, being that the pump has such a short distance between it and the nozzle.
    I found a tech that said some of the vacuum desoldering stations have a design that makes it so there's always vacuum pressure ready & waiting, as it stops it off in high vacuum at the wand. Thus, on the next joint, the pump doesn't have to suck all the air out of the line between it and the station before having full vacuum at the tip.
    Any truth to this matter? Is he referring to the Hakko stations? It sounds like the Ungar, Pace & even some of the Weller stations are utterly HORRID!! Either having poor performance, or they just break down a lot. No one ever mentions this about the Hakko stations. But they don't say otherwise either.
    In that same thread, it was stated that this Den-on struggled on multilayer boards or just wouldn't do them. Whereas the Hakko 808 did them just fine. But it seemed loose to me and unfounded. IE. A user that didn't know their stuff.
    Plus, with its reversible pump switch, it can do SMD hot-air work too!!
    Not to mention, it sounds like it has an absolutely superior design when it comes to filter longevity, since it doesn't clog it up with solder, only fumes.
    I'm wondering if this is what really separate the Hakko stations from the self contained unit.
    Anyone used it?
    Of course I'd love to hear some 1st hand accounts of it.
    Spit-ballin' is good too... chime in!
    Thanks everyone!!
    • Kiriakos GR
      Banned
      • May 2012
      • 940
      • Greece
      I have the DEN-ON brother model of the 7000,
      it is an very old design capable to handle single layer PCB and throw hole desoldering.
      The pump is noisee and not powerful enough as needed to handle a five layers PCB just with hot air.
      You need to find an more modern tool than that.
      Yes it is made in Japan and with a cost around 1000$ USD as new, and so what?
      It does not come even close to a modern rework Air station.
      • y_not
        Same 'ol Song
        • Aug 2009
        • 147
        Is it the SC5000?
        The newer one I linked to doesn't use hot air to do the vacuum desoldering. It uses a ceramic heater core iron /w a hot, hollow tip connected to a "vacuum" pump. Which, when activated, sucks the molten solder into the chamber and yadda yadda.
        You can however reverse the vacuum pump to blow out, instead of suck in.
        As far as I know, they're still manufacturing them. It's pump specs are on-par with the Hakko stations, which exceed the specs of the Hakko 808 self contained unit.
        It's a $400 tool, not $1k. True, cost doesn't necessarily indicate performance or quality. I just felt that it had some design aspects worth looking at.
        The one you have, or this one?
        Yeah, I wouldn't think it'd be "as good", but I figured it'd be close enough for basic things like pulling off small BGA chips, not big ones like GPUs or NBs but like bga ram. Pulling off multi-leg "non BGA" ram chips and the like.
        Nothing hugely fancy ya know.
        "Multi-Use" tools are seldom ever as good as a stand alone tool designed for the job. Just figure if it's there, it'd be nice to have it for use here & there.
        Not my main buying consideration decision for the unit whatsoever. I have stated those above. One user did state that it was a great feature to use just for clearing out the molten solder in the tip alone.
        I wasn't planning on hot air heating through hole components to de-solder them. That's why it has a vacuum pump for that, which is what you should use for the job. I know one tech did 35,000 some odd joints on a massive mixing board /w over 2200 switches.
        It only took him 20 minutes!! That'd mean he didn't even have to change the filter. I would presume.
        #16 - end of post.
        http://www.groupdiy.com/index.php?PH...&topic=49876.0
        It's not like I plan on re-flowing an Xbox GPU or something with it. I know only a good, non-chinese made station will do that.
        • Kiriakos GR
          Banned
          • May 2012
          • 940
          • Greece
          If you have not test the tool ... you are unable to speak about performance.
          Enjoy the view.
          • smason
            • 1652
            This we know.
            The 808 is $300.00 at the local shop here
            I'll be in California next week, I may nab one at Fry's for $180. (they want $70.00 to ship, so I'll pick it up)
            • y_not
              Same 'ol Song
              • Aug 2009
              • 147
              You can get it for that new on Amazon /w free freight. No stand, however there is a sock included. As I understand it, the stands become rather topheavy with the large unwieldy gun in it. It has been suggested to put a heavy weight on the base of the metal, tan colored, Hakko stand. Or bolt it to the bench. Problem solved.
