Recall notice - PowerFist Multimeter
  • Kiriakos GR
    Banned
    • May 2012
    • 940
    • Greece
    Re: Recall notice - PowerFist Multimeter
    Originally posted by retiredcaps
    If I tried to make a current measurement, it could have went poof
    Well if we remove temporarily from the equation the case about an accident due over current which is something more usual in the automotive repairs.
    The truth is that the speed that those fuses get blown is crucial to protect and the dmm circuitry, and I am talking about some diodes near by the shunt.
    Even a slow blow fuse it is capable to do damage on the dmm it self.
    Up to date I have blown the 440mA Fuse twice and always accidentally, with 12V or less.
    Fluke should offer and a choice for such fuses at 500V which are much cheaper.
    I do not see the point people in automotive repairs or in CAT II which is the most common environments for the 90% of the electricians, to pay the price premium for 1000V fuses.
    I have make some HRC fuses tear down so to see what we are paying after all.
    http://www.ittsb.eu/forum/index.php?board=16.0
      If you do not particularly care about 1000V rating (very few do) you could always use the excellent BS 1363 fuses. 1A, 3A, 5A, 7A, 10A and 13A are available, with 3A, 5A, and 13A being relatively cheap, less than £0.10 each. These are reliable and rugged fuses and will safely interrupt most faults that a regular home user (not an electrician) would encounter.
      • Kiriakos GR
        Banned
        • May 2012
        • 940
        • Greece
        Even if technically or practically it is possible to use 500V fuses, the true complete or acceptable approach would be the meter to be some what capable to auto-detect the fuse that is inserted to it.
        Most serious DMM which use 1000V fuses, comes also with 1000V+ over-voltage alarm function.
        The smart meter should be capable to detect the fuses and adjust this over voltage alarm according to fuse type.
        Yes I am talking about something that is not here yet, but I have some ideas of how this is possible to be implemented, I case that I will be asked by an product engineer in the future. :-)
        • MDOC
          EngineeringTech
          • Mar 2010
          • 146
          Picture attached. The fuse shown is the blown mA for size reference. As you can see the 10A "fuse" is a bit longer.
          What pisses me off is that the metal drill bit is heavy. If I had dropped the multimeter, the fuse could have moved every so slightly and made contact with the components on the pcb.
          Well, maybe. Only if you attempt to measure a current value that's above the original fuse rating, or you dropped it and the "fuse" dislodged. Otherwise, no fireworks.
          And that's a screw, not a drill bit.
          • dj8452000
            How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
            by dj8452000
            I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
            02-18-2025, 08:28 AM
          • trex66
            Craftsman 82345 Multimeter broke!
            by trex66
            My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
            03-04-2025, 04:26 PM
          • Sofian75
            Things not to do with a multimeter?
            by Sofian75
            I started to learn laptop repair a few weeks ago, since then I ve ordered several dead laptops to try to fix them and learn.
            I fixed some of them and some I ve made things worse by blowing components.
            Every time while taking measurements with my multimeter.
            Yesterday I was working on a dell laptop motherboard, I was checking the charge IC for short in diode mode and it killed the chip.
            So my question is are there things I should not do with my multimeter?
            Or measurements I should do only with the charger and battery unplugged?...
            06-27-2024, 05:13 AM
          • spleenharvester
            GRT60-145410 brick PSU, how much of a fire hazard is this thing exactly?
            by spleenharvester
            I bought an Alpicool C20 fridge, which is a 60W compressor fridge that runs on 12V or 24V, which can come from either an AC/DC adapter from mains (240V here in UK) or a car battery. The fridge itself is really good quality, so I was surprised to find the power supply (DC14.5V, 4.1A) pretty questionable. Despite being 240V/1.5A the plug was fitted with a 13A fuse - concerning, but not all that uncommon for imported chinese electronics here. But when I felt how light the brick was I immediately said hell no and transferred the proprietary connector to a MeanWell GS90A12-P1M brick (this supply is...
            07-08-2025, 06:02 PM
          • antoniu200
            Why does my Uni-T multimeter not measure anything?
            by antoniu200
            Hi! So, a couple of months ago, I got tired of me watching my movies and when someone flips a certain switch in the house, my Blu-Ray to stop working for a second, then come back on (the TV being fine, mind you, connected both at the same outlet). So, I took my multimeter (Uni-T UT33B) and tried to measure the voltage of my outlet when that switch is flipped. Dumb me, I set the multimeter for DC Voltage, while connecting the red cable to the Unfused connection. Of course, both the fuses in the multimeter and in my house blew.
            Now, I replaced the fuse in the multimeter, but it still...
            11-11-2019, 07:40 AM