              • smason
                • 1652
                Not to Canada. All I ever get from Amazon.com is:
                " We're sorry. This item can't be shipped to your selected destination. You may either change the shipping address or delete the item from your order. "
                And from Amazon.ca:
                Hakko Desoldering Kit, With 808 Gun, 120 VAC
                CDN$ 301.99
                Usually ships in 6 to 10 days
                More buying choices
                CDN$ 301.99 new "
                Nice deal!
                • y_not
                  Same 'ol Song
                  • Aug 2009
                  • 147
                  I'm sorry, but I don't see anywhere in my posts in which is spoke of my own personal experience with any of the products. Only what I'd read others say in regards to them.
                  That's definitely the previous generation model, of which I can find no information.
                  Have you used any other vacuum desoldering units? Whether owned by you or not. If so what were they and what sort of experience did you have with them?
                  • y_not
                    Same 'ol Song
                    • Aug 2009
                    • 147
                    "We're sorry. This item can't be shipped to your selected destination. You may either change the shipping address or delete the item from your order."
                    How LAME!
                    Use a freight forwarding service. Boom, problem solved.
                    • mariushm
                      • May 2011
                      • 3799
                      US Hakko distributor on eBay:
                      http://stores.ebay.com/NEI-Lamps-and...=p4634.c0.m322
                      178$ or more + (I think) 42$ shipping to canada
                      • capkid
                        • Oct 2010
                        • 1339
                        I got my 808 on eBay for $179, including shipping from this seller: www*bdent*com. I've bought several items from them, so they appear to be very reputable.
                        Edit: Duh, I saw you're in Canada. It doesn't look like they ship there.
                        LG Plasma Mal-Discharge Correction Service
                        • Kiriakos GR
                          Banned
                          • May 2012
                          • 940
                          • Greece
                          All that I am trying to do, is to protect you from getting something that it will not work.
                          This is a hand tool, the pump is tiny, no matter the model as 5000 or 7000, the pump in those dedicated hot air stations is double or triple in size.
                          Yes I have use recently a Hot air station which it was doing miracles regarding performance, the lesson that I got from it is to select my own among the ones with analog temperature controls.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 4955
                            • New Zealand
                            I have an SC5000 also. It works quite well on multilayer boards if I preheat the board with hot air first.
                            What I do not like though is that since the pump is in the handle it vibrates through to the work and can cause damage to the board more easily.
                            -David VanHorn
                            • Kiriakos GR
                              Banned
                              • May 2012
                              • 940
                              • Greece
                              Well @y_not made me to have a second look on my SC5000 prior giving my reply above.
                              I did take out for a first time in my life this 1.5mm copper noose and the about 10cm long tube came out too.
                              My finding was that the on-board wire ( cleaner for the noose) it very thin and incapable to clean sufficiently the tube where the air moves.
                              I did clean it up by entering an 1.5mm drill bit.
                              After restoring the air flow I did run some tests, but I got disappointed again.
                              It can heat up one solder blob and make it soft regarding melting, but it has no power to move the solder away from the PCB.
                              In the best scenario you are using the metal noose to heat up the solder, and you may use the air just to push and clean the PCB hole and that's it.
                              I have one Nvidia VGA which has a cap that needs replacement, the SC5000 even by been clean as new it was incapable to do the magic.
                              My feelings about it due the fact that I own it for two decades, is that due the new multi-layer PCB,s this tools has lost it practical value.
                              Preheat with another hot air tool and then with the SC5000 it is like using two cars at once with just a single driver = extra trouble.
                              • Agent24
                                I see dead caps
                                • Oct 2007
                                • 4955
                                • New Zealand
                                It sounds like maybe you did not really get a full melt. I followed the procedure I saw here: http://youtu.be/e8KRPFOD1RE - moving the tip around to check that the lead is loose.
                                On multilayer boards, the trick is getting the feel for when the lead comes totally 'free' in the hole and not just half-way. There is a difference but it's small. I am still getting the hang of it. Thick\wide leads in small holes usually feel different.
                                I don't know if it's the best solution, but it does seem to work. Just have to be careful not to overheat the board, I have lifted some pads being too aggressive with the hot air before. You have to preheat for longer on the big copper planes.
                                I see on 'proper' pre-heater stations (Hot air or IR), they all have a thermocouple you are supposed to use to keep the board temperature in check. These would probably be a better idea.
                                -David VanHorn
                                • Kiriakos GR
                                  Banned
                                  • May 2012
                                  • 940
                                  • Greece
                                  Thanks for the video @Agent24 it did remind me the old good days.
                                  • int0x13
                                    • Nov 2012
                                    • 42
                                    • France
                                    I discovered those video from company PACE and they are really a reference to learn the soldering. I wish i would see them 10 years ago!!!
                                    Are them really from the 1980's ?!!!
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4955
                                      • New Zealand
                                      They sure look like it to me
                                      -David VanHorn
                                      • japlytic
                                        • Oct 2005
                                        • 2086
                                        I prefer an all-in-one unit, since the station can have a bit of lag.
                                        • flat-earther
                                          Hoover FM216LI cordless vacuum refuses to charge
                                          by flat-earther
                                          I have a Hoover FM216LI cordless vacuum which isn't charging its internal battery.
                                          I opened up the unit, and it has 6x Samsung ICR18650-22P cells connected in series.
                                          5 cells were at about 3.3-3.1V. one was at 2.4V, so I assumed this cell was bad that's why the vacuum wasn't charging so I replaced it with another 18650, but after that the problem still persists, the vacuum turns on a bit and then cuts out since the batteries are empty.
                                          So I think the over discharged battery wasn't the culprit, it was a symptom of the unit not being able to charge its batteries....
                                          06-06-2025, 03:14 AM
                                        • hans_meier
                                          HP EliteBook 840 G6 how to dump without desoldering
                                          by hans_meier
                                          I have an "HP EliteBook 840 G6" and would like to know how to dump the BIOS flash chip without desoldering. Putting 3.3V on VCC of the BIOS chip with a programmer does not work (seems to enable the PCH). I have read some general notes about connecting the CPU reset to ground or to bypass oscillators. There does not seem to be a reset line for Intel i5-8365U. Just RSMRST, but it's only accessible on the other side of the mainboard. Is there an easy way to dump the flash without desoldering and without removing the mainboard? Does anyone have experience with this? Maybe...
                                          01-04-2025, 04:11 PM
                                        • AlexVG
                                          Replacing the WiFi module on a vacuum cleaner iROBOT i7
                                          by AlexVG
                                          I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
                                          I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
                                          (This board does not respond, only the LEDs light up in a circle.
                                          The liquid damage is catastrophic and restoration is impractical).
                                          (I bought this board to get the WiFi module and camera).
                                          The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
                                          If...
                                          10-22-2024, 07:20 AM
                                          ZD-915 vacuum pump motor mount service alert
                                          by sam_sam_sam
                                          If you have this Desoldering Gun Station there is something you should be aware of the two screws that hold the motor to mounting for pump can come loose and make raddling noise
                                          One note this unit has been repaired already once because of switching power supply regulator ic chip failure
                                          Now this with the vacuum motor mounting issue yes I give this Desoldering station a very hard work out and use about every weekend to do some type of project
                                          The fix is taking the vacuum pump assembly out and take the metal cover off and you will see the two screws on it
                                          09-19-2021, 02:15 AM
                                        • Dreigas
                                          ISL95880HRTZ desoldering temperature
                                          by Dreigas
                                          I bought from China ISL95880HRTZ (3+1+1 Voltage Regulator with Expanded ICCMAX Register Range Supporting IMVP8 CFL/CNL CPUs) chip, which I think is not the original one, but anyway, I tried to resoldering it with a 380C hot air station. Seems soldering is pretty good, but the laptop doesn't work (it worked before, but still had some problems with power delivery).
                                          Is there any big chance, that they sent me two fake ISL95880HRTZ chips or did I just use too big temperature for desoldering? I will try with another chip, but I can't find any info about the maximum desoldering...
                                          09-13-2024, 10:59 PM
